查看: 4155|回复: 1
[NI驱动程序] NI Vision Acquisition Software 8.5 for LabVIEW8.5 Win32Eng LV8.5视觉采集软件VAS8.5版
    半小时前
  • 签到天数: 3734 天
    连续签到: 61 天
    发表于 2020-2-6 22:09:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    美国国家仪器视觉采集软件NI Vision Acquisition Software 8.5.0版本VAS850,视觉论坛visionbbs.com珍藏版。NI不再提供老旧版本的下载服务或是SSP服务才可以下载,本论坛会收取一定的费用用于论坛日常维护。视觉采集软件是NI提供的IMAQ相机驱动程序。具体支持工业相机驱动协议、支持LabVIEW版本、操作系统等,可以查看读我文件。
    链接: 请购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址(不一定有效或无法完成下载):
    请购买附件下载查看
    单文件
    文件大小: 657852190 字节 (627.38 MB)
    修改日期: 2016-09-01 17:54
    MD5: f06c5972daeef099e605caf841a1a793
    SHA1: d24e9a09c8cb53f7f1afe38818b428a1ae36b80d
    SHA256: c56090cd8003ed3e5cca75811fdd3492167932b06ceb11d18c91b61b3b71df15
    CRC32: f220ebd3
    双文件CD1
    文件大小: 542968417 字节 (517.82 MB)
    修改日期: 2022-06-24 12:39
    MD5: 5bf998cf0dfc63abf85a7094b9d6ca32
    SHA1: bdd6f7a5abac9e64ee3131d00753fae29b61a9b0
    SHA256: 4349068994853e8618abe1254e4db149e936d7a39d2798844337e74004427c73
    CRC32: d3a64b1d
    双文件CD2
    文件大小: 114883795 字节 (109.56 MB)
    MD5: e38c9dd6eca9668f9146a918c77ac7a2
    SHA1: 3db76a2496742c397b8f71a4fe83f57f9ce916b3
    SHA256: 5b33ab5009541688be471fa7736a12967d018bfdf9a1f20ce5c1c607cb92030e
    CRC32: 91fda324
    VAS8.5.0.txt (650 Bytes, 下载次数: 40, 售价: 100 圆)
    NI Vision Acquisition Software Release Notes
    July 2007
    This file contains important information about National Instruments Vision Acquisition Software and is organized into the following sections:
    Upgrade Considerations for NI-IMAQ Customers
    Upgrade Considerations for NI-IMAQ for IEEE 1394 Cameras Customers
    Upgrade Consideration for NI-IMAQ I/O Customers
    Minimum System Requirements
    Software Support
    Installation
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    NI Vision Acquisition Software allows you to acquire, display, and save images; control the digital I/O on IEEE 1394 hardware; and configure your driver software and hardware.
    The readme.rtf file for each NI Vision Acquisition Software driver is installed to the following default locations, where is the location to which National Instruments software is installed.
    • NI-IMAQ\NI-IMAQ\Docs\readme.rtf
    • NI-IMAQdx\NI-IMAQdx\Docs\readme.rtf
    • NI-IMAQ I/O\NI-IMAQ IO\Docs\readme.rtf
    This release of Vision Acquisition Software includes the following new features:
    NI-IMAQ 3.8
    NI-IMAQ is the National Instruments driver software for NI image acquisition devices. Using NI-IMAQ, you can program your image acquisition device to acquire images.
    • Support for LabVIEW 8.5
    • New NI Vision Acquisition Express VI
    NI-IMAQdx 3.1
    NI-IMAQdx is the National Instruments driver software for IEEE 1394 and GigE Vision cameras. NI-IMAQdx gives you the ability to use IEEE 1394 and GigE Vision industrial digital video cameras to acquire images.
    NI-IMAQ I/O 2.1
    NI-IMAQ I/O is the National Instruments I/O device driver software for controlling the digital I/O on IEEE 1394 hardware.
    • Support for Windows Vista x64 Edition
    Note: If you have installed a prior version of NI-IMAQ on a Windows Vista system, uninstall the old version before installing the NI-IMAQ software.
    Region of Interest (ROI) and scaling settings in NI-IMAQ 2.x persist if you call Snap, Grab Setup, or Sequence a second time. In NI-IMAQ 3.0 or later, subsequent function calls change the ROI and scaling values to the defaults, as they were defined in MAX, unless you pass in new values for each.
    NI-IMAQdx introduces a new, though similar, application programming interface (API) for acquiring images from GigE Vision and IEEE 1394 cameras. National Instruments recommends that you use the NI-IMAQdx API for future applications. The following information is important to those upgrading to NI-IMAQdx from NI-IMAQ for IEEE 1394 Cameras.
    Note: If you have installed a prior version of NI-IMAQ for IEEE 1394 Cameras on a Windows Vista system, uninstall the old version before installing the NI-IMAQdx.
