查看: 4636|回复: 1
[LabVIEW] NI LabVIEW2009SP1 Win64ENG LV2009SP1英语64位版下载
    4 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2019-1-17 14:37:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    LV2009SP1ENG64.txt (315 Bytes, 下载次数: 101, 售价: 10 圆)
    LabVIEW 2009 Service Pack 1 Readme for Windows
    Version 9.0.1
    December 2009
    This file contains important last-minute information about LabVIEW 2009 Service Pack 1 (SP1) for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed for LabVIEW 2009 SP1, changes from LabVIEW 2009, and a link to the Web page that contains known issues for LabVIEW. Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and a complete list of new features in LabVIEW 2009 and related service packs. Refer to the LabVIEW Release Notes for installation instructions and a complete list of system requirements. After you install LabVIEW, refer to the labview\manuals directory to access these documents. You also can access the LabVIEW Release Notes and LabVIEW Upgrade Notes at ni.com.
    Refer to the National Instruments Web site for the latest information about LabVIEW 2009 SP1.
    Installing LabVIEW 2009 SP1
    Installing Another Language Version
    Licensing
    LabVIEW 2009 SP1 (64-bit)
    Additions to the LabVIEW Help
    Recompiling VIs for Bug Fixes
    If you have LabVIEW 2009 installed, you can install LabVIEW 2009 SP1 without uninstalling LabVIEW 2009. Note: Because LabVIEW installs LabVIEW 2009 SP1 over LabVIEW 2009, you cannot have both LabVIEW 2009 and LabVIEW 2009 SP1 installed simultaneously.
    If you do not have LabVIEW 2009 installed, you can install LabVIEW 2009 SP1 without first installing LabVIEW 2009.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW on Windows.
    If you have installed another language version of LabVIEW 2009 SP1, uninstall that version before you install the new language version.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate the license, use the serial number you received as part of your installation package. If you upgrade to LabVIEW 2009 SP1 from LabVIEW 2009, use your existing LabVIEW 2009 serial number during installation.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW 2009 and related service packs.
    Windows 7 Issues
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the info code windows7.
    LabVIEW 2009 SP1 is available in a 64-bit version of the LabVIEW Development System. When run on Windows Vista (64-bit version), LabVIEW 2009 SP1 (64-bit) provides access to more memory than either a 32-bit operating system or a 32-bit application can provide. LabVIEW 2009 SP1 (64-bit) includes nearly all of the development environment features of LabVIEW 2009 SP1 (32-bit), including the LabVIEW Application Builder.
    Refer to the National Instruments Web site for information about obtaining a copy of LabVIEW 2009 SP1 (64-bit).
    LabVIEW 2009 SP1 (64-bit) supports many hardware devices. Drivers are available for DAQ devices, VISA devices, GPIB devices, and image acquisition devices. For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2009 SP1 (64-bit).
    Supported Modules
    LabVIEW 2009 SP1 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. LabVIEW 2009 SP1 (64-bit) does not support any additional add-ons.
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help:
    • LabVIEW 2009 SP1 supports the Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit) editions. LabVIEW does not support the Windows Server non-R2 editions.
    • When you open a VI snippet .png file, LabVIEW 2009 SP1 displays the version of LabVIEW in which the VI snippet was saved in the upper right-hand corner of the image. To use the code of a VI snippet, the version of LabVIEW you are running must be the same as or later than the version of LabVIEW in which the VI snippet was saved.
    • You can configure LabVIEW 2009 SP1 to open each probe in its own window in addition to opening each probe in the Probe Watch Window. Refer to the Knowledge Base on ni.com for more information about opening individual probe windows.
    • In LabVIEW 8.6.x and earlier, you can define custom error codes in the range of –8999 through –8000 and 5000 through 9999. In LabVIEW 2009 and related service packs, you also can define custom error codes in the range of 500,000 through 599,999.
    • LabVIEW 2009 and related service packs include changes to the following VIs:
      • The mse output of the General Polynomial Fit VI and the General Linear Fit VI is renamed residue. The General Linear Fit VI also includes the covariance selector input that indicates whether the VI computes the covariance matrix.
      • The algorithm input of the General Polynomial Fit VI changed from a 32-bit unsigned enumerated data type to a 16-bit unsigned numeric data type.
      • The filter type input of the Bessel Filter PtByPt VI, Butterworth Filter PtByPt VI, Chebyshev Filter PtByPt VI, Elliptic Filter PtByPt VI, and Inverse Chebyshev Filter PtByPt VI changed from a 16-bit unsigned enumerated data type to a 32-bit unsigned enumerated data type.
      • The section and refnum inputs of the Get Key Names VI, the refnum input of the Get Section Names VI, and the refnum input of the Not a Config Data Refnum VI are required inputs.
      • The path input of the Get LV Class Default Value VI is renamed class path.
      • The class data output of the Get LV Class Default Value VI is renamed object.
      • The lv object output of the Get LV Class Path VI is renamed object.
