查看: 7821|回复: 0
[NI驱动程序] NI Vision Acquisition Software 2017.01 LabVIEW2016 Win32/64Eng 视觉采集软件VAS_2017_01下载
    11 小时前
    发表于 2017-4-25 18:39:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    视觉采集软件属于驱动程序软件,用于采集、显示和保存各类相机的图像。NI视觉采集软件(VAS)使您能够采集、显示和保存各种行业标准相机(包括GigE Vision、USB3 Vision和Camera Link)和图像。您还可以使用此软件轻松地控制NI视觉硬件上的数字I/O。借用一套易于使用的函数和示例程序,您可以使用LabVIEW、LabVIEW NXG和C/C++快速创建应用程序。
    因为没有相应的LabVIEW2016SP1版本,所以VAS2017.01也就没有针对LabVIEW2016SP1,仍然是针对LabVIEW2016的。注意该版本不能用于后面的LabVIEW2017版本。
    发布日期:17-3-21
    语言:英文
    大小:2.92GB
    支持操作系统:
    Windows 10
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Checksum(MD5):d3fb41556b1fdcce01d2781a5a768f42
    文件大小: 3139746045 字节 (2.92 GB)
    修改日期: 2019-01-03 13:25
    MD5: d3fb41556b1fdcce01d2781a5a768f42(官方正确)
    SHA1: 2b2f768abc5c5ecb6741a7983d6d969b1f1a09df
    SHA256: 605205e6e155bf7dddc1721510ac9a67265fc8ec1156a926b3c3762a00d8ce05
    CRC32: 281f9fb1
    标准下载:
    链接:
    请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI下载器下载:
    链接:
    提取码: 请购买附件下载查看
    NI在线下载地址(可能无效或无法下载完成):
    标准下载:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    VAS2017.01.txt (487 Bytes, 下载次数: 40, 售价: 10 圆)
    NI Vision Acquisition Software Readme
    January 2017
    This file contains important information about National Instruments Vision Acquisition Software, including installation instructions, new features, fixed issues, and known issues.
    Updates and Improvements
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    Documentation and Examples
    NI Vision Acquisition Software allows you to acquire, display, and save images; control digital I/O on National Instruments image acquisition devices; and configure your driver software and hardware. Refer to the NI Vision website at ni.com/vision for the latest information about NI Vision Acquisition Software.
    NI Vision Acquisition Software includes the following drivers:
    • NI-IMAQ is driver software for the following device types:
      • NI 17xx smart cameras
      • analog cameras
      • parallel digital cameras
      • Camera Link cameras
    • NI-IMAQdx is driver software for the following device types:
      • NI 177x smart cameras
      • ISC-178x real-time smart cameras
      • GigE Vision-compliant cameras
      • USB3 Vision-compliant cameras
      • IIDC/DCAM-compliant IEEE 1394 cameras
      • DirectShow-compatible cameras
      • Basler and Axis IP cameras
    • NI-IMAQ I/O is driver software for controlling reconfigurable input/output (RIO) on image acquisition devices and real-time targets. The following hardware is supported by NI-IMAQ I/O:
      • NI CVS-1457RT
      • NI CVS-1458
      • NI CVS-1458RT
      • NI CVS-1459
      • NI CVS-1459RT
      • NI EVS-1463
      • NI EVS-1463RT
      • NI EVS-1464
      • NI EVS-1464RT
      • NI PCI-8254R
      • NI PCIe-8255R
      • NI PCIe-8237R
      • NI PCIe-1473R
      • NI PCIe-1473R-LX110
      • NI 1483 FlexRIO Adapter Module
    • Note: New versions of Vision Acquisition Software no longer support the following hardware:
      • NI 1762 and 1764 Smart Cameras
      • NI CVS-1454, 1455, and 1456 Compact Vision Systems
    • Note: The EVS-146x series of controllers are not supported in LabVIEW 2016 or later.
    Additional Driver Software
    Some hardware requires driver software in addition to Vision Acquisition Software drivers. Refer to the National Instruments website at ni.com/drivers for information about these drivers.
    • The NI PCIe-1473R and NI PCIe-1473R-LX110 require NI FlexRIO software to access the DRAM resources in a LabVIEW FPGA project.
    • The NI 1483 FlexRIO Adapter Module requires NI FlexRIO software.
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    Minimum Recommended
    Free Hard Disk Space
    3.5 GB
    NI-IMAQ
    1.5 GB
    NI-IMAQdx
    1.5 GB
    NI-IMAQ I/O
    2.5 GB
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    Note  NI Vision Acquisition Software August 2016 dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Acquisition Software August 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Acquisition Software August 2016 or later to an unsupported OS. Additionally, after installing NI Vision Acquisition Software August 2016 or later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Acquisition Software. The installer specifically allows side-by-side installations of NI Vision Acquisition Software for each of the supported versions of LabVIEW, enabling you to use the NI Vision Acquisition Software with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing NI Vision Acquisition Software.