    Existing Applications Will Continue to Work
    NI-IMAQ for IEEE 1394 Cameras 2.0.5 files will be installed on the target machine. Existing compiled applications will continue to call into this driver and will run exactly as they did in NI-IMAQ for IEEE 1394 Cameras 2.0.5. This is also true for existing applications run from the development environment including National Instruments LabVIEW, LabWindows™/CVI™, Microsoft Visual Basic, and Visual C.
    Considerations for NI-IMAQ I/O Devices
    The following sections provide specific information about updating your software for use with your NI-IMAQ I/O device. NI-IMAQ I/O devices include the NI CVS-1450 Series compact vision system, the NI PCI-8254R, and the NI PCIe-8255R.
    Note: If you have installed a prior version of NI-IMAQ I/O on a Windows Vista system, uninstall the old version before installing the NI-IMAQ I/O software.
    NI Vision Builder AI
    If you are using Vision Builder AI with your CVS-1450 device, you must have Vision Builder AI 2.5 or later installed. If you have Vision Builder AI 2.0 installed, go to ni.com/support, and click the Drivers and Updates link to find and install the latest downloadable update. Without this support, you cannot configure the CVS-1450 device. Refer to the Vision Builder AI readme.html file for additional information about this update.
    Upgrading NI-IMAQ I/O Host VIs for Use with LabVIEW 8.x
    A host VI is a VI that communicates with an FPGA VI to control an FPGA target. A host VI can run on a Windows computer or on a real-time (RT) target. If you previously used LabVIEW 7.x to program your NI-IMAQ I/O device and you upgrade to LabVIEW 8.x, host VIs that use the digital I/O functionality of the NI-IMAQ I/O device may have a broken Run arrow when you open the VIs in LabVIEW 8.x.
    Complete the following steps to correct the broken Run arrow:
    • In LabVIEW 8.x, select Tools»Update 7.X VIs using NI-IMAQ I/O in the Getting Started window or in the Project Explorer window of an open project.
    • Click Add to add the host VIs that you want to upgrade to the VIs list.
    • Choose the location to save the VIs.
    • Click Continue. The Update 7.X VIs using NI-IMAQ I/O window will automatically close when the update is complete.
    Upgrading FPGA VIs for Use with LabVIEW 8.x
    An FPGA VI is a VI that runs on an FPGA target. If you created FPGA VIs using LabVIEW 7.x and the LabVIEW FPGA Module 1.x, you can update the VIs for use with LabVIEW 8.x and the LabVIEW FPGA Module 8.x. Refer to Upgrading FPGA VIs, Host VIs, and Embedded Projects from LabVIEW FPGA Module 1.x to 8.2 in the LabVIEW Help for more information about upgrading FPGA VIs to LabVIEW 8.x.
    After you have updated the software on your host computer, you must also update the software on your RT target. Refer to the Configuring NI-IMAQdx for the LabVIEW Real-Time Module section for information about updating software on your RT target.
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    • Pentium 4 1 GHz or equivalent processor
    • 512 MB RAM
    • Free hard disk space
      • NI-IMAQ: 460 MB
      • NI-IMAQdx: 360 MB
      • NI-IMAQ I/O: 850 MB
    • 1024 × 768 resolution video adapter and monitor
    • Internet Explorer 5.0 or later to view online documentation
    Software Support
    This section describes the operating systems and application development environments (ADEs) supported by NI Vision Acquisition Software.
    Operating Systems
    • Microsoft Windows Vista/XP/2000. Refer to the following table for more information.
      DeviceWindows Vista 32-bitWindows Vista 64-bit
      NI 1405YesYes*
      NI 1407YesYes*
      NI 1408NoNo
      NI 1409YesYes*
      NI 1410YesYes*
      NI 1411YesYes*
      NI 1422YesYes*
      NI 1424YesYes*
      NI 1426YesYes*
      NI 1427YesYes*†
      NI 1428YesYes*
      NI 1429YesYes*†
      NI 1430YesYes*†
      NI 8231YesYes
      NI 8252YesYes
      NI 8254RYesYes
      NI 8255RYesYes
      *  Applications developed using LabVIEW 8.2.1 or later will run on systems with more than 3 GB of physical memory. Applications developed using other development environments, such as Microsoft Visual C, Visual Basic, and .Net, are limited to systems with 3 GB or less of physical memory. All 32-bit applications, including those developed using LabVIEW, may not allocate more than 2 GB of memory total.
      †  A firmware update is available for this device to allow non-LabVIEW applications to run on systems with more than 3 GB of physical memory. To update the device firmware, launch MAX and select Tools»NI Vision»Update NI-IMAQ Device Firmware.
    • LabVIEW Real-Time Module (LabVIEW RT) 7.1.1 or later
      Note: NI-IMAQdx does not support GigE Vision cameras on LabVIEW RT. NI-IMAQdx does support IEEE 1394 cameras on LabVIEW RT.
