查看: 12106|回复: 0
[LabVIEW] NI LabVIEW 2017 Win64ENG 64位LV2017英文版下载
    昨天 16:03
    发表于 2017-5-23 12:19:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2017年5月春季包更新全新LabVIEW2017版,该软件包含了下一代的LabVIEW NXG。LabVIEW2017共发布了64位英文版、32位英文版、32位中文版、32位日文版、32位韩文版、32位法语版、32位德语版以及MAC系统版本等多个版本。请根据需要选择不同的版本安装。
    NI发布软件不按套路出牌了,按以前的套路,这个时候应该是出LabVIEW2016SP1版本的,等到下半年8月时,才会出LabVIEW2017了。但是现在将LabVIEW2017直接放到上半年发布了,跳过了LabVIEW2016SP1版本。不管他怎么发布,反正只要性能强劲就好。不过从LV2017版开始,上半年开始发布主版本,下半年则发布SP1版本。调整了一下发布周期。以前是上半年发布上一年的SP1版本,下半年发布当年的主版本。
    百度网盘下载地址:
    标准下载:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI下载器下载:
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)(EXE版和ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期更新重压制版):
    标准下载:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    LV2017ENG64.txt (822 Bytes, 下载次数: 57, 售价: 10 圆)
    LabVIEW 2017 Readme for Windows
    This file contains important information about LabVIEW 2017 for Windows, including system requirements, installation instructions, a partial list of bugs fixed for LabVIEW 2017 for Windows, and known issues.
    LabVIEW 2017 (64-bit)
    Additions to the LabVIEW Help
    LabVIEW 2017 has the following requirements:
    Operating SystemWindows 10/8.12/7 SP13
    Windows Server 2012 R22
    Windows Server 2008 R2 SP13
    1 LabVIEW and LabVIEW Run-Time Engine require processors of the Pentium 4M/G1 generation or later, which are capable of executing SSE2 instructions.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    • In 2016 LabVIEW dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2017 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2017 to an unsupported OS. Additionally, after installing LabVIEW 2017, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Are you installing LabVIEW for the first time? Insert the LabVIEW Platform media and follow the onscreen instructions to install LabVIEW, modules, toolkits, and drivers. When prompted, enter the serial number for each product you want to activate. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2017 (32-bit) and LabVIEW 2017 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    LabVIEW 2017 (64-bit) supports a limited number of modules and toolkits. The following lists compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ProductLabVIEW 2017 (32-bit)LabVIEW 2017 (64-bit)
    ✓1
    Database Connectivity Toolkit
    DataFinder Toolkit
    Digital Filter Design Toolkit
    FPGA Module
    MathScript RT Module
    ✓2
    Real-Time Module
    Robotics Module
    SoftMotion Module
    Statechart Module
    Sound and Vibration Measurement Suite
    Unit Test Framework Toolkit
    VI Analyzer Toolkit
    Vision Development Module
    1 The Control Design and Simulation Module (64-bit) does not support the System Identification VIs, System Identification Assistant, Control Design Assistant, and real-time targets.
    2 The MathScript RT Module (64-bit) does not support the libraries class of MathScript RT Module functions.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2017.
    404983Dynamic load of LabVIEW Class fails when built into a DLL.
    522606Error Ring does not adhere to dataflow in an executable or in a VI with debugging disabled.
    524160Updated Timed Loop Mode example VI to better display custom phase and show correct value for period in context help.
    567353When an XNode output is wired to the Loop count of a Parallel For Loop the VI breaks.
    571901Using the BD Get Image Scaled method crashes LV 2014 and 2015 if the depth of the image is 1.
    572024Built applications hang in some instances when calling Quit LabVIEW.
    584378LabVIEW has the potential to crash when simultaneously setting multiple variant attributes to empty variant constants.
    588140Insert of Compound Arithmetic node on wire can result in undesirable configuration.
    590370Levenberg-Marquardt algorithm has poor convergence in some cases.
    591709Calling Format Value on improper value can result in crash.
    592088Improper updates of library members when using Actor Framework Message Maker.
    594760Example "Extract number with match pattern" gives incorrect output.
    595178Certain examples show incorrect title bars on the Project Window.
    595814The unflatten from String primitive can take several minutes to return when given malformed input strings.
    595815DataSocket Read VI crashes LabVIEW when calling certain IP addresses.
    596804Re-registering a dynamic event can cause subscribing event frames to behave improperly.
    597858File permissions error when saving a LabVIEW file to a Windows Server from Windows 10.
    598986Scrollbar does not properly respond to clicks on string constant.
    599478LabVIEW may not update classes on Real-Time targets after changing the inplaceness of a connector pane terminal for a VI within those classes.
    601256Error message when replacing existing channel endpoint with an invalid configuration is not clear.
    601764Local variables can be created from channel wires.
    601807Resizing a "Register for Events" Node Crashes LabVIEW.
    602230Connecting conflicting channel types does not always break the wire.
    602973In some cases, using the Min/Max function on array of single precision floating point numbers can cause a VI to fail to compile.
    603092Rearranging tabs in tab control can cause a crash.
    603391Incorrect Out of Memory dialog when using "Active Plot" property node in 64-bit LabVIEW.
    603562Using dynamically dispatched VIs with unwired input terminals can, in some cases, cause crashes.
    603576Channels carrying typedefs/classes create crosslinks when users duplicate projects.
    603854QMH project template contains a potential race condition.
    605231Attempting to abort a VI may not always cause the VI to abort.
    606365Dragging a control or indicator to the edge of the block diagram can cause duplication of the front panel object.
    606847Dynamic Dispatch VIs break when the class wire is passed through a shift register in specific cases.
    607685Cast Unit Bases does not correctly remove units from output.
    609835Actor Framework debug traces do not occur on Real-Time targets.
    611532Selecting "Use Default if Unwired" on an output tunnel with a LabVIEW class data type will cause a broken VI with no errors.
    611810Saving a VI containing a "Lookup Channel Probe" node for LabVIEW version 2015 and earlier can result in failure to open the saved VI.
    611838The abort behavior of the Accumulator Tag channel wire does not match that of other implementations.
    612501Interpolate 2D Scattered VI will return an incorrect value for specific size input values.
    615195Collapsing "Variant Attribute Get / Replace" border node on In Place Element Structure causes LabVIEW to crash.
    615288Previous versions of LabVIEW are unable to open dynamic classes saved using "Save for Previous Version" in 2016.
    616848Using Quick Drop to add a Custom Control Template to a VI's Front Panel crashes LabVIEW.
    617119Pressing Abort during project creation then creating another project causes LabVIEW to crash in some cases.
    617504Dragging the front panel icon of a VI onto the block diagram of another VI will undo the last edit of the dragged VI in some cases.
    617917Possible crash when loading particular classes.
    624304Actors that return an error from Pre Launch Init also send a Last Ack containing the same error.
    624957Possible memory corruption when opening invalid file.
    627716Opening a project with "Messenger Channels" causes a search for Wrapper.lvclass.
    627910Large projects may have extended save times.
    • In LabVIEW 2017, you can insert the contents of a subVI into the calling block diagram at edit time by right-clicking the subVI node and selecting Replace with SubVI Contents. In the Replace with SubVI Contents dialog box that appears, you can configure the following options:
      • Make space in calling diagram to fit subVI contents—Specifies whether to adjust the calling block diagram to accommodate the contents of the subVI.
      • Wrap subVI contents in a Sequence structure—Specifies whether to place the contents of the subVI in a Stacked Sequence structure.
    © 2004–2017 National Instruments. All rights reserved.
    374715G-01
    GMT+8, 2026-2-24 22:15