    • LabVIEW 2009 and related service packs include the following miscellaneous VI behavior changes:
      • The Exponential Fit VI was rewritten with one new input and one changed input. Replace versions of this VI from previous versions of LabVIEW with an Exponential Fit VI from the Functions palette to use the new functionality.
      • The Gaussian Peak Fit VI was rewritten with two new inputs in LabVIEW 2009 and later. Replace versions of this VI from previous versions of LabVIEW with a Gaussian Peak Fit VI from the Functions palette to use the new functionality.
      • The Open Config Data VI was rewritten with one new input. Replace versions of this VI from previous versions of LabVIEW with an Open Config Data VI from the Functions palette to use the new functionality.
    • On the Pie Graph and Bar Graph, the Add, Delete, Up, and Down buttons are disabled.
    • In LabVIEW 8.6 and earlier, the user locale determines the font script. In LabVIEW 2009 and related service packs, the system locale determines the font script. To change the system locale, open the Windows Control Panel, double-click Regional and Language Options, click the Advanced tab of the Regional and Language Options dialog box, and select the language from the pull-down menu that correponds to the encoding you want to display in LabVIEW. After you select the language, you must restart the system.
    The following table contains the IDs and titles of a subset of issues fixed between LabVIEW 2009 and LabVIEW 2009 SP1. This table is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed. Refer to the National Instruments Web site to view a list of issues fixed in LabVIEW 2009.
    IDLegacy IDFixed Issue
    932964FSGQ6C4Terminal information is not being passed correctly
    122321-Mixed Signal Graph does not resize plot legend when in executable
    145796-Choose implementation dialog does not bring-to-front VIs which are already open but hidden
    158487-Application Builder errors when building file with a slash in the file name
    160585-Error message when path is too long in building an application
    162215-Cannot change RT FIFO from multiple variable editor
    171913-3D Graph Surface Plot Color Matrix Yields Colorless Surface
    173068-Error when trying to drop things from the HTML help
    174619-Open and Closing VIs with variables leak about 50-200 KB of memory
    175643-Deployment dialog display on built application
    175788-Measurement & Automation Explorer (MAX) could not be launched from LabVIEW on Windows 2000
    175997-3D Comet Plot does not show the animation and static plot in application with default build settings
    176266-Plot of Waveform Graph cannot be renamed in property page if input terminal is wired
    176379-Crash when fixed point number is wired to a case structure
    176597-Get/Set Control Value and Run VI Methods fail when used with a strict VI reference to a reentrant VI
    176834-Inserting a feedback node on a wire drops corrupted feed forward node
    176860-Terminals property of feedback node doesn't include the enable terminal
    177230-Weather Monitor example readme file is corrupted for French
    177239-LabVIEW crashes when a VI tries to deploy its parent library programmatically
    178232-Block Diagram Clean Up may break VI when cleaning up large VIs
    178234-Data Value References wires do not coerce
    178313-VI hierarchy shows tip strip with old (library-qualified) name when VI is removed from the library
    178614-Type defined constant can lose value when updating to edited typedef if feedback node also on diagram
    179002-Changing variable container property node causes LabVIEW to crash
    179140-LabVIEW hangs when trying to restoring the topmost windows
    179375-LabVIEW crashes when using "To Variant" with Single Process variable
    179472-The Write to Measurement File Express VI cannot be set to "Save to series of files"
    179677-Dependency conflicts for internal VIs in stored in vi.lib may appear when upgrading projects
    179711-Web Service palette VI reads incorrectly
    179854-Invalid variable configuration when opening variable properties
    180451-Application builder UI hangs
    181098-Call Library Node with unwired Error Out no longer puts up error dialog
    181478-A class dynamically loaded into a running framework which statically loads its own child may not reserve the child's VIs correctly
    181495-Nested parallel FOR loops are not completely parallel
    182053-Custom About screen not displayed with a LabVIEW built application
    182414-Memory leak when probing an error cluster in a while loop
    182420-LabVIEW hangs when using highlight execution with more that 17 I/O Variables
    182771-Open VI Reference using strictly typed constant results in 1031 error
    182831-LLBs are not detected in project when located in auto-populating folders
    182844-Tab Controls don't save Default Visible Tab
    182865-VI Crashes on load if Call by Reference Node Statically Configured to a VI and has a Reference Out wired
    182961-New value node in timeout event structure
    182990-LabVIEW crashes when changing shared variable property
    183005-Save for Previous to 8.5 or older will crash if VI contains an event structure
    183239-LabVIEW crashes when adding a folder to project
    183560-Graph does not display timestamps on X-axis as expected when using timestamp data type
    183837-Type uintptr_t * cannot be built into a shared library (DLL)
    183972-Conflict message when main VI in project opens
    184040-Not a refnum constant wired to a mouse down event causes compile error
    184077-LabVIEW Load Error Code 3: Could Not Load Front Panel When Opening a VI in the Development Environment
    184463-Open VI Reference cannot recognize type when upgraded to LabVIEW 2009
    184557-User defined refnums are improperly grouped
    185219-Error 1502 while building a LabVIEW application
    185348-VIs with large data types (like the Enum) will crash on load after being saved in LabVIEW 2009
    185812-Crash when saving for previous version
    185867-Aggregate comparator causes LabVIEW to crash
    185980-Editing An Event Structure With A String Event Might Crash Localized Versions Of LabVIEW 2009
    186211-LabVIEW crashes when saving for previous version
    186276-Certain references (NI SoftMotion, WSN...) may incorrectly refer to data associated with a different reference
    186392-Cannot Save sparse rings with unit labels in LabVIEW 2009
    186404-Default values lost when upgrading from LabVIEW 7.1
    186418-Image Display control does not update using Value property node in a LabVIEW built application
    186602-Application Builder uses too much memory, which may result in build failures
    187349-Subtract output is wrong when coercing values to I64 or U64
    187427-Open and Close VI Reference take very long time when large project opened
    187457-Visible VI options in Web Server options of LabVIEW disabled.