    Development Environments
    • LabVIEW 7.1.1 or later
    • LabVIEW Real-Time Module 7.1.1 or later
    • LabWindows/CVI 7.1.1 or later
    • Microsoft Visual C/C++ 6.0 or later
    • Microsoft Visual Basic 6.0 or later
    • Microsoft Visual Studio .NET 2003 and later (except NI-IMAQ I/O)
    Additional Software
    You can also use NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O with the following National Instruments software packages to prototype, benchmark, and deploy your applications.
    • NI Vision Development Module 7.1 or later
    • NI Vision Builder for Automated Inspection (Vision Builder AI) 2.5 or later
      Note: GigE Vision support requires Visoin Builder AI 3.0 or later.
    Installation
    Complete the following steps to install NI Vision Acquisition Software:
    Note: You must have administrator access to install the NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation CD in the CD-ROM drive.
    NI-IMAQ and NI-IMAQdx integrate with MAX, the National Instruments utility for configuring and testing your measurement and automation system. The MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ:
    • Run MAX.
      • Double-click the MAX icon on the desktop. You can use MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces and NI-IMAQ Devices to display a list of the image acquisition devices installed on your computer.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with MAX.
    Configuring a Remote Image Acquisition Device
    Use MAX to install NI-IMAQ for LabVIEW Real-Time from the host machine onto the target system. The NI-IMAQ for LabVIEW Real-Time components enable the remote device to acquire and analyze images as directed by the host machine.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the MAX help window to install software.
    • Launch MAX.
    • Expand NI-IMAQ Devices.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to install and configure NI-IMAQdx.
    Instructions for configuring an IEEE 1394 or GigE Vision camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    Installing IEEE 1394 Hardware
    Install your IEEE 1394 interface card. Follow the installation instructions provided by the manufacturer.
    • Install your NIC.
      • If Windows does not prompt you to choose a driver, proceed to step 2.
      • If Windows prompts you to choose a driver, proceed to step 3.
    • Choose not to connect to the Windows Update Web site, and click Next.
    • Choose to Install from a list or a specific location, and click Next.
    • Choose Don’t Search. I will choose the driver to install.
    • Click Next.
    • Select National Instruments GigE Vision driver from the list, and click Next.
    • Click Finish.
    Note: Windows may return a warning stating that the driver is unsigned. It is safe to ignore the warning.
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps:
    Configuring Multiple Ports
    If you plan to use multiple ports with NI-IMAQdx, complete the following steps:
    • Open the Network Connections window in Windows, and select all of the ports that cameras will be connected to by holding while clicking each port.
    • Right-click one of the selected ports, and choose Bridge Connections.
    Note: If you are not using the High Performance Driver, you will be unable to use jumbo frames on bridged devices.
    Complete the following steps to configure NI-IMAQdx for Windows:
    • Connect the IEEE 1394 of GigE Vision camera.
    • Run MAX.
      • Double-click the MAX icon on your desktop. You can use MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • For IEEE 1394 cameras, NI-IMAQdx may not be associated with the camera. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx:
    Note: NI-IMAQdx only supports IEEE 1394 cameras on the LabVIEW Real-Time Module.
    • Run MAX.
      • Configure your network settings. Refer to the Remote Systems Help in MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the RT target.
      • Click Install Software on the MAX toolbar to launch the LabVIEW Real-Time Install Software Wizard.
      • Select NI-IMAQdx RT, as well as any additional software you would like to install on the target machine.
      • Click Next to begin downloading the software to the target machine. When MAX has finished downloading the software, it restarts the remote device.
      • Click Finish.
      Note: If you are using an NI CVS-1450 Series device with Vision Builder AI, refer to the Vision Builder AI documentation for camera configuration information.
    • Press to refresh the MAX configuration tree. Your IEEE 1394 camera should be listed in the Remote Systems list.
    The NI Vision Acquisition Software documentation is installed onto your hard drive with NI Vision Acquisition Software. The documentation ships as Adobe Acrobat portable document format (PDF) files and HTML Help files.
    To view the NI Vision Acquisition Software documentation, select Start»All Programs»National Instruments»Vision»Documentation. You can access the NI-IMAQ VI Reference Help and the NI-IMAQdx VI Reference Help from the LabVIEW Help menu.
    Note: You must have Adobe Acrobat Reader with Search and Accessibility 5.0.5 or later installed to view the PDFs. Refer to the Adobe Systems Incorporated Web site at www.adobe.com to download Adobe Reader.
    © 2007 National Instruments Corporation. All rights reserved.
    发表于 2021-5-6 19:23:38 | 显示全部楼层 来自:江苏省苏州市 电信
    GMT+8, 2025-12-6 12:50
