查看: 9046|回复: 1
[LabVIEW] NI LabVIEW 2013 MAC OS X32Eng LV2013苹果系统评估版
    10 小时前
    发表于 2013-8-7 12:17:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    百度网盘下载地址和NI官方下载地址:
    注册登录视觉论坛账号,购买附件下载查看
    LV2013MAC.txt (225 Bytes, 下载次数: 65, 售价: 10 圆)
    LabVIEW 2013 Readme for OS X
    Version 13.0.0
    June 2013
    This file contains late breaking news about LabVIEW 2013 for Linux and supersedes any information found in other documentation included in the distribution. Refer to ni.com/linux for the most recent information about Linux support at National Instruments.
    Refer to the LabVIEW Help located in the labview/help directory for more information about LabVIEW 2013.
    Additions to the LabVIEW Help
    Important Information
    OS XRun-Time EngineDevelopment Environment
    ProcessorIntel-based processorIntel-based processor
    Screen Resolution1024 x 768 Pixels1024 x 768 Pixels
    Operating SystemOS X 10.5, 10.6, 10.7, or 10.8OS X 10.7 or 10.8
    Disk Space656 MB - 1.2 GB1.2 GB for the complete installation (excluding drivers)
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  National Instruments recommends that you use Firefox 3.0 or later or Safari 3.0.4 or later to view the LabVIEW Help.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2013.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW 2013.
    • Because LabVIEW 2013 may apply different compiler optimizations on different machines, you may need to perform additional steps to guarantee that a built application contains the same binary contents when built on different machines. Refer to the National Instruments website for more information about reproducing builds in LabVIEW 2013.
    • If you create a VI that overrides a property accessor VI in a parent LabVIEW class, you must provide the same name and folder path in the property definition folders for both the child and parent classes.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2013. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    3960449UBP4LEWrite to Clipboard Method consumes 100% of CPU for several minutes
    439314GPF7QYESave Report to File.vi copies images from Temp rather than moving them
    91672477M7K00Large amounts of data in combo box can appear to hang LabVIEW
    136939Dragging an unsaved VI from one project to another, and then closing the original project without saving corrupts the VI
    138552Load VRML File.vi missing "error in" terminal
    148149Event Structure cases can incorrectly remap to other dynamic events
    214989Dropping a System OK button silently removes any existing key binding for the key
    221251Shared Variable values discarded after system restart
    233963Service Locator does not work when installed to a path containing stress characters
    240362Image in Header or Footer.vi created HTML-files with one additional unwanted '<' character
    242214LabVIEW does not marshal .NET objects, so you cannot make a LabVIEW .NET assembly with a usable .NET refnum in the connector pane
    248755Zoom, pan, and rotate sometimes cause 3D objects to move in 3D Scene Displays
    253088Programmatic tab view changes sometimes fail if front panel controls are being updated with property nodes
    256978Custom Font Setting tokens in LabVIEW.ini file are overwritten when you modify any other part of the INI file
    279047Coercing a cluster containing a cluster to a variant can cause the inner cluster to have its labels change
    280941DWarn: ProjectItem.cpp line 8914 sometimes thrown when using auto-populating folders
    287984lvanlys.dll fails to load on an 8 core processor
    288741Non-handled, registered dynamic events reset the Event structure timeout
    294464Connected PSP property returns error on Shared Variables that have write only access
    300375Scan From String returns error when using %y%m formatting with 2 digit years
    301753SMTP Email Send Message VI: Subject line with more than 45 connected characters causes error
    303503When a LVM file is read by the Read from Measurement File Express VI, the Y Unit attribute is ignored
    306025Changing the front properties of a front panel object affects all objects created after it
    309897Scan from String incorrectly parses a string containing SI notation
    312458Fatal Internal Error: "proptype.cpp" sometimes displayed when programmatically exiting LabVIEW
    312533Private member VIs of a library can be exported in .NET interop assemblies
    315663Files inside a NIER Report have the incorrect date
    317314LabVIEW "Terminal" based web services don't display more than 6 digits of precision
    318263Changing a type def text ring control to a constant causes the display format to change to floating point
    319888Using NaN in Y array of XY Graph causes line not to plot
