查看: 4097|回复: 0
[LabVIEW] NI LabVIEW 2013SP1 Win64ENG 64位LV2013SP1英文版下载
    昨天 16:03
    发表于 2019-2-28 09:35:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    百度网盘下载1.34GB:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    下载器:
    请购买附件下载查看
    LV2013SP1ENG64.txt (442 Bytes, 下载次数: 88, 售价: 10 圆)
    LabVIEW 2013 Service Pack 1 Readme for Windows
    Version 13.0.1
    December 2013
    This file contains important information about LabVIEW 2013 Service Pack 1 (SP1) for Windows, including system requirements, installation instructions, a partial list of bugs fixed for LabVIEW 2013 SP1, and known issues.
    Refer to the National Instruments website for the latest information about LabVIEW 2013 SP1.
    LabVIEW 2013 SP1 (64-bit)
    ProcessorPentium III/Celeron 866 MHz or equivalentPentium 4M or equivalent
    Screen Resolution1024 x 768 Pixels1024 x 768 Pixels
    Operating SystemWindows 8.1/8/7/Vista (32-bit and 64-bit)
    Windows XP SP3 (32-bit)
    Disk Space407 MB3.5 GB (includes default drivers from the NI Device Drivers DVD)
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  The following list describes restrictions for using LabVIEW on Windows:
    • LabVIEW does not support Windows 2000/NT/Me/98/95 or Windows XP x64.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2013 and LabVIEW 2013 SP1.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    LabVIEW Updates and Notifications
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW 2013 SP1.
    When run on Windows (64-bit), LabVIEW 2013 SP1 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2013 SP1 (64-bit) includes nearly all of the development environment features of LabVIEW 2013 SP1 (32-bit).
    Refer to the National Instruments website for information about obtaining a copy of LabVIEW 2013 SP1 (64-bit).
    LabVIEW 2013 SP1 (64-bit) supports many hardware devices. Refer to the National Instruments website for information about drivers compatible with LabVIEW 2013 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2013 SP1 (64-bit).
    Supported Modules
    LabVIEW 2013 SP1 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. No additional modules support LabVIEW 2013 SP1 (64-bit).
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2013 SP1. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    408914Using save for previous on a For Loop containing a subdiagram label in LabVIEW 2013 causes the loop N terminal to appear on top of the subdiagram label
    408955Crash when deleting a newly created comment with Automatic Tool Selection turned off
    415901When repairing LabVIEW 2013, the service locator dependency is uninstalled
    416470Using the Get Waveform Attribute in a subVI can cause incorrect data to be returned to the main VI
    420622If an HTTP method VI outputs an analog waveform it cannot be locally debugged
    422680Deploying a Web service to the Application Web Server gives an error "NI Application Web Server service is still starting"
    423373Under certain conditions, a compiler optimization will cause array shift registers to share memory space
    423385In LabVIEW 2013, once a Type Definition is made a Strict Type Def, it cannot be made non-strict
    423616If a LabVIEW executable containing .NET is included in an installer, it will fail to run when installed
    425800Calling Quit LabVIEW VI will not quit LabVIEW if the calling VI also contains an Event structure handling the Application Instance Close Event
    426140Building an installer with VIs that contain unsatisfied dependencies within diagram disable structures fails with "Error Generating Preview"
    429282In LabVIEW 2013, including VIs from some libraries causes building an installer to fail with error 1 "Error Generating Preview"
    429509LabVIEW 64-bit can crash when passing data to a Call Library Function Node that modifies the input data
    429724Under certain circumstances, an internal race condition can cause the LabVIEW UI thread to stop updating front panel objects
    429726.NET event callbacks to VIs that are already unloaded cause memory access violations
    430748Robust fix needed for .NET events calling back to VI that has already been de-registered
    434571In LabVIEW 64-bit manipulating arrays with the Array Subset node can cause LabVIEW to crash
    Recompiling VIs for Bug Fixes
    The following fixes require you to manually recompile VIs to correct the problem:
    • 416470—Using the Get Waveform Attribute in a subVI can cause incorrect data to be returned to the main VI
    • 429509—LabVIEW 64-bit can crash when passing data to a Call Library Function Node that modifies the input data
    • 430748—Robust fix needed for .NET events calling back to VI that has already been de-registered
    • 434571—In LabVIEW 64-bit manipulating arrays with the Array Subset node can cause LabVIEW to crash
    To force a recompile of a VI without recompiling its subVIs, press the key while you click the Run button. To force a recompile of all VIs in memory, press the keys while you click the Run button. To force a recompile of the entire current VI hierarchy, close all VIs currently opened, open the top-level VI, and press the keys while you click the Run button. This method does not recompile any of the VIs called dynamically in the hierarchy.
    You can also recompile VIs in a specified directory using the following steps:
    • Open LabVIEW.
    • Select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
    • Navigate to the directory you want and click the Current Folder button.
    • Click the Mass Compile button to recompile all VIs in that directory with updates.
    • Click the Done button to return to LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2013 SP1.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as NI MAX, to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps(Windows 8) or click the down arrow on the bottom left of the screen (Windows 8.1).
    LabVIEW Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2004–2013 National Instruments. All rights reserved.
    GMT+8, 2026-2-24 23:48
