查看: 3584|回复: 0
[LV工具模块] NI LabVIEW 2009 Digital Filter Design Toolkit Win32Eng LV2009DFDT数字滤波器设计工具包32位版
    昨天 16:03
    发表于 2019-11-1 10:24:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW数字滤波器设计工具包
    LabVIEW数字滤波器设计工具包提供了设计、分析和实现数字滤波器所需的交互式工具。
    LabVIEW数字滤波器设计工具包是一个LabVIEW附加软件,其内置的交互式设计工具可以帮助您探索经典的滤波器设计。该工具包还提供了各种算法、滤波器拓扑结构以及用于定点与浮点数字滤波器分析工具。对于定点滤波器,您可以建立量化效应的模型,优化数值表示/拓扑结构,并使用自动生成的ANSI C或LabVIEW FPGA代码,将设计部署到数字信号处理器或FPGA上。
    DFDT数字滤波器工具包,从2018年版本开始提供64位版的。之前的版本,则只有32位的版本。自2022Q3版开始,LabVIEW专业版集成DFDT工具包,但是仍然有独立安装版本。从2024Q1版开始,则不再提供独立安装包,仅在LabVIEW专业版安装包中包含DFDT工具包。
    发布日期:2009/8/4
    包含版本:2009完整版,版本号9.0.0
    Windows Server 2003
    Windows XP 32-bit
    Windows Vista
    应用程序位数:32位
    文件大小: 81390270 字节 (77.62 MB)
    修改日期: 2019-09-07 19:25
    MD5: c4245c7d1b2e83d24d8bb7ea91e87846
    SHA1: 66f0a424d2471f4f86a860f3ea84a8ebd3b92eaa
    SHA256: a0ce341e4a89127a5effb70eda2528527cdc6bd752567c2a1c225ac9ff61b86a
    SHA512: 49ec3ade0a1e049d67aac5df7b46f09a2e3cb023a8387523b5bafcf9159e8ea46cff5298622de78392cf49815dc1cad956a29543fcf90714cc110665e00571e2
    百度网盘下载链接:
    请注册视觉论坛会员登录后购买附件下载查看
    DFDT2009.txt (508 Bytes, 下载次数: 79, 售价: 10 圆)
    LabVIEW 2009 Digital Filter Design Toolkit Readme
    June 2009
    This file contains information to introduce you to the LabVIEW Digital Filter Design Toolkit. This file also provides you with help resources you can use while working with the toolkit. The file contains the following information that you need to understand.
    Uninstallation Instructions
    The LabVIEW 2009 Digital Filter Design Toolkit is the upgrade version of the LabVIEW 8.6 Digital Filter Design Toolkit. The Digital Filter Design Toolkit provides a collection of digital filter design tools to supplement the LabVIEW Full Development System. The Digital Filter Design Toolkit helps you design digital filters without requiring you to have advanced knowledge of digital signal processing or digital filtering techniques. With the Digital Filter Design Toolkit, you can design, analyze, and simulate floating-point and fixed-point digital filters.
    Without prior knowledge about programming in LabVIEW, you can use the Digital Filter Design Express VIs to interact graphically with filter specifications to design appropriate digital filters.
    The Digital Filter Design Toolkit provides VIs that you can use to design a digital finite impulse response (FIR) or infinite impulse response (IIR) filter, analyze the characteristics of the digital filter, change the implementation structure of the digital filter, and process data with the digital filter. In addition to the floating-point support, the Digital Filter Design Toolkit provides a set of VIs that you can use to create a fixed-point digital filter model, analyze the characteristics of the fixed-point digital filter, simulate the performance of the fixed-point digital filter, and generate fixed-point C code, integer LabVIEW code, or LabVIEW field-programmable gate array (FPGA) code for a specific fixed-point target.
    The Digital Filter Design Toolkit includes VIs for floating-point multirate digital filter design. You can use the VIs to design a floating-point single-stage or multistage multirate filter, analyze the characteristics of the floating-point multirate filter, and process data with the floating-point multirate filter. In addition to the floating-point filter design, the toolkit also provides a set of VIs that you can use to create a fixed-point multirate filter, analyze the characteristics of the fixed-point multirate filter, simulate the behavior of the fixed-point multirate filter, and generate LabVIEW FPGA code from the fixed-point multirate filter for NI-RIO targets.
