NI LabVIEW 2018 Digital Filter Design Toolkit Win32Eng LV2018DFDT数字滤波器设计工具包32位版
LabVIEW数字滤波器设计工具包
LabVIEW数字滤波器设计工具包提供了设计、分析和实现数字滤波器所需的交互式工具。
LabVIEW数字滤波器设计工具包是一个LabVIEW附加软件,其内置的交互式设计工具可以帮助您探索经典的滤波器设计。该工具包还提供了各种算法、滤波器拓扑结构以及用于定点与浮点数字滤波器分析工具。对于定点滤波器,您可以建立量化效应的模型,优化数值表示/拓扑结构,并使用自动生成的ANSI C或LabVIEW FPGA代码,将设计部署到数字信号处理器或FPGA上。
DFDT数字滤波器工具包,从2018年版本开始提供64位版的。之前的版本,则只有32位的版本。自2022Q3版开始,LabVIEW专业版集成DFDT工具包,但是仍然有独立安装版本。从2024Q1版开始,则不再提供独立安装包,仅在LabVIEW专业版安装包中包含DFDT工具包。
发布日期:2018/5/21
包含版本:2018完整版,版本号18.0.0
Windows 7 (SP1) 64-bit
Windows 10
Windows Server 2008 R2 64-bit
Windows Server 2012 R2 64-bit
Windows 7 (SP1) 32-bit
Windows 8.1
应用程序位数:32位
文件大小: 244506522 字节 (233.18 MB)
修改日期: 2019-09-07 19:24
MD5: 7a345b206ea82066730db7f031e7c75a
SHA1: f4bea539c8755924166217f91ca5a98f5593ac98
SHA256: b4c1696c8653cad7aab8c8e29a90ff8cd639034e6f40b7cfa75021ab02bf5bb4
SHA512: 7d6f74a5277655a19cf9ac8b635b9021c3be5b471f42a0a789b2cb41c58b3d051c999fe348d83bfe9f3afbf0fb2addc135ecd93d1fd784f14f52be291c83336c
百度网盘下载链接:
请注册视觉论坛会员登录后购买附件下载查看
DFDT2018X86.txt
(584 Bytes, 下载次数: 94, 售价: 10 圆)
LabVIEW 2018 Digital Filter Design Toolkit ReadmeMarch 2018 This file contains important information about the LabVIEW 2018 Digital Filter Design Toolkit, including system requirements, installation instructions, new features, and known issues. Overview System Requirements Supported Operating Systems LabVIEW Digital Filter Design Toolkit (64-bit) Installation Instructions Product Security and Critical Updates New Features Known Issues Accessing the Help Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewThe Digital Filter Design Toolkit includes the Digital Filter Design VIs and the Adaptive Filters VIs to provide a collection of digital filter design tools, including adaptive filter design tools, to supplement the LabVIEW Full Development System. The Digital Filter Design Toolkit helps you design digital filters and filter banks without requiring you to have advanced knowledge of digital signal processing or digital filtering techniques. With the Digital Filter Design Toolkit, you can design and analyze floating-point and fixed-point digital filters and filter banks. With the Digital Filter Design Toolkit, you also can design and analyze floating-point and fixed-point adaptive filters. You also can simulate fixed-point digital filters, including fixed-point adaptive filters. Without prior knowledge about programming in LabVIEW, you can use the Digital Filter Design Express VIs to interact graphically with filter specifications to design appropriate digital filters and filter banks. The Digital Filter Design VIs help you design the following filters and filter banks: - Digital finite impulse response (FIR) or infinite impulse response (IIR) filters—You can use the VIs to analyze the characteristics of the digital filter, change the implementation structure of the digital filter, and process data with the digital filter. In addition to the floating-point support, the Digital Filter Design VIs also help you create a fixed-point digital filter model, analyze the characteristics of the fixed-point digital filter, simulate the performance of the fixed-point digital filter, and generate fixed-point C code, integer LabVIEW code, or (32-bit only) LabVIEW field-programmable gate array (FPGA) code for NI FPGA targets.
