查看: 12022|回复: 0
[LV工具模块] NI Vision Development Module 2018 SP1 Win32/64Eng 视觉开发模块VDM2018SP1 适用LabVIEW2018SP1
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2018-12-5 11:39:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2018年10月22日发布。适用LabVIEW 2018SP1 32/64位中英文等多国语言版本。
    文件大小: 2877302256 字节 (2.68 GB)
    修改日期: 2018-12-05 09:31
    MD5: b12891ca8440a3dd8271898cb6c2e791
    SHA1: 9ab51f9f3fa71a45152d54ea85d0a0900d47afce
    SHA256: bb1acc7b6485e784ba71fee6509c7936f109eb99e65378cae8e91c62b11fb2c6
    CRC32: 032ce55a
    请注册视觉论坛会员登录后购买附件下载查看
    VDM2018SP1.txt (212 Bytes, 下载次数: 157, 售价: 10 圆)
    支持操作系统:
    • Windows 10 (32- and 64-bit)
    • Windows 10 IoT Enterprise (64-bit)
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)
    • Windows Embedded Standard 7 SP1(32- and 64-bit)
    • Windows Server 2008 R2 SP1 (64-bit)
    即要求最低WIN7SP1且要更新对SHA-256数字签名的支持,对于WIN7、WIN VISTA、WIN XP已经不再支持。
    更多信息请阅读以下自述文件:
    NI Vision Development Module 2018 SP1 Readme
    November 2018
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    External Library Support
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    NXG Support and Considerations
    The NI Vision Development Module (VDM) provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com//vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display (Vision Assistant)1,152 × 864 resolution video adapter with a 16-bit display1,152 × 864 resolution video adapter with a 24- or 32-bit display
    Display (other environments)1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    NI Vision Development Module 2018 SP1 supports the following operating systems:
    • Windows 10 IoT Enterprise (64-bit)3
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Embedded Standard 7 SP1(32- and 64-bit)2,3
    Note: In 2016 NI Vision Development Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Development Module 2018 SP1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Development Module 2018 SP1 to an unsupported OS. Additionally, after installing NI Vision Development Module 2018 SP1, you cannot use any installers built on this computer with any version of , LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my , LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note: Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
    3Only supported as pre-installed on NI hardware.
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of , enabling you to use the NI Vision Development Module with multiple versions of . National Instruments recommends that you install ,  Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI
    2015, 2016, 2017, 2018
    NI  Real-Time Module
    NI  FPGA Module
    NI LabWindows™/CVI™
    2012, 2013, 2015, 2017
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    NI Vision Development Module FPGA Support
    For more information and the complete list of Vision functions and hardware supported on FPGA, visit ni.com/info and enter the Info Code VisionFPGASupport.
    The NI Vision Development Module supports the external vision library OpenCV. Refer to the National Instruments Web site to download the NI Vision OpenCV support utilities.
    NI Vision OpenCV support utilities enable the use of OpenCV algorithms in  and NI Embedded hardware. NI Vision OpenCV support utilities provide:
    • Pre-built OpenCV binaries for Windows and NI Linux RT
    • C++ development files to create an interface between NI Vision Image and OpenCV Mat.
    • Utilities to create  APIs to call OpenCV entry points
    • examples
    New Features in Vision Development Module 2018 SP1
    The 2018 SP1 release of the Vision Development Module includes the following new features:
    • Support for  2018 SP1 (32- and 64-bit)
    • Deep Learning: Model Importer Updates:
      • New TensorFlow version 1.8 support
      • Optimized TensorFlow libraries for better inference performance
      • New Model Importer Example
    • Pattern Matching Auto Crop for improving template creation.
