查看: 6847|回复: 4
[NI软件产品] NI Vision Builder for Automated Inspection 2019 Win32/64Eng 自动检测视觉生成器VBAI19.5 LabVIEW2019SP1版适用
    前天 16:03
    发表于 2020-2-21 21:46:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI Vision Builder for Automated Inspection 2019 VBAI2019视觉生成器,版本号19.5,标准图像处理软件,32位与64位英文版本,Windows系统。支持LabVIEW2019SP1。可选择离线安装版本下载。VBAI的版本号现在也是很乱了,从早些年的VBAI2015/F1/F2/F3分别可用于LV2015/16/17到VBAI2018(适用LV2018)、VBAI2018SP1(适用LV2019),再到现在的VBAI2019又是适用LV2019SP1的。一定要注意看自述文件及发行时间,以保证兼容相应的LabVIEW,以保证在LabVIEW中有API可支持。
    发布日期:2019.12.6
    支持系统:
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    语言:英文
    MD5: 92ef821177b725373419dac9bda6b7fd
    SHA1: cb44f27cef8748fdec1f35fc0698b9f6010b07d0
    SHA256: a2b248d82bd192a5386368f6f83152bcc5a6787c9aef1fedd24d7388bbeebeb6
    CRC32: 28997199
    百度网盘下载地址:
    离线安装版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请登录论坛账号后购买附件下载查看
    在线安装版(在线安装程序只有5.4M,即在安装时所需要的内容,均需要从NI官方网站下载,如果是内网用户或者是网络不佳时,请使用离线安装方式):
    NI官方下载地址:
    离线安装版:
    请登录论坛账号后购买附件下载查看
    在线安装版:
    请登录论坛账号后购买附件下载查看
    VBAI2019.txt (630 Bytes, 下载次数: 147, 售价: 10 圆)
    NI Vision Builder for Automated Inspection 2019 Readme
    November 2019
    This file contains important information about NI Vision Builder for Automated Inspection (Vision Builder AI), including installation instructions, new features, and known issues.
    Software Requirements for Migrating an Inspection to LabVIEW
    PC-Based Image Acquisition and I/O Support
    Additional Resources
    NI Vision Builder AI helps you to configure, benchmark, and deploy a system that addresses vision applications from pattern matching to code reading and presence detection to precision alignment and classification.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/vision for the latest information about NI Vision Builder AI.
    NI Vision Builder AI 2019 has the following requirements:
    Minimum
    Recommended
    ProcessorPentium 4/M or equivalentCore Duo or equivalent
    Memory512 MB RAM1 GB RAM
    Display1,024 × 768 resolution video adapter with a 24- or 32-bit display1,280 × 1,024 resolution video adapter with a 24- or 32-bit display
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 10 IoT Enterprise LTSB 2016 (64-bit)3
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Embedded Standard 7 SP12,3
    Browser
    Microsoft Internet Explorer 6.0 or later
    Hard Disk Space
    7.7 GB
    8.3 GB
    3Only supported as pre-installed on NI hardware.
    NI Vision Builder AI 2019 supports the following application software versions, including service packs.
    Versions Supported by NI Vision Builder AI 2019
    LabVIEW2015, 2016, 2017, 20181, 2019
    LabWindows™/CVI™2012, 2013, 2015, 2017, 2019
    TestStand2014, 2016, 2017, 2019
    1 Required when using the NI Vision Builder AI Development Toolkit.
    Note: The Vision Builder AI API for .NET is now available as an open source on github at https://github.com/ni/vbai-dotnet.
    Installation InstructionsInstalling Vision Builder AI
    Complete the following steps to install Vision Builder AI:
    Note: You must be logged in with administrator privileges to install Vision Builder AI.
    • Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
    • Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
    • Vision Builder AI prompts you to enter your user information. Select one of the following options:
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard.
    Activating Vision Builder AI
    If you do not activate a valid license, Vision Builder AI runs in evaluation mode and continues to prompt you to activate a license on each launch. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
    Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
    Complete the following steps to activate the Vision Builder AI license:
    • Launch Vision Builder AI.
    • Click Yes when prompted to activate Vision Builder AI.
