查看: 10241|回复: 1
[LV工具模块] LabVIEW Report Generation Toolkit for Microsoft Office 2018 for LabVIEW 2018 Win32ENG 报表工具包RGT2018 适用LabVIEW2018 X86版本
    昨天 16:03
     楼主| 发表于 2018-5-10 13:13:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
    百度网盘下载地址和NI官方下载地址:
    请注册视觉论坛用户,登录后购买附件下载查看
    RGT2018.txt (481 Bytes, 下载次数: 56, 售价: 10 圆)
    LabVIEW 2018 Report Generation Toolkit for Microsoft Office Readme
    2018
    Version 18.0.0
    May 2018
    This file contains important information about the Report Generation Toolkit for Microsoft Office, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2018 Report Generation Toolkit for Microsoft Office, and known issues.
    System Requirements for the 32-Bit Version
    System Requirements for the 64-Bit Version
    Automatic Installation of NI Products
    The LabVIEW Report Generation Toolkit for Microsoft Office provides VIs you can use to create and edit reports in Microsoft Word and Microsoft Excel formats. You can use the Report Generation VIs to perform the following tasks:
    • Create and edit Word documents and Excel worksheets.
    • Use Word and Excel templates to create reports with a consistent style.
    • Insert, format, and edit text, tables, images, and graphs within Word documents and Excel worksheets.
    • Run Microsoft Visual Basic for Applications macros from Word documents and Excel worksheets.
    In addition to the system requirements for the LabVIEW Development System, the 32-bit version of Report Generation Toolkit for Microsoft Office has the following requirements:
    • Windows 10/8.1 (32-bit and 64-bit)1/7 SP1 (32-bit and 64-bit)2
    • Windows Server 2012 R21
    • LabVIEW 2018 Base, Full, or Professional Development System (32-bit)
    • At least 40 MB of disk space
    • Microsoft Office 2016/2013/2010/2007/2003/XP (32-bit) (Microsoft Office 2013 is also included in Microsoft Office 365)
      Note:  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    In addition to the system requirements for the LabVIEW Development System, the 64-bit version of Report Generation Toolkit for Microsoft Office has the following requirements:
    • Windows 10/8.1 (64-bit)1/7 SP1 (64-bit)2
    • LabVIEW 2018 Base, Full, or Professional Development System (64-bit)
    • Microsoft Office 2016/2013/2010/2007/2003 (32-bit) (Microsoft Office 2013 is also included in Microsoft Office 365)
    In 2016 Report Generation Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Report Generation Toolkit 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Report Generation Toolkit 2018 to an unsupported OS. Additionally, after installing Report Generation Toolkit 2018, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2018, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    • LabVIEW 2018 and later no longer supports generating reports in the Standard Report format.
    • LabVIEW 2018 crashes in an executable with Report Generation Toolkit when using the "Save Report to File" VI. For more information, refer to the KnowledgeBase article LabVIEW Crash in Executable with Report Generation Toolkit at Save Report to File VI.
    Visit ni.com/security to view and subscribe in order to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    • Refer to KB 4CJDP38M, Customize and Automate Installation of a Single Installer for more information on automatic installations of individual NI products.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate Installation of a Suited Installer.
    • Refer to KB 4CJDR18M, Determine Type and Version of My National Instruments Installer for a description of the version of the NI Installer your product contains.
    The following items are the IDs and titles of a subset of issues fixed in the Report Generation Toolkit for Microsoft Office. This is not an exhaustive list of issues fixed in the current version of the Report Generation Toolkit for Microsoft Office. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    249185Unable to create report from Macro-enabled Word or Excel template (.dotm and .xltm file).
    463584Append Horizontal Line to Report VI generates incorrect HTML code with width units in percent and decimal separator set to ",".
    598515The default format in Excel Easy Table (num).vi is changed from "%.f3" to "%.; %_13g" to preserve precision and avoid problems on Systems with "," as decimal separator.
    626944Excel_Save_Workbook.vi is broken and needs to be relinked with some versions of office 2016.
    631802When using the right-click menu option to export a non-empty, typedef numeric array's data to Excel, LabVIEW will crash.
    To find information on the compatibility of earlier versions refer to ni.com/support under the search term "LabVIEW Report Generation Toolkit for Microsoft Office Readme".
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Report Generation Toolkit for Microsoft Office.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Report Generation Toolkit for Microsoft Office are located in the labview\examples\office directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Microsoft Windows 10 is the latest version of the Windows operating system. Windows 10 features significant changes compared to previous versions. Windows 10 combines features from both Windows 7 and Windows 8. Moreover, the operating system introduces several new capabilities. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2009–2018 National Instruments. All rights reserved.
    375405D-01
  • 签到天数: 1 天
    发表于 2022-12-23 19:40:22 | 显示全部楼层 来自:河北省廊坊市 电信
    特价工业相机、机器视觉光源、工业镜头、机器视觉教程,就到机器视觉商城
    GMT+8, 2026-2-24 22:15