    • Image display:
      • Overlay Improvements:
        • Programmatically update color for group of Overlays (supports text & shape overlays)
        • New IMAQ SetOverlayColor API
      • Zoom to Fit ( supported on LV NXG only)
        • This tool on the display control allows user to select a subsection and zoom to fit with a single click
    • New APIs:
      • IMAQ Cast Image 2: New method input
      • IMAQ Copy Vision Info
      • IMAQ Find Straight Edges 4 & IMAQ Find Edges 2
    • Updated APIs:
      • IMAQ Copy Vision Info:
      • IMAQ Find Straight Edges 4:
      • IMAQ Find Edges 2:
    • Vision Assistant:
      • Parameters Presets support in Map Defects step
      • FPGA: Color BCG Lookup and x8 Nth Order Filter
    • Vision FPGA - New IPs:
      • IMAQ FPGA ColorBCGLoookup for RGB supports x1 and x8 processing
      • ROI support is added for AutoBThreshold
      • x8 processing is supported for IMAQ FPGA Nth Order filter
    • NI Package Manager installation of development support:
      • NI Vision APIs for  and C/C++ environments
      • Vision Assistant application and code generation for  and C/C++ environments
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    Installation InstructionsInstalling from the  Platform Suite
    If you purchased , you can install all of your  products—including the NI Vision Development Module—using the  Platform Suite.
    To request additional  Platform Suite, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Enter the product serial number, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the  Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Runtime directly from the NI Vision Development Module installation media.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the runtime installer for NI Vision. The runtime installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Runtime License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Runtime directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Runtime licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Runtime
    You can call the NI Vision Runtime installer from the application installer. If you create the application installer with the  Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Runtime installer.
    Refer to the Help for more information about the  Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can also direct a custom application installer to call the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Runtime installer at the end of the installation procedure because the installer may require the system to be restarted.
    To call the NI Vision Runtime installer silently (non-interactively), you must add /q /AcceptLicenses yes as command line arguments to the runtime installer. For example, enter \Run-Time Engine\visionrte.exe /q /AcceptLicenses yes, where is the location to which NI Vision is installed, and is the version number of the NI Vision Runtime installed. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    Distributing  Applications
    The NI Vision Runtime installer does not install  VIs. If you use the  Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate  Runtime as part of the installation.
    Refer to the Help for more information about viewing the hierarchy of VIs and for more information about using the  Runtime.
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    Documentation and examples are installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    NI Vision for
    • NI Vision for  Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with . It describes how to create machine vision and image processing applications in . It also describes how to create a real-time vision application using NI Vision and the  Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the  FPGA Module. You can access this help in  by selecting Help»NI Vision for  Help.
    • NI Vision for  Examples—Illustrates common applications you can create with NI Vision. In , select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for  are installed to <>\examples\Vision FPGA, where <> is the location  is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»All Programs»National Instruments»Vision»Documentation»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»All Programs»National Instruments»Vision»Examples»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI , Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    The following sections detail considerations for using NI Vision Development Module with  NXG.
    NXG Operating Systems and Requirements
    Software support for  NXG differs in the following ways:
    • Operating system—Only 64-bit operating systems are supported.
    Note: Refer to the NXG Readme for additional system requirements.
    Changes in VDM Supported in  NXG
    For information about VDM support in  NXG, visit ni.com/info and enter the Info Code VisionNXGGuide.
    Installing Vision Development Module for  NXG
    NXG is installed using NI Package Manager. Complete the following steps to install Vision Development Module for  NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the  NXG download page.
    • Click Download  NXG.
    • NI Package Manager installs, then automatically opens an installation window.
    • Select NXG 3.0 and NI Vision Development Module 2018 SP1.
    • Complete the installer instructions to download  NXG and Vision Development Module support for  NXG.
    NXG Help
    View context help in  by pressing Ctrl+H and hovering over an object.
    Search for items using the search bar in the upper right corner of the  window. You can also view context help for the search results.
    NXG Examples
    Launch  and click the Learning tab.
    lessons are located in the Lessons tab, and  Examples are located in the Examples tab. Follow the instructions in the lessons and examples.
    © 2003-2018 National Instruments. All rights reserved.
    375127J-01
    GMT+8, 2025-12-5 13:21