    321518Nested source-only type-defined clusters may not propagate changes to calling VIs
    322705Find and Replace text sometimes does not find all instances of text
    323078Silver XY Graph's legend does not snap to upper-right corner of graph when control is set to fit to pane
    325150The tip strips for the Variant To/From Element nodes on the In Place Element structure are missing
    330806Incorrect time stamp plotted when using Express VIs
    331293Font changes to XY Graph affect non-selected controls
    334314Creating an Override VI for a child class that has a parent in a Packed Project Library gives error 1035
    334661Pane setting "Scale Objects While Resizing" is disabled after programmatically disabling scaling and then reenabling it for a single object
    339553Under certain conditions, wiring a mismatching data type to a Property Node input does not cause a broken run arrow
    339661Using the Export to CSlipboard method with a Mixed Signal Graph causes LabVIEW to crash
    342148Using a Boolean reference as the first item in a cluster can cause LabVIEW to crash
    346295Cannot create negative user-defined error codes in the Edit Error Code Assistant
    347249Keeping the mouse over the drop-down menu for a combo box causes high CPU usage
    352625Creating patches for an installer leaves multiple entries in Add/Remove Programs
    354737Running eight remote front panel executables on the same port on the same computer causes significant performance degradation
    354827Polymorphic VIs break the wires connected to their outputs when switching between a specific type and Automatic
    354829MathScript Node hangs using certain data sets for linear and cubic 2D interpolation
    355198The Revision History dialog always appears when building an executable containing LabVIEW classes even if they are saved
    355966Changes to typedef enum sometimes do not prompt affected open VIs to save
    356466Stopping VIs and immediately closing project may crash LabVIEW
    357219Pasting into the Icon Editor stretches the clipboard image in the x and y directions
    358049When a specific VI is opened and closed, LabVIEW remains in the task bar, with no windows open
    359369Application Font change not applied correctly when pasting text
    360520Crash when dropping a cluster with a disabled table into an empty array control
    360757Deploying a project created with the Actor Framework template makes LabVIEW unresponsive
    361635Importing strings to a cluster containing two or more tables throws an error
    361636Ignore Timestamp property does not work for Mixed Signal Graphs
    361793I/O tags with names that are identical except for case behave differently in a built application
    362742Updating multiple shared variables' Networking Published: Binding Project Path crashes LabVIEW
    362812Quit LabVIEW primitive does not work in subVIs called by an Asynchronous Call by Reference function
    363363Undo does not work for the VI Properties dialog Reentrancy setting
    364154Cross-linking can occur if you use a sample project that contains an FPGA target before installing the LabVIEW FPGA Module
    364607Invalid Network VISA reference causes DAQmx calls to slow in different loop
    364643Cursor does not associate with correct plot when using Cursor.Plot property with waveforms of different scales
    365087Register Event Callback crashes LabVIEW when wired to front panel object
    366427.NET property exceptions are not propagated by the error wire if called with a LabVIEW Property Node
    367445Source distribution of a class that uses dynamic dispatch can become broken looking for a missing subVI
    369125Shortcut menu does not allow the user to select items using the right mouse button
    369472Polymorphic VIs lose their icons when built into packed libraries
    369537Trying to set the "Active Bus" property on a Digital Waveform Graph crashes LabVIEW
    369691LabVIEW crashes if a Plot Visibility Checkbox of a Silver Waveform Graph is customized
    369833Draw VIs sometimes create corrupt PNG images when used with the LV Image to PNG Data VI
    369872Polymorphic VIs are not password-protected when built into source distributions
    371030A Waveform Graph incorrectly shows more peak plots when doing peak detection in combination with certain bar plot styles
    372390Hermite Interpolation 1D VI does not correctly interpolate certain data sets
    373396Sub-diagram labels that have been resized do not maintain their size when you edit them
    373399Resizing a sub-diagram label and bolding text within it bolds other text on the block diagram
    374196A Call Library Function Node referencing a function that does not exist within an existing DLL attempts to load despite being in a Diagram Disable structure