    NI Application SoftwareVersions Supported by NI Vision Acquisition Software
    NI LabVIEW
    2013, 2014, 2015, 2016
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabWindows™/CVI™
    2010, 2012, 2013, 2015
    NI Vision Development Module
    7.1 or later
    NI Vision Builder for Automated Inspection
    2.5 or later
    NI Vision Acquisition Software .NET Support
    NI Vision Acquisition Software February 2014 was the last version to release updated support for the .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Acquisition Software will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    This release of NI Vision Acquisition Software includes the following new features.
    NI-IMAQ 16.0
    • No new features in this release
    NI-IMAQdx 16.2
    • Support for ISC-178x smart cameras running Linux Real-Time in LabVIEW 2015 and later
    NI-IMAQ I/O 16.1
    The following list describes issues in previous versions of NI Vision Acquisition Software that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Acquisition Software.
    608370, 629758On NI CVS-1458RT Linux Real-Time targets, communication with the host may not by default get sent out through the primary/host Ethernet port if the host and other devices are all connected with link-local addressing (LLA).
    617482, 629760On NI CVS-1458RT Linux Real-Time targets, Ethernet interfaces do not always enumerate with the expected name order upon boot.
    626575, 629757On NI CVS-1458RT Linux Real-Time targets, devices connected with link-local addressing (LLA) can sometimes obtain duplicate IP addresses upon link negotiation.
    Complete the following steps to install NI Vision Acquisition Software.
    Note: You must have administrator access to install NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation media.
    NI-IMAQ and NI-IMAQdx integrate with NI Measurement & Automation Explorer (MAX), the National Instruments utility for configuring and testing your measurement and automation system. The NI MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ.
    • Run NI MAX.
      • Double-click the NI MAX icon on the desktop. You can use NI MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces and NI-IMAQ Devices to display a list of the image acquisition devices installed on your computer.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with NI MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Use NI MAX to install NI-IMAQ for LabVIEW Real-Time from the host machine onto the target system. The NI-IMAQ for LabVIEW Real-Time components enable the remote device to acquire and analyze images as directed by the host machine.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the NI MAX help window to install software.
    • Launch NI MAX.
    • Expand NI-IMAQ Devices.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the NI MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to configure NI-IMAQdx.
    If you are using a USB webcam or other DirectShow-compatible camera, ensure that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an IEEE 1394, USB3 Vision, GigE Vision, or IP camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    Installing the Legacy USB3 Vision Driver for Windows 10 Systems with Secure Boot Enabled
    Windows 10 systems with Secure Boot enabled cannot load the default installed USB3 Vision drivers. You may either disable Secure Boot to use the installed driver as is, or you may associate the camera with an earlier release of the driver from NI-IMAQdx 16.0. The earlier driver does not contain all the latest features and fixes. To associate your camera with the earlier driver, complete the following steps.
    • Plug the USB3 Vision camera into your system.
    • Right-click the camera in the Device Manager, and select Update Driver Software.
    • Choose Browse my computer for driver software.
    • Choose Let me pick from a list of device drivers on my computer.
    • Select your USB3 Vision driver from the following options:
      • If only one driver is listed as NI-IMAQdx USB3 Vision Device, it is the default installed driver and must be overridden:
        • Click Have Disk.
        • In the Install from Disk dialog box, browse to the driver location. The legacy driver version is installed to \NI-IMAQdx\Staging\NI USB3 Vision Legacy.
        • Click OK.
        • The single driver choice shown at this time is the legacy driver. Choose NI-IMAQdx USB3 Vision Device.
      • If more than one driver is listed as NI-IMAQdx USB3 Vision Device, choose NI-IMAQdx USB3 Vision Device Version: 16.0.0.49152.
    • Click Next.
    • Click Close.
    • Install the NIC.
    • Browse to the driver location. The newest driver version is installed to \NI-IMAQdx\Staging\NI GigE Vision.
    • Click Next.
    • Click Close.
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps.
    Complete the following steps to configure NI-IMAQdx for Windows.
    • Connect the camera.
    • Run NI MAX.
      • Double-click the NI MAX icon on your desktop. You can use NI MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • For IEEE 1394 and USB3 Vision cameras, NI-IMAQdx may not be associated with the camera if a third-party driver is installed. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx.
    • Run NI MAX.
      • Configure your network settings. Refer to the Remote Systems Help in NI MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the Real-Time target, using one of the following options:
      • Recommended Software Set on supported Smart Cameras, Embedded Vision Systems, Compact Vision Systems, and CompactRIO controllers
        • Click Add/Remove Software on the NI MAX toolbar to launch the LabVIEW Real-Time Software Wizard.
