查看: 5761|回复: 0
[LV工具模块] NI Vision Development Module 8.2 Win32Eng 视觉开发模块VDM8.2版 适用LabVIEW8.2
    11 小时前
    发表于 2013-12-25 17:23:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    可用于LabVIEW8.2版的视觉模块。视觉论坛visionbbs.com专供。
    VDM8.2.txt (213 Bytes, 下载次数: 92, 售价: 100 圆)
    National Instruments Vision 8.2 Development Module
    Copyright 2006, National Instruments Corporation.
    All rights reserved.
    NI Vision 8.2 Development Module
    README.rtf contains the following sections:
    •        General Information
    •        How to Activate the NI Vision 8.2 License
    •        Using NI Vision 8.2 with Microsoft Visual Studio .NET 2003
    •        Known Issues
    General Information
    Installing this program may remove previous versions of IMAQ Vision for LabVIEW, IMAQ Vision for Measurement Studio, NI OCR, NI-IMAQ, and Measurement & Automation Explorer (MAX) that are currently installed.
    NI Vision 8.2 supports LabVIEW 7.1 or later, Visual Studio 6.0 or later, and LabWindows™/CVI™ 7.0 or later. The installer specifically allows side-by-side installations of NI Vision 8.2 for each of the supported versions of LabVIEW, enabling you to use the NI Vision 8.2 Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, or any other supported development environment, before installing the NI Vision 8.2 Development Module.
    NOTE: The NI Vision 8.2 Development Module overwrites existing NI-IMAQ examples, NI Vision examples, and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision 8.2 Development Module.
    For installation instructions and a complete list of system requirements, refer to the NI Vision 8.2 Development Module Release Notes.
    When you run an NI Vision 8.2 application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision 8.2 application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision 8.2 license through an Internet connection.
    1.        Run the product you want to license.
    2.        Click Yes when prompted to interactively activate your product.
    3.        Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    4.        Enter the product serial number, and click Next.
    5.        Enter your registration information, and click Next.
    TIP: Enter your email address to receive a copy of your activation code for your records.
    NI Vision 8.2 supports interoperability between the Vision 8.2 ActiveX control and Microsoft Visual Studio .NET 2003. NI Vision installs the following Interop Assemblies that allow .NET languages to correctly communicate with the ActiveX controls:
    •        NationalInstruments.AxCWIMAQControlsLib.Interop.dll—cwimaq.ocx
    •        NationalInstruments.AxCWIMAQHelpButton.Interop.dll—CWIMAQHlpBtn.ocx
    •        NationalInstruments.AxCWMV.Interop.dll—cwmv.ocx
    •        NationalInstruments.AxNIOCRLib.Interop.dll—niocr.ocx
    You can find these assemblies in the \dotNET\Assemblies\Current directory. The assemblies installed by NI Vision correctly wrap several methods that generate errors if you call the methods using the assemblies generated by Visual Studio .NET. For information about the properties, methods, and events available with these assemblies, refer to the NI Vision for Visual Basic Reference Help and the NI Vision for Visual Basic User Manual.
    Creating a New .NET Application using NI Vision 8.2
    You must first add the NI Vision controls to your toolbox when creating a new application. Complete the following steps to add the NI Vision controls to the Microsoft Visual Studio .NET 2003 Toolbox:
    1.        In Visual Studio .NET, either create a new application or open an existing one.
    2.        Open a form in Design View.
    3.        Select View»Toolbox.
    4.        Select the category in which you want the NI Vision controls to appear, such as General, Components, and so on.
    5.        Select Tools»Add/Remove Toolbox Items.
    6.        In the .NET Framework Components tab, select the controls you want to add to your application. Choose from CWIMAQ, CWIMAQVision, CWIMAQViewer, CWMachineVision, and NIOCR.
    When the controls are in the toolbox, you can add them to your forms by clicking the tool and drawing an area on the form. References to the NI Vision Interop Assemblies are automatically added to your project.
    Viewing the NI Vision 8.2 Examples
    The NI Vision examples for Microsoft Visual Studio .NET 2003 are converted from the NI Vision for Visual Basic examples. The .NET examples are written in Visual Basic .NET and demonstrate use of the NI Vision 8.2 Interop Assemblies. The examples are located in the \Examples\MSVB.NET directory, and the images for the examples are located in the \Examples\Images directory.
    Converting an Existing Microsoft Visual Basic 6.0 Application
    Microsoft's automatic upgrade engine often generates its own Interop assemblies rather than referencing the official NI Vision 8.2 Interop assemblies. When this happens, your project will have two references for every NI Vision assembly needed. Complete the following steps to correctly reference the NI Vision 8.2 Interop assemblies:
    1.        In Visual Studio .NET, select Edit»Find and Replace»Replace in Files.
    2.        Replace the following with NationalInstruments.CWIMAQControls:
            AxCWIMAQControlsLib
            AxCWIMAQHelpButtonLib
            AxCWMVLib
            AxNIOCRLib
    3.        Select View»Solution Explorer.
    4.        Expand the Project References.
    5.        Remove the following references if they are present:
            AxCWMV
            AxNIOCRLib
    •        AVI functionality requires Microsoft DirectX 8.1 or later.
    •        On Windows XP with Service Pack 2 installed, NI Vision 8.2 does not support reading AVI files located in the Local Settings folder, or any subfolders of this folder, when the AVI file uses any of the following compression filters:
            Indeo® Video 5.10 Compression Filter
            Intel Indeo® Video R3.2
            Intel Indeo® Video 4.5
            Indeo® Video 5.10
    Copying the AVI file to another folder resolves this problem.
    •        Viewing the online help files requires Microsoft Internet Explorer 5 or later.
    •        Using NI Vision 8.2 with LabWindows/CVI on a machine that does not support the MMX instruction set may cause an Illegal Operation exception to occur within the LabWindows/CVI environment. This error occurs when DirectX checks for the availability of the MMX instruction set on the machine.
    •        The Visual Basic .NET examples may display the UI controls with incorrect size and location settings if you use a computer with a DPI display setting other than 96 DPI. 96 DPI is the default setting for most Windows operating systems.
    •        NI Vision 8.2 does not support the use of Image Display control invoke nodes when using LabVIEW 7.0 Real-Time. The following examples use Image Display control Invoke nodes. Avoid downloading the following examples to a LabVIEW 7.0 Real-Time target.
            examples\Vision\2. Functions\Analysis\Histogram Example.vi
            examples\Vision\2. Functions\Analysis\LineProfile Example.vi
            examples\Vision\2. Functions\Calibration\Perspective Calibration Example.llb
            examples\Vision\2. Functions\Caliper\Clamp Example.vi
            examples\Vision\2. Functions\Caliper\Edge Detection Example.llb
            examples\Vision\2. Functions\Classification\Classification.vi
            examples\Vision\2. Functions\Color\Color Distance.llb
            examples\Vision\2. Functions\Color\ColorLearn Example.vi
            examples\Vision\2. Functions\Color Pattern Matching\Color Pattern Matching Example.llb
            examples\Vision\2. Functions\Grayscale Processing\MagicWand Example.vi
            examples\Vision\2. Functions\Image Management\Extract Example.vi
            examples\Vision\2. Functions\Image Management\ImageToArray Example.vi
    GMT+8, 2025-12-8 20:16
