查看: 9821|回复: 1
[LV工具模块] NI LabVIEW 2015 C Generator Win32ENG 美国国家仪器LV2015Win32位英文版C代码生成器2015版下载 LV程序申请著作权转码工具
    发表于 2018-1-16 17:58:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW C生成器模块可帮助您使用LabVIEW VI为特定目标创建C代码。
    LabVIEW C代码生成器模块是一个软件附件,用于将LabVIEW算法移植到Windows平台、静态库或ARM应用程序等目标。此外,用户可通过要与第三方工具链集成的LabVIEW VI来创建ANSI C代码。LabVIEW C生成器模块可兼容8位、16位和32位微处理器。
    LabVIEW编程平台编写的G语言程序,申请著作权必须转换为文本代码方式,而这个C代码生成器模块可以实现这个功能。不过,请注意目前只有2010、2011、2012、2013、2015、2017六个版本可供使用,请注意自已LabVIEW的版本。如果没有相应的C代码生成器,请使用保存为早期版本,以查找接近的LabVEIW版本或者是升级为可用的C代码生成器对应平台(LabVIEW2018、LabVIEW2019只能降级保存为早期版本)。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    NI下载器:
    请购买附件下载查看
    2015CGEN.txt (1.05 KB, 下载次数: 23, 售价: 10 圆)
    LabVIEW 2015 C Generator Readme
    Version 15.0.0
    June 2015
    This file contains important information about the LabVIEW C Generator, including installation instructions, a partial list of bugs fixed for the C Generator, and known issues.
    Lease Information
    The C Generator has the following requirements:
    • LabVIEW 2015 Full or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    Complete the following steps to install the C Generator.
    • Log in as an administrator or as a user with administrator privileges.
    • Install LabVIEW using the LabVIEW 2015 Platform media, if not already installed. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    • Insert the NI LabVIEW C Generator media. If the installer does not automatically begin, double-click autorun.exe on the media to begin installation.
    • Select Install NI LabVIEW C Generator.
    • Follow the instructions on the screen for installing the C Generator.
    • Activate the C Generator.
      The C Generator runs in evaluation mode if you do not activate it. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager or from NI Launcher in Windows 8, to activate NI products. Refer to the NI License Manager Help, available by selecting Help»Contents in the NI License Manager, for more information about activating NI products.
    Lease Information
    If you purchased a one-year lease of the C Generator, the C Generator will be deactivated one year after you activate the software. For information on purchasing a new lease, contact your local NI sales representative or visit ni.com/niglobal.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the C Generator.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the C Generator.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the C Generator are located in the labview\examples\CGenerator directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW C Generator Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI LabVIEW C Generator will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW C Generator that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2011–2015 National Instruments. All rights reserved.
    375439A-01
    发表于 2020-2-20 23:39:17 | 显示全部楼层 来自:河南省郑州市 移动
    GMT+8, 2025-12-8 07:36
