查看: 4783|回复: 0
[NI软件产品] NI Vision Builder for Automated Inspection 2.0 Win32Eng 自动化检测视觉生成器VBAI2.0
    前天 16:03
    发表于 2020-2-4 10:43:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    VBAI2.0 自动化检测视觉生成器,标准图像处理软件,Windows系统32位英文版本。2003年发布,NI Vision Builder AI与LabVIEW7同期。
    百度网盘下载地址:
    VBAI2.0.txt (194 Bytes, 下载次数: 1, 售价: 100 圆)
    NationalInstruments Vision Builder for Automated Inspection
    Copyright2003, National Instruments Corporation.
    All rightsreserved.
    Readme.wri file for Vision Builder for Automated Inspection 2.0
    General Information
    1) This version of NI Vision Builder for AutomatedInspection (Vision Builder AI) runs on Windows 2000/NT/XP/Me/98. If you areusing Windows NT 4.0, you must have Service Pack 6 or higher installed on yourcomputer to run Vision Builder AI.
    2) Vision Builder AI requiresMicrosoft Internet Explorer 5.0 or higher. Go to www.microsoft.com to download Microsoft Internet Explorer.
    3) Vision Builder AI requires aminimum screen resolution of 1024 x 768 and a 16-bit (65536 colors) displayminimum. National Instruments recommends a 24- or 32-bit display.
    4) Perform the following steps toinstall Vision Builder AI:
    Note:To install Vision Builder AI on a Windows 2000/NT/XP system, you must be loggedin with administrator privileges.
    a.Insert the Vision Builder AI CD into your computer. If the CD startup screendoes not appear, use Windows Explorer to run the Setup.exe program from the Vision Builder AI CD.
    b.Follow the setup instructions on your screen.
    5) The Vision Builder AI installercreates the following directory structure under the Vision Builder AI 2.0directory:
    ·        Program and support files
    ·        Pluginsfolder - Additional support files
    ·        DemoImgfolder - Sample images
    ·        Products folder - Product inspection files
    ·        Helpfolder - Vision Builder AI online help files
    ·        Manualsfolder - Portable Document Format (PDF) versions of the release notes and NIVision Builder for Automated Inspection Tutorial. You must have AcrobatReader installed to use these documents.
    ·        RT Images - Software components required to run Vision Builder Server on an NI 1450Series Compact Vision System.
    National InstrumentsDevice Support
    1) This version of Vision Builder AIsupports the following National Instruments IMAQ devices:
    IMAQPXI/PCI-1407
    IMAQPXI/PCI-1409
    IMAQPXI/PCI-1411
    IMAQPXI/PCI-1422
    IMAQPCI-1424
    IMAQPCI-1428
    Note: If you are using an IMAQ device,you must install NI-IMAQ version 2.5.1 or later before you install the IMAQdevice. The NI-IMAQ 2.5.1 driver software gives you access to Measurement &Automation Explorer (MAX), which is software you can use to configure NationalInstruments devices.
    2) This version of Vision Builder AIsupports the NI 1450 Series Compact Vision System.
    Note: You must install version 1.5 orhigher of the NI-IMAQ for IEEE 1394 Cameras driver software to use VisionBuilder AI with the NI 1450 Series Compact Vision System.
    3) This version of Vision Builder AIsupports static digital I/O from any National Instruments device using MAXchannels. To support NI digital output devices, Vision Builder AI requiresNI-DAQ driver software version 6.9.2 or higher.
    Use MAX to create DAQ virtualchannels. For information about creating DAQ channels, refer to the Creatinga DAQ Channel topic in NI Vision Builder for Automated Inspection:Configuration Help.
    3) If you want to use Firewireindustrial digital video cameras with Vision Builder AI, you need NI-IMAQ forIEEE 1394 Cameras driver software version 1.1 or higher. To purchase thisdriver software, go to ni.com/vision.
    4) To support serial communication,Vision Builder AI requires NI-VISA driver version 2.6.0 or higher. You can useserial ports built into your PC or the following NI serial interfaces: PCI232/x, PXI 8420/x, or PXI 8422/x.
    Migration to LabVIEW
    Vision Builder AI 2.0 can createLabVIEW VIs that implement the steps of your inspection diagram. This featurerequires LabVIEW 7.0 or higher and IMAQ Vision 7.0 or higher. If yourinspection diagram contains a Read Text step, you must have NI OCR 1.0installed to migrate the Read Text step to LabVIEW.
    InstallationConsiderations
    If you are using Vision Builder AI 2.0with the NI 1450 Series Compact Vision System, you must install version 1.5 ofthe NI-IMAQ for IEEE 1394 Cameras driver software. Also, when you install thisdriver software, you must select the NI 1450 Series Support feature availableon the Features dialog of the installer.
    ·        Enabling EnableInspection Selection and specifying an Inspection to run on for aparticular Product Select Value overrides the Inspection youselected in the Startup tab. The NI Compact Vision System launches the Inspectionyou select for the first Product Select Value in the InspectionSelection tab rather than the Inspection you selected in the Startuptab. Refer to the Setting Remote Target Options topic in NI VisionBuilder AI Configuration Help for more information about these settings.
    ·        If you are using VisionBuilder AI with an NI Compact Vision System, you must install NI-VISA 3.0.1 orlater. Visit ni.com/visa for information about downloading and installing NI-VISA.Refer to the NI-VISA readme file for information regarding the changes andenhancements included in NI-VISA 3.0.1.
    GMT+8, 2026-2-25 03:04
