查看: 19692|回复: 3
[LV工具模块] NI Vision Development Module 2018 Win32/64Eng 视觉开发模块VDM2018 适用LabVIEW2018
    昨天 10:57
  • 签到天数: 3732 天
    连续签到: 59 天
     楼主| 发表于 2018-5-5 17:14:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2018年3月发布。适用LabVIEW 2018 32/64版本。
    支持操作系统:
    Windows 10(1709版)/8.1 Update 1/7 SP1
    Windows Server 2012 R2
    Windows Server 2008 R2 SP1
    即要求最低WIN7SP1,对于WIN7、WIN VISTA、WIN XP已经不再支持。
    新功能:重点改进了模式匹配和几何匹配,以及增加了深度学习功能。
    文件大小: 2615408014 字节 (2.44 GB)
    修改日期: 2018-05-05 15:16
    MD5: b9741ef7140945b267f99636a8651ba8
    SHA1: 2f796dad759adac593d8b44650d8270bb4c7e7ac
    SHA256: 165a07733cf5d356dd76a79515840e8c85a637cf45002be8f311e25cdd1c520e
    CRC32: 2da83bae
    请注册视觉论坛会员登录后购买附件下载查看
    VDM2018.txt (285 Bytes, 下载次数: 156, 售价: 10 圆)
    NI Vision Development Module 2018 Readme
    March 2018
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    External Library Support
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    The NI Vision Development Module (VDM) provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/labview/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display (Vision Assistant)1,152 × 864 resolution video adapter with a 16-bit display1,152 × 864 resolution video adapter with a 24- or 32-bit display
    Display (other environments)1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    NI Vision Development Module 2018 supports the following operating systems:
    • Windows 10 (32- and 64-bit)
    • Windows 10 IoT Enterprise (64-bit)3
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Embedded Standard 7 SP1(32- and 64-bit)2,3
    Note: In 2016 NI Vision Development Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Development Module 2018 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Development Module 2018 to an unsupported OS. Additionally, after installing NI Vision Development Module 2018, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note: Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
    3Only supported as pre-installed on NI hardware.
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI LabVIEW
    2015, 2016, 2017, 2018
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabWindows™/CVI™
    2012, 2013, 2015, 2017
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    NI Vision Development Module FPGA Support
    For more information and the complete list of Vision functions and hardware supported on FPGA, visit ni.com/info and enter the Info Code VisionFPGASupport.
    The NI Vision Development Module supports the external vision library OpenCV. Refer to the National Instruments Web site to download the NI Vision OpenCV support utilities.
    NI Vision OpenCV support utilities enable the use of OpenCV algorithms in LabVIEW and NI Embedded hardware. NI Vision OpenCV support utilities provide:
    • Pre-built OpenCV binaries for Windows and NI Linux RT
    • C++ development files to create an interface between NI Vision Image and OpenCV Mat.
    • Utilities to create LabVIEW APIs to call OpenCV entry points
    • LabVIEW examples
    New Features in Vision Development Module 2018
    The 2018 release of the Vision Development Module includes the following new features:
    • Support for LabVIEW 2018 (32- and 64-bit)
    • Pattern Matching (PM) Improvements:
      • Improved robustness and performance for learning and matching by improving optimal pyramid level
      • Improved match reliability for images with Symmetrical Parts
      • Added Pyramid - PreProcess Learn Advanced Parameter to allow pre-processing of noisy and low contrast images for improved templates
      • Added Pyramid - Enable Target to Template Score Advanced Match Parameter to allow for improved match scores
      • Updated Pyramid - Initial Match List Length Advanced Match Parameter to automatically estimate size, leading to improved match performance for varied number of matches
      • Updated Pyramid - Max Cache in MB Advanced Match Parameter to automatically estimate cache size, leading to improved match performance for varied image sizes
      • Updated Versions: IMAQ Match Pattern 4, IMAQ Learn Pattern 6
    • Geometric Pattern Matching (GPM) Improvements
      • Improved match accuracy for Large Templates (~1024x1024) and Symmetrical Parts
      • Improved match reliability and robustness for detecting Small Parts
      • GPM 16-bit support
      • Defect Map Support for GPM (IMAQ Calculate Defect Map)
        • Added parameter Enable Defect Map to use the Defect Map feature in GPM. This is found in the Advanced Geometric Match Options 2 parameter in IMAQ Advanced Setup Match Geometric Pattern 2.
