查看: 3888|回复: 0
[LabVIEW] NI LabVIEW 2011SP1 Win32ENG/FRE/GER/JPN/KOR 32位LV2011SP1英语/法语/德语/日语/韩语版下载
    昨天 16:03
    发表于 2019-2-26 20:51:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI LabVIEW2011 SP1 英语版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    NI LabVIEW2011 SP1 法语版:
    请购买附件下载查看
    NI LabVIEW2011 SP1 德语版:
    请购买附件下载查看
    NI LabVIEW2011 SP1 日语版:
    请购买附件下载查看
    NI LabVIEW2011 SP1 韩语版:
    请购买附件下载查看
    LV2011SP1ENG、FRE、GER、JPN、KOR.txt (1.22 KB, 下载次数: 70, 售价: 10 圆)
    LabVIEW 2011 Service Pack 1 Readme for Windows
    Version 11.0.1
    December 2011
    This file contains important information about LabVIEW 2011 Service Pack 1 (SP1) for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed for LabVIEW 2011 SP1, changes from LabVIEW 2011, and a link to the Web page that contains known issues for LabVIEW.
    Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and a complete list of new features in LabVIEW 2011 and related service packs. Refer to the LabVIEW Release Notes for installation instructions and a complete list of system requirements. After you install LabVIEW, refer to the labview\manuals directory to access these documents. You also can access the LabVIEW Release Notes and LabVIEW Upgrade Notes at ni.com.
    Refer to the National Instruments Web site for the latest information about LabVIEW 2011 SP1.
    Installing LabVIEW 2011 SP1
    Installing Another Language Version
    Licensing
    LabVIEW 2011 SP1 (64-bit)
    Additions to the LabVIEW Help
    Notice Regarding Microsoft Silverlight Installation and Redistribution
    If you have LabVIEW 2011 installed, you can install LabVIEW 2011 SP1 without uninstalling LabVIEW 2011.
    Note: You cannot have both LabVIEW 2011 and LabVIEW 2011 SP1 installed simultaneously because LabVIEW 2011 SP1 installs over LabVIEW 2011.
    If you do not have LabVIEW 2011 installed, you can install LabVIEW 2011 SP1 without first installing LabVIEW 2011.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW on Windows.
    If you have installed another language version of LabVIEW 2011 SP1, uninstall that version before you install the new language version.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate the license, use the serial number you received as part of your installation package. If you upgrade to LabVIEW 2011 SP1 from LabVIEW 2011, use your existing LabVIEW 2011 serial number during installation.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW 2011 and related service packs.
    When run on Windows (64-bit), LabVIEW 2011 SP1 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2011 SP1 (64-bit) includes nearly all of the development environment features of LabVIEW 2011 SP1 (32-bit).
    Refer to the National Instruments Web site for information about obtaining a copy of LabVIEW 2011 SP1 (64-bit).
    LabVIEW 2011 SP1 (64-bit) supports many hardware devices. Drivers are available for DAQ devices, VISA devices, GPIB devices, and image acquisition devices. For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2011 SP1 (64-bit).
    Supported Modules
    LabVIEW 2011 SP1 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. LabVIEW 2011 SP1 (64-bit) does not support any additional modules.
    • In previous versions of LabVIEW, the NewRange event data field for the Scale Range Change event ignores custom offset and multiplier values you set for a graph or chart. In LabVIEW 2011 and related service packs, the NewRange event data field factors in custom offset and multiplier values in the results it returns. In previous versions of LabVIEW, if you use code to work around this issue, you need to update the code in LabVIEW 2011.
    The following table contains the IDs and titles of a subset of issues fixed in LabVIEW 2011 SP1. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    202432Throw the error with detailed message for the ReserveEPDS function in generated .NET assembly
    241971GenLeaInstruction, mapping null reg, EventData copy err=1 errors when debugging an .exe
    288455Shared variable not updated when changing representation
    300856Unable to use certain smart probes when debugging LabVIEW-built DLLs
    304328Typecasting an empty I/O constant to a numeric array crashes LabVIEW
    304531Red dot not working correctly for variants
    305157LabVIEW crashes when unflattening an empty string to a specific cluster
    305220Solve Linear Equations.vi can return incorrect values on Real-Time
    306797Cannot create indicator/control/constant for refnum data types from XML property and invoke nodes
    307318Crash when merging a change to a class control/indicator
    307687Error 1012 merging VIs from command line
    308464LabVIEW cannot build some large applications because it fills the image table
    308503Marking VIs as NOT source only will crash LabVIEW unless panels/diagrams are force loaded first
    309233LabVIEW 2011 crashes when doing a cut and paste of a system checkbox
    309834Access violation (0xC0000005) at EIP=0x00764624
    310077Variable browse dialog doesn't show any deployed IOVs
    310513LabVIEW can crash when aborting a VI using Asynchronous Call by Reference
    310850Internal error (OxA824222F) on user cancel of VI load
    311279Deploying a web service will fail
    311460Silver XY Graph - palette buttons are wrong color when toggled
    312257Executable build fails and locks the LabVIEW User Interface after finishing
    312332Charts history changed memory usage between LabVIEW 2010 and LabVIEW 2011
    313231LabVIEW Application Builder cannot deploy Mean.vi when setting passwords to the Analysis library
    314062Silver listbox control does not gray disabled item
    315103Execution-time crash with Scan Value.vi
    315365Enum/Ring control in Silver palette results in Generic Error on save
    315378Project loads significantly slow if .lvlps file is present after a build
    315726"Prompt for a comment on save VI" during builds
    315878Internal error (0xF50EFD7B)
    316379Assembly load error 1589 when using '#' in the assembly path
    316408LabVIEW 2011 crashes after running and closing a VI that uses packed library
    316606Strict typedefs containing a Named IO reference refuse to allow their label to be written via scripting.
    316641LabVIEW 2011 does not limit internal warning prints (to the log file)
    316909Custom license agreements are not displayed on LabVIEW-built installers
    318426Callers of items in packed library that are in subitems don't get their links updated properly.
    320393Owner references for controls within a typedef cluster do not match cluster reference
    322188VI Revision History "prompt for comment when a VI is closed" doesn't save comment
    Recompiling VIs for Bug Fixes
    The following fixes require you to manually recompile VIs to correct the problem:
    • 316408—LabVIEW 2011 crashes after running and closing a VI that uses packed library
    To force a recompile of a VI without recompiling its subVIs, press the key while you click the Run button. To force a recompile of all VIs in memory, press the keys while you click the Run button. To force a recompile of the entire current VI hierarchy, close all VIs currently opened, open the top-level VI, and press the keys while you click the Run button. This method does not recompile any of the VIs called dynamically in the hierarchy.
    You also can force a recompile of all VIs in a specified directory using the following steps.
    • Open LabVIEW.
    • Select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
    • Navigate to the desired directory and click the Current Folder button.
    • Click the Mass Compile button to force a recompile of all VIs in that directory.
    • Click the Done button to return to LabVIEW.
    Using Microsoft Silverlight
    © 2004–2011 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    LabVIEW, National Instruments, NI, ni.com, LabVIEW, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2026-2-24 23:48