    In addition to the graphical tools for digital filter design, the toolkit also provides Digital Filter Design MathScript RT Module functions that LabVIEW MathScript supports. These functions enable you to design filters in a text-based environment. You must install the LabVIEW MathScript RT Module to use the Digital Filter Design MathScript RT Module functions.
    • The LabVIEW 2009 Digital Filter Design Toolkit supports the fixed-point data type.
    • The LabVIEW FPGA code you generate with the LabVIEW 2009 Digital Filter Design Toolkit supports only the fixed-point data type.
    • You can generate LabVIEW FPGA code for any installed FPGA target by using the Start IP Generator dialog box. You can use this dialog box to configure filter implementation settings interactively.
    • You can implement fixed-point single-rate FIR filters by using the multiply-accumulate method or the distributed arithmetic method, which you can specify in the Start IP Generator dialog box.
    • You can implement multi-channel fixed-point cascaded integrator comb (CIC) filters.
    • You can save a multistage multirate filter into a file. You also can retrieve a multistage multirate filter from a file.
    • You can save a multistage multirate filter into a text file in XML format. You also can retrieve a multirate filter or multistage multirate filter from an XML file.
    • The DFD Get Filter Structure VI now is on the Utilities palette.
    • The LabVIEW 2009 Digital Filter Design Toolkit renames all Digital Filter Design MathScript RT Module functions. These changes do not affect your existing applications.
    The computer you are using must meet the minimum system requirements to run the Digital Filter Design Toolkit:
    • Windows Vista/XP/2000
    • A minimum of 50 MB free of disk space
    • LabVIEW 2009 Full or Professional Development System
    Note: If you want to use the LabVIEW 2009 Digital Filter Design Toolkit to generate LabVIEW FPGA code for a fixed-point digital filter, you must install the LabVIEW 2009 FPGA Module and NI-RIO software on the host computer. Ensure that you install the FPGA Module and NI-RIO software before you install the Digital Filter Design Toolkit. If you already installed the Digital Filter Design Toolkit, uninstall the Digital Filter Design Toolkit before installing the FPGA Module and NI-RIO software.
    You can install all of your LabVIEW products—including the Digital Filter Design Toolkit—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the Digital Filter Design Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    Complete the following steps to uninstall the Digital Filter Design Toolkit.
    • Open the Add or Remove Programs dialog box from the Control Panel.
    • Select National Instruments Software and click the Change button.
    • Under NI Products, select NI LabVIEW 2009 Digital Filter Design Toolkit and click the Remove button.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Digital Filter Design Toolkit. On the Contents tab of the LabVIEW Help, choose Toolkits»Digital Filter Design Toolkit. This book contains:
    • Concepts—An overview of how to use the Digital Filter Design Toolkit.
    • How-To—A step-by-step tutorial on designing floating-point and fixed-point filters using the Digital Filter Design Toolkit.
    • VIs—Detailed information about the Digital Filter Design VIs.
    • MathScript RT Module Functions—Detailed information about the Digital Filter Design MathScript RT Module classes of functions and commands that LabVIEW MathScript supports.
    LabVIEW examples for the Digital Filter Design Toolkit are located in the labview\examples\Digital Filter Design folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find example VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. You also can click the arrow on the Open button on the LabVIEW dialog box and select Examples from the shortcut menu to launch the NI Example Finder.
    Use the Browse or Search page of the NI Example Finder to find an example VI. In the Browse page, the Digital Filter Design Toolkit examples are located in the Toolkits and Modules»Digital Filter Design folder.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Digital Filter Design Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Digital Filter Design Toolkit. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Digital Filter Design Toolkit.
    Bug IDFixed Issue
    135615DFDT generates wrong LabVIEW FPGA code for moving average filters, when both the conversion rate and the number of channel are 1.
    136195DFDT generates wrong LabVIEW FPGA code for CIC filters in some cases.
    140908The implementation of nearest in CIC simulation is wrong.
    GMT+8, 2026-2-24 23:49