    375002Old library icon template persists on lower layer of VI icon after making library icon changes
    375760Displaying transposed array data on a Waveform Chart typedef causes crash during execution
    375872Crash when setting a floating-point numeric control to Inf, -Inf, or NaN when the control is configured for relative time display format
    376574Launching the Getting Started Window repeatedly can launch a blank VI instead of the Getting Started Window
    376714Using the Merge VIs utility with VIs that contain a tab control causes LabVIEW to hang
    377021Primitives are not correctly overloaded for Silver Matrix controls
    378888The Mixed Signal Graph does not correctly label plots in LabVIEW 2012
    378947MD5Checksum File VI returns the wrong value for files larger than 4GB
    379023Items with colons in their localized names do not drop with Quick Drop in LabVIEW German
    379095Changing display format on an EXT indicator produces an "End of file encountered" dialog
    379444Register Event Callback does not work in LabVIEW 2012 Base Development System
    380475Data returned from a LabVIEW built .NET Assembly that unbundles a cluster is incorrect
    380741Array Subset function can add an extra value to the output array when used on a fixed-sized array
    381638Waveform chart x-axis scales incorrectly when Plot Area scrolls for new data
    381707The Render to Image method for 3D picture controls demonstrates slow performance
    382333The Match Regular Expression VI in LabVIEW 2012 on Linux crashes when the screen color depth is set to 16-bit
    382668Silver Multicolumn Listbox has six blank cells when placed from palette
    383351LabVIEW crashes if a subVI front panel is continually open and closed while its graphs are updated
    383525The "auto-detect the storage format" option of the Open Data Storage Express VI only works the first time you wire the VI
    384576NI SSL Libraries not installed for LabVIEW Runtime Engine on OS X
    384767Performance of Error Cluster From Error Code VI is hurt by VI Server calls
    385212Adding and removing a registry key from a build specification can cause the build specification to become corrupt
    385247Custom Waveform Graphs display NaN values incorrectly
    385317LabVIEW crashes when a Value Change user event is registered on a Panel GOjbect
    385324The Max&Min VI incorrectly compares NaN values in arrays of 16 or more
    386813Changing an Error Cluster constant to a control, then undoing the change, causes the front panel to hang
    387768SubVI execution speed is reduced if SubVI contains a Case structure with an unwired 2D string array tunnel
    388083LabVIEW crashes when you open Profile Performance and Memory window from a library
    388419Registering a cluster containing an array of user-defined events crashes LabVIEW 64-bit
    389295LabVIEW 2012 SP1 breaks custom prototypes in DLLs that contain LabVIEW classes
    389991Memory leak when calling LabVIEW DLLs from C with new threads
    390386LabVIEW HTTP Client does not implement Curl Rewind, causing authentication errors for auth-basic
    390673Crash when you open a VI containing a Time Domain Math Express VI in LabVIEW 2012 after saving the VI for 2011
    390908Crash on Windows 64-bit when X input of the Cubic Spline Fit VI is empty
    391285NI Variable Engine tagsrv.exe cannot handle illegal characters in OPC Tag names
    391783Compiler error: "copy cvt str/pict/tag, csrc=0x21" on conditional auto-indexing tunnel
    394001Timestamp data exported to DIAdem from graphs is incorrect
    395404Reading MixedSignalGraph.PlotClassName causes Access Violation crash
    395901Compiler error: "maxmin only minip?" when LabVIEW 2011 VI is compiled in LabVIEW 2012
    396062After upgrading VI to 2012 SP1 the Round to Nearest function sometimes produces incorrect value if debugging is not allowed
    396305Conversion from EXT to U64 is incorrect for integers greater than 53 bits, when the top 53 bits are set
    396603The X-axis tick marks on strip charts move further than data points when updating
    396984Sequential For Loops sometimes execute incorrectly when VI property "Allow Debugging" is disabled
    403235DAbort 0xF50EFD7B in MemoryManager.cpp when auto-indexing a 2D waveform
    403284Execution speed does not return to normal after removing debug probes
    403386Using a property node to rapidly read the references to the variables deployed on a target introduces memory leak
    404117Cannot create Shared Variable if properties are copied from a Shared Variable inside a virtual folder
    © 2004–2013 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, LabVIEW, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    发表于 2014-2-18 20:40:51 | 显示全部楼层 来自:江苏省南京市 电信
    GMT+8, 2025-12-8 19:31