- Floating-point multirate digital filters—You can use the VIs to design a floating-point single-stage or multistage multirate filter, analyze the characteristics of the floating-point multirate filter, and process data with the floating-point multirate filter. In addition to the floating-point filter design, the Digital Filter Design VIs also help you create a fixed-point multirate filter, analyze the characteristics of the fixed-point multirate filter, simulate the behavior of the fixed-point multirate filter, and (32-bit only) generate LabVIEW FPGA code from the fixed-point multirate filter for FPGA targets.
- Filter banks—You can use the VIs to design a 2-band quadrature mirror filter (QMF) or M-band cosine-modulated filter bank, analyze the characteristics of a filter bank, decompose or reconstruct signals with filter banks, retrieve filter bank parameters, and create a filter bank from a prototype filter.
The Adaptive Filters VIs help you design a floating-point and fixed-point adaptive filter for different applications and with different adaptive filter algorithms. You can use the Adaptive Filters VIs to create an adaptive filter with the following adaptive algorithms: - Least mean squares (LMS) and the variants, such as normalized LMS, leaky LMS, normalized leaky LMS, sign LMS, and fast block LMS
- Filtered-x LMS and normalized filtered-x LMS
- Recursive least squares (RLS) and QR decomposition-based RLS (QR-RLS)
You can apply the adaptive filter that you create to applications like adaptive noise cancellation, adaptive echo cancellation, and system identification. (32-bit only) You also can create and implement a fixed-point adaptive filter on FPGA targets. In addition to the graphical tools for digital filter design, the toolkit also provides Digital Filter Design MathScript RT Module functions that LabVIEW MathScript supports. These functions enable you to design filters in a text-based environment. You must install the LabVIEW MathScript RT Module to use the Digital Filter Design MathScript RT Module functions. System RequirementsIn addition to the system requirements for the LabVIEW Development System, the Digital Filter Design Toolkit has the following requirements: - LabVIEW 2018 Full or Professional Development System
- At least 200 MB of disk space
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018. Note (32-bit only) If you want to use the Digital Filter Design Toolkit to generate LabVIEW FPGA code for a fixed-point digital filter, you must install the LabVIEW FPGA Module and NI-RIO software on the host computer. Ensure that you install the FPGA Module and NI-RIO software before you install the Digital Filter Design Toolkit. If you already installed the Digital Filter Design Toolkit, uninstall the Digital Filter Design Toolkit before installing the FPGA Module and NI-RIO software. Supported Operating SystemsThe Digital Filter Design Toolkit supports the following operating systems: - Windows 10 (version 1709)/8.1 Update 11/7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Note In 2016 the Digital Filter Design Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 Digital Filter Design Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 Digital Filter Design Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2018 Digital Filter Design Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. LabVIEW Digital Filter Design Toolkit (64-bit)The Digital Filter Design Toolkit (64-bit) provides access to more memory than the Digital Filter Design Toolkit (32-bit) can provide. The Digital Filter Design Toolkit (64-bit) does not support features and example VIs that require the Real-Time Module or the FPGA Module. Installation InstructionsYou can install all of your LabVIEW products—including the Digital Filter Design Toolkit—using the LabVIEW 2018 Platform media. To request additional LabVIEW Platform media, refer to the NI website. Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New FeaturesThe LabVIEW 2018 Digital Filter Design Toolkit adds support for LabVIEW 2018 (64-bit). Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the LabVIEW 2018 Digital Filter Design Toolkit. Accessing the HelpRefer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the Digital Filter Design Toolkit. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Digital Filter Design folder and the Toolkits and Modules»Adaptive Filters folder to access the examples. You also can find the examples for the Digital Filter Design Toolkit in the labview\examples\Digital Filter Design directory and the labview\examples\Adaptive Filters directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 2005–2018 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375119D-01 |