    187493-Wrong behavior for some VIs in XML.lvlib
    187670-LabVIEW leaks memory when certain VIs in the NI_AALPro.lvlib are called using VI Server
    187759-Cannot launch LabVIEW 2009 when using Microsoft Mandatory User Profiles
    188140-Parallel port examples unusable in localized environment
    188425-.mnu files with same name conflict even if they have different namespaces.
    188669-Datalog Files Created in LabVIEW 2009 Cannot Be Opened in LabVIEW 8.6.x
    189527-LabVIEW crashes when using some ProjectIems property
    189548-LabVIEW Interop assembly cannot use cluster arrays properly
    189649-LabVIEW crashes when Open Application Reference uses IP Address and Open VI reference has empty path input
    189820-Clicking the ReadMe link from the autorun installation dialog will fail to open the html file in Internet Explorer 8
    190472-Opening large project crashes LabVIEW
    190703-LabVIEW can leak memory when the Extract Single Tone Information 1 Chan.vi is called using VI Server
    190704-LabVIEW Configuration File VIs leak memory when called using VI Server
    190705-LabVIEW can leak memory when the Error Cluster From Error Code.vi is called using VI Server
    190758-LabVIEW can leak memory when repeatedly opening a VI reference
    191404-LabVIEW fails to compile if decimate 1D array.vi is used with string arrays
    191413-gemv - General Matrix - Vector Product.vi in LabVIEW 2009 Produces incorrect result when run within a loop
    191814-Crash when loading LabVIEW runtime from NI TestStand
    191830-Not all probes work if multiple windows are open
    192167-Using Cast Unit Bases and Convert Unit VI with Array Subset VI gives compile error
    192480-Digital Graph legend does not scale properly
    192579-LabVIEW 7.1 Storage VIs can no longer overwrite TDM file bulk data after installation of LabVIEW 2009
    192667-Common subexpression elimination combines fixed-point arithmetic incorrectly in VIs with debugging disabled
    194522-Digital Waveform with empty data can crash LabVIEW
    195627-Information returned from a subVI is not consistent in LabVIEW 2009
    The following fixes require you to manually recompile VIs to correct the problem:
    • 179375—LabVIEW crashes when using To Variant with Single Process variable
    • 181098—Call Library Node with unwired Error Out no longer puts up error dialog
    • 184557—User defined refnums are improperly grouped
    • 186276—Certain references (NI SoftMotion, WSN...) may incorrectly refer to data associated with a different reference
    • 187349—Subtract output is wrong when coercing values to I64 or U64
    • 190703—LabVIEW can leak memory when the Extract Single Tone Information 1 Chan.vi is called using VI Server
    • 190704—LabVIEW Configuration File VIs leak memory when called using VI Server
    • 190705—LabVIEW can leak memory when the Error Cluster From Error Code.vi is called using VI Server
    • 190758—LabVIEW can leak memory when repeatedly opening a VI reference
    • 191404—LabVIEW fails to compile if decimate 1D array.vi is used with string arrays
    • 192667—Common subexpression elimination combines fixed-point arithmetic incorrectly in VIs with debugging disabled
    • 195627—Information returned from a subVI is not consistent
    To force a recompile of a VI without recompiling its subVIs, press the key while you click the Run button. To force a recompile of all VIs in memory, press the keys while you click the Run button. To force a recompile of the entire current VI hierarchy, close all VIs currently opened, open the top-level VI, and press the keys while you click the Run button. This method will not recompile any of the VIs called dynamically in the hierarchy.
    You also can force a recompile of all VIs in a specified directory using the following steps.
    • Open LabVIEW.
    • Select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
    • Navigate to the desired directory and click the Current Folder button.
    • Click the Mass Compile button to force a recompile of all VIs in that directory.
    • Click the Done button to return to LabVIEW.
    © 2004–2009 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    National Instruments, NI, ni.com, LabVIEW, DIAdem, and NI TestStand are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    发表于 2022-5-31 16:58:14 | 显示全部楼层 来自:广东省深圳市 电信
    GMT+8, 2025-12-5 12:55
