查看: 4118|回复: 0
[LabVIEW] NI LabVIEW 2016 MAC OS X64Eng LV2016苹果系统评估版下载
    前天 16:03
    发表于 2020-2-19 20:46:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW2016 MAC版,有三个文件版本可以下载,差别都不是很大,文件大小也不大。
    其中有一个版本是2016.6.19修改发行的。应该是最早的一版,后面有两个版本则是2017.02.14发布的,只是在时间分秒上有差别,可能只是命名不同罢了,内容应该一样。
    LabVIEW2016-Evaluation.dmg
    2016.06.19 11:13
    链接:
    请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    LabVIEW2016Eval.dmg
    2017.02.14 13:51
    链接:
    提取码: 请购买附件下载查看
    LabVIEW2016.dmg
    2017.02.14 13:58
    链接:
    提取码: 请购买附件下载查看
    NI官方在线下载:
    请购买附件下载查看LabVIEW2016-Evaluation.dmg(2016-06-20 00:20  561M)
    请购买附件下载查看LabVIEW2016.dmg(2017-02-14 00:22  560M)
    请购买附件下载查看LabVIEW2016Eval.dmg(2017-02-14 00:23  561M)
    LV2016MAC.txt (937 Bytes, 下载次数: 76, 售价: 10 圆)
    LabVIEW 2016 Readme for OS X
    June 2016
    This file contains important information about LabVIEW 2016 for OS X, including system requirements, installation instructions, known issues, and a partial list of bugs fixed. LabVIEW 2016 for OS X is available only in 64-bit.
    LabVIEW 2016 for OS X has the following requirements:
    OS XRun-Time EngineDevelopment Environment
    ProcessorIntel-based processorIntel-based processor
    RAM256 MB2 GB
    Operating SystemOS X 10.10 or 10.11OS X 10.10 or 10.11
    • LabVIEW 2016 for OS X is available only in 64-bit.
    • NI recommends that you use Firefox 10.0 or later or Safari 6.0 or later to view the LabVIEW Help.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2016.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    LabVIEW 2016 for OS X supports the following modules and toolkits.
    • MathScript RT Module2
    • VI Analyzer Toolkit
    2 The MathScript RT Module does not support the libraries class of MathScript RT Module functions.
    Refer to the NI website for information about drivers compatible with LabVIEW for OS X.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2016.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2016. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    333388Incorrect highlight execution order with LVOOP property node
    405304Menu Item VIs can cause LabVIEW to crash
    425622Edit Events menu for Event Structures can delete the new event you are trying to create
    434420Leading zeros are not allowed in Numeric Case Selector values
    518954Unconstrained Downhill Simplex ignores some stopping conditions
    519216LabVIEW crash when closing subVI Icon Editor that was opened from VI Hierarchy
    526175Spreadsheet String to Array VI crashes when an empty string is wired to delimeter input
    530595Not a Refnum Primitive returns incorrect value when evaluating a specific type of "Invalid Refnum"
    534553Quit LabVIEW function closes VI if you choose cancel
    539895File Dialog Express VI alters error chain
    542865Front panel object updates pause when resizing front panel or block diagram
    5444351-D Array Probe Display Window has issues with high resolutions
    544526Fatal Internal Error 0x89B93EF0: "drawmgr2.cpp" when running Mac application for extended time
    544533Scripting dynamic events on an event structure returns Error 1
    544907Delaunay Triangulation hangs on certain input data
    546555Error 1025 when creating Override VI for an already open parent class
    547120Incorrect VI dataflow when using an Error Wire with a parallelized For Loop
    549429DAbort 0x34E86741 ConvertNum called with non-numeric
    554381Sort items in the Choose Implementation class dialog alphabetically
    555758Using the 'Unflatten From String Function' to unflatten an "invalid" string within LabVIEW x64 can cause the computer to become unresponsive
    555788Using "Fast File Format" to build an executable could result in error 2208 in some cases
    555868Using the Tree Control 'Drag Starting? Event' allows you to Delete the reference to the item you are dragging and can result in a LabVIEW crash
    561615In specific cases, building a LabVIEW executable with shared variables causes Error 1003 during the build
    564219Sometimes if RFmx continuously modifies the loading state of the UI thread, a race condition can occur and potentially cause a crash
    567353When an XNode output is wired to the Loop count of a Parallel For Loop the VI breaks
    567369LabVIEW crashes when getting the properties of a class containing a member VI with certain connector pane configurations
    568111HTTP calls can throw Assertion Errors on Mac OS X when LabVIEW is not installed
    569362In cases of extreme load on a TCP server, LabVIEW can miss new connection notifications, causing a timeout
    569793Rare persistent Error 56 at TCP Read
    570547Bluetooth Read, Write, and Close primitives have TCP icon
    571421In certain cases, dynamically calling a VI containing a SubVI can cause a memory leak. The size of the memory leak scales with the size of the SubVI and its dependencies
    571556Showing Visible Items on Waveform Chart probe does not resize chart in the probe window
    571713Scripting a Value Change event for an IVI Logical Name control crashes LabVIEW
    571935Closing a project library containing a class with unsaved changes does not prompt for save
    573539In some cases, DNS name resolution in LabVIEW can block other TCP calls
    574048Error 8 when trying to create an actor under an unsaved library
    574488Upgrading to Mac OS X 10.11 (El Capitan) prevents Source Control in LabVIEW from finding Perforce
    575278Error 1019 when creating a message, if the actor contains a never-before-saved method
    578899LabVIEW 64-bit Development Environment has the potential to crash while running certain RFmx examples
    580210Remote debugging sessions that involve packed project libraries can stop unexpectedly
    580212Remote debugging VIs that were built without front panels can close the session unexpectedly
    581199Unflatten From String throws error 74, does not update indicators
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2016.
    © 2004–2016 National Instruments. All rights reserved.
    374717F-01
    GMT+8, 2026-2-25 03:02