        • Select Vision Software or NI CompactRIO under the version of the LabVIEW Real-Time Module you are using.
        • Click Next.
        • Select any additional add-ons you would like to install to the target machine. For some real-time targets, such as CompactRIO controllers, NI-IMAQdx or supported camera types will appear as an add-on.
        • Click Next to begin downloading the software to the target machine. When NI MAX has finished downloading the software, it restarts the remote device.
        • Click Finish.
      • Custom installation
        • If you are given a choice of Recommended Software Sets, choose custom software installation and click Next to proceed with a custom installation.
        • Select NI-IMAQdx, as well as any additional software you would like to install on the target machine.
        • Click Finish.
    • Press to refresh the NI MAX configuration tree. Your camera should be listed in the Remote Systems list.
    If the NI product you are installing uses Microsoft .NET 4.6.1, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.1 separately before you install NI software.
    • Runtime installers are localized for deployment, but the development support installers are not. This could lead to a partially localized installation from a custom-built installer.
    NI-IMAQ
    • Changing the interface of an NI-IMAQ device in MAX requires a Refresh (F5) for the update to complete.
    NI-IMAQdx
    • Windows 10 systems with Secure Boot enabled cannot load the default installed USB3 Vision drivers. Refer to the Configuring NI-IMAQdx section of this document for more information.
    • Installing or reinstalling certain drivers, including NI-IMAQdx, on top of previous installations on a Linux Real-Time target can put the target in an unreachable state unless you force it into safe mode using the reset button or manually reassociate driver dependencies on the target. To avoid this issue, format the target prior to installing or reinstalling software, or only perform reinstallations using a Recommended Software Set. To learn more about this issue and additional recovery options, visit ni.com/info and enter the Info Code nikalEmbeddedReinstall.
    • Volume License Manager attempts to check out available NI Vision Development Module licenses before trying NI Vision Acquisition Software licenses.
    • Attempts to extend the evaluation period for NI Vision Acquisition Software licenses from within LabVIEW or the LabVIEW Runtime are unsuccessful in connecting to the internet.
    • Renaming a camera on some real-time targets may take a long time to complete.
    • LabVIEW examples specific to the ISC-178x smart cameras are listed in Example Finder, but are not installed to LabVIEW 2014 and earlier because these versions are unsupported on those targets.
    NI-IMAQ I/O
    • On real-time Compact Vision Systems, switching serial transceiver configuration between RS-485 and RS-232 is not available in MAX. The port can be switched between these modes in the BIOS.
    • Only one NI PCIe-1473R framegrabber can use the virtual serial port at a time.
    • LabVIEW projects targeting the DRAM banks on the PCIe-1473R may give a configuration error when attempting to compile bitstreams. In certain combinations of LabVIEW and NI FlexRIO 14.5 or older, the instructions to fix this issue may be incorrect.
    Documentation and examples are installed onto your hard drive with NI Vision Acquisition Software. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation and then select the driver documentation. You can also navigate to \Public\Public Documents\National Instruments. Some application-specific documents are installed to the application help folder, as listed in the following sections.
    NI Vision Acquisition Software Documentation for NI MAX
    • You can access the Measurement & Automation Explorer Help for NI-IMAQ and the Measurement & Automation Explorer Help for NI-IMAQdx from the NI MAX Help menu by selecting Help»Help Topics»NI Vision. These documents are installed to \MAX\Help.
    NI Vision Acquisition Software Documentation for LabVIEW
    • You can access the NI-IMAQ VI Reference Help, NI-IMAQdx VI Reference Help, and NI Vision-RIO VI Reference Help from the LabVIEW Help menu.
    • NI Example Finder—Illustrates common applications you can create with NI Vision Acquisition Software. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. Vision Acquisition Software examples for LabVIEW are installed to is the location LabVIEW is installed.
    NI Vision Acquisition Software Documentation for LabWindows/CVI
    • NI-IMAQ Function Reference Help—Contains reference information about NI-IMAQ functions for LabWindows/CVI.
    • NI-IMAQdx Function Reference Help—Contains reference information about NI-IMAQdx functions for LabWindows/CVI.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each function to access help for that function, control, function class, and function library. The NIIMAQdx.fp, and \CVI\Bin.
    • Example programs are installed to
      • version\samples
    NI Vision Acquisition Software for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application. This document is installed to \Vision\Help.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples, and then select the driver you want to see examples for. You can also navigate to \Public\Public Documents\National Instruments.
    © 2017 National Instruments. All rights reserved.
    375130E-01
    GMT+8, 2025-12-8 20:47
