查看: 9755|回复: 1
[LabVIEW] NI LabVIEW 2018 Win64Eng 64位LV2018英文版下载
    昨天 16:03
     楼主| 发表于 2018-5-10 13:03:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2018年3月发布。64位LabVIEW,没有中文版等非英语版本。
    支持操作系统:
    Windows 10(1709版)/8.1 Update 1/7 SP1
    Windows Server 2012 R2
    Windows Server 2008 R2 SP1
    即要求最低WIN7SP1,对于WIN7、WIN VISTA、WIN XP已经不再支持。
    请注册视觉论坛会员登录后购买附件下载查看
    LV2018ENG64.txt (622 Bytes, 下载次数: 109, 售价: 10 圆)
    LabVIEW 2018 Readme for Windows
    March 2018
    This file contains important information about LabVIEW 2018 for Windows, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2018.
    LabVIEW 2018 (64-bit)
    Additions to the LabVIEW Help
    LabVIEW 2018 has the following requirements:
    Operating SystemWindows 10 (version 1709)/8.1 Update 12/7 SP13
    Windows Server 2012 R22
    Windows Server 2008 R2 SP13
    1 LabVIEW and LabVIEW Run-Time Engine require processors of the Pentium 4M/G1 generation or later, which are capable of executing SSE2 instructions.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    • In 2016 LabVIEW dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2018 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2018 to an unsupported OS. Additionally, after installing LabVIEW 2018, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    Complete the following steps to install and activate LabVIEW for Windows.
    Are you installing LabVIEW for the first time? Insert the LabVIEW Platform media and follow the onscreen instructions to install LabVIEW, modules, toolkits, and drivers. When prompted, enter the serial number for each product you want to activate. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    Are you upgrading from a previous version of LabVIEW? Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2018.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2018 (32-bit) and LabVIEW 2018 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2018 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2018 (64-bit) supports a limited number of modules and toolkits. The following lists compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ProductLabVIEW 2018 (32-bit)LabVIEW 2018 (64-bit)
    ✓1
    Database Connectivity Toolkit
    DataFinder Toolkit
    Digital Filter Design Toolkit
    FPGA Module
    MathScript RT Module
    ✓2
    Real-Time Module
    Robotics Module
    SoftMotion Module
    Statechart Module
    Sound and Vibration Measurement Suite
    Unit Test Framework Toolkit
    VI Analyzer Toolkit
    Vision Development Module
    2 The MathScript RT Module (64-bit) does not support the libraries class of MathScript RT Module functions.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2018.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2018. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    457851Bundling class data is slower than bundling cluster data.
    536763Pop-up menus can appear only limited number of times before LabVIEW crashes.
    619819Icon transparency of VIs is not maintained when building a packed project library.
    629258In some cases, reading from a corrupt TDMS file deletes the file from your machine.
    630227LabVIEW incorrectly allows dropping a shared variable into a cluster.
    631802Exporting typedef array of numerics to Excel may crash LabVIEW.
    639000LabVIEW crashes when updating the radix of a numeric control on an Actor Core VI that is running.
    643107Changing the line styles of multiple plots does not work as expecting in XY graphs.
    645059Uninitialized shift registers may cause incorrect type propagation.
    648582Cannot create Express VIs in certain localized versions of LabVIEW.
    658587Rescripting a message for an actor on a Linux RT target results in error 7.
    664649Accessing a DVR and deleting its reference in parallel can, in certain circumstances, cause LabVIEW to crash.
    666823VIs that use channel wires are broken when built into a packed project library.
    670440When dynamically registering events, LabVIEW may behave unexpectedly if an event is fired and unregistered before it is processed.
    671753The LabVIEW Application Builder has the potential to hang when building malleable VIs with subarray or substring inputs.
    672120Malleable VIs may not properly break after you rename a class method that the mallable VI calls when performing class substitution.
    678973Tools»Synchronize with ni.com Icon Library fails in the LabVIEW Icon Editor.
    684125In some cases, resizing a mixed signal graph causes LabVIEW to crash.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2018.
    • The Python functions use the new PythonSessionRefnum refnum. This refnum is added to the enum type control at labview\vi.lib\Utility\Data Type\Type Definitions\Refnum Type.ctl. If you use VI Scripting that checks this type control, you must update your code to handle the new refnum.
    © 2004–2018 National Instruments. All rights reserved.
    374715J-01
    GMT+8, 2026-2-24 20:50