      • Updated Versions: IMAQ Learn Geometric Pattern 3, IMAQ Match Geometric Pattern 2
    • Presets for Pattern Matching and Geometric Pattern Matching
      • Pre-defined known-good sets of options for different match requirements
      • New: IMAQ Set Preset Match Options, IMAQ Set Advanced Match Options
    • Deep Learning Support:
      • New Model Importer APIs (under Machine Learning -> Deep Learning) to import pre-trained TensorFlow Models into LabVIEW and run inference on NI hardware targets
      • Support for TensorFlow within LabVIEW
      • Supported Development Environment: LabVIEW 64 bit
      • Supported NI HW Targets: NI Linux RT 64 bit based hardware
    • Vision FPGA
      • IMAQ AutoBThreshold2 (Interclass Variance/Otsu Method) FPGA IP
      • Optimized Particle Analysis (x8) IP
    • Vision Assistant
      • Merged Pattern Matching (PM) and Geometric Pattern Matching (GPM) Steps
      • Updated UI with new look and feel
      • Support for PM and GPM Presets
      • Support for GPM in Defect Map
      • Support for AutoBThreshold for FPGA
      • Support for Modified Sauvola for FPGA
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    Installation InstructionsInstalling from the LabVIEW Platform Suite
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform Suite.
    To request additional LabVIEW Platform Suite, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Enter the product serial number, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Runtime directly from the NI Vision Development Module installation media.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the runtime installer for NI Vision. The runtime installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Runtime License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Runtime directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Runtime licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Runtime
    You can call the NI Vision Runtime installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Runtime installer.
    You can also direct a custom application installer to call the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Runtime installer at the end of the installation procedure because the installer may require the system to be restarted.
    To call the NI Vision Runtime installer silently (non-interactively), you must add /q /AcceptLicenses yes as command line arguments to the runtime installer. For example, enter \Run-Time Engine\visionrte.exe /q /AcceptLicenses yes, where is the location to which NI Vision is installed, and is the version number of the NI Vision Runtime installed. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    The NI Vision Runtime installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Runtime as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Runtime.
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    Documentation and examples are installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    NI Vision for LabVIEW
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»All Programs»National Instruments»Vision»Documentation»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»All Programs»National Instruments»Vision»Examples»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    The following sections detail considerations for using NI Vision Development Module with LabVIEW NXG.
    LabVIEW NXG Operating Systems and Requirements
    • Operating system—Only 64-bit operating systems are supported.
    Note: Refer to the LabVIEW NXG Readme for additional system requirements.
    Changes in VDM Supported in LabVIEW NXG
    For information about VDM support in LabVIEW NXG, visit ni.com/info and enter the Info Code VisionNXGGuide.
    Installing Vision Development Module for LabVIEW NXG
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install Vision Development Module for LabVIEW NXG.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, then automatically opens an installation window.
    • Select LabVIEW NXG 2.1 and NI Vision Development Module 2018.
    • Complete the installer instructions to download LabVIEW NXG and Vision Development Module support for LabVIEW NXG.
    LabVIEW NXG Help
    View context help in LabVIEW by pressing Ctrl+H and hovering over an object.
    LabVIEW NXG Examples
    © 2003-2018 National Instruments. All rights reserved.
    375127H-01
  • 签到天数: 44 天
    发表于 2018-5-13 12:05:52 | 显示全部楼层 来自:浙江省宁波市宁海县 电信
    发表于 2020-12-30 14:28:26 | 显示全部楼层 来自:江苏省苏州市 电信
  • 签到天数: 7 天
    发表于 2021-3-20 10:30:41 | 显示全部楼层 来自:广东省东莞市 移动
    GMT+8, 2025-12-5 05:44