    • Continue to follow the instructions on the screen. Login or register your NI account with the NI Licensing Wizard and enter your serial number when prompted.
    The following list describes the new features in Vision Builder AI 2019:
    • User Documentation
      • This new feature allows users to document their inspection by adding formatted text and images to steps, states, transitions, as well as the inspection. Go to Edit > Edit Inspection Documentation from the Edit menu to access the documentation.
    • TestStand Custom Steps
      • Integrated TestStand support with the release of TestStand Custom steps. The TestStand Custom steps allow users to automate Vision Builder AI from TestStand. The new feature allows the user to launch a local Vision Builder AI engine, connect to a Remote Target running Vision Builder AI, open the inspections, run the inspection, set variables, and get results.
    • Improved Pattern Matching Template Editor
      • Improved masking capabilities and match offset and angle definition. The UI is now expandable.
    • Screenshot Preset
      • New Screenshot preset added to the Match Pattern and Map Defect steps. The screenshot preset loads predefined parameters used to match templates defined on images acquired directly from display sources.
    Supported HardwareWindows-Based Device Support
    You can use Vision Builder AI to configure and control the following Windows-based National Instruments devices:
    • NI CVS-1458 and 1459 Compact Vision Systems
    • NI IC-3120, 3121, 3171, and 3173 Industrial Controllers
    • NI ISC-178x Smart Cameras
    Remote Target Support
    You can use Vision Builder AI to remotely configure and control a supported remote target running NI Linux Real-Time. Vision Builder AI supports the following remote targets:
    • NI CVS-1458RT and 1459RT Compact Vision Systems
    • NI IC-3120, 3121, 3171, 3172, and 3173 Industrial Controllers
    To use Vision Builder AI with a remote target, you must use Vision Builder AI to configure the remote target. For more information about using Vision Builder AI to configure the remote target, refer to the documentation included with the remote target or the NI Vision Builder for Automated Inspection: Configuration Help.
    Note: National Instruments recommends using WebDAV to transfer files to and from a real-time target. For more information on using WebDAV to transfer files to and from a remote target, go to ni.com/info and enter the Info Code WebDAVTransfer.
    The following table illustrates when a remote target requires you to install driver software on the development computer.
    Remote Target or Camera
    Connected to a Remote Target
    Requires Driver Software Installed
    on Development Computer
    NI Smart Camera
    No
    IEEE 1394
    No
    GigE Vision
    No
    The following table illustrates which USB NI CompactDAQ chassis are supported by remote Vision Builder AI targets.
    Remote Target
    Supported USB NI CompactDAQ chassis
    • NI cDAQ-9171
    • NI cDAQ-9174
    • NI cDAQ-9178
    NI CVS-1458 and NI CVS-1459 Compact Vision System
    NI IC-312x Industrial Controller
    NI IC-317x Industrial Controller
    The following list describes the changes and enhancements to existing features in Vision Builder AI 2019:
    • Precision improved to more than 2 digits of precision in step limits. Users can now input limits with x digits of precision.
    • Addition of a line profile graph to the Measure Intensity step.
    • Vision Builder AI now supports smaller monitor resolutions of 741x601 or larger in the Inspection Mode.
    • The Calculator and Run LabVIEW step can now abort the currently running VI while editing the step.
    • Addition of the following primitives to the Calculator step:
      • String to Path
      • Path to String
      • Build/Strip Path
      • Get Date/Time
      • Format Date/Time
      • Case Structure
      • Feedback Note
      • Tick Count
    Application Interface and Examples
    The NIEXTCCOMPILERSUPP environment variable is provided as an alias to the location of C language support files. You can use this variable when compiling and linking an application. The Application Interface files (header and library files to include in applications) are placed in a centralized location to prevent users from accidentally overwriting them and to provide this NIEXTCCOMPILERSUPP environment variable.
    Note: $(NIEXTCCOMPILERSUPP) is configured as an environment variable on the target system. The variable evaluates by default to \Program Files\National Instruments\shared\ExternalCompilerSupport\C on a 32-bit system.
    ItemInstalled Location
    header files<$(NIEXTCCOMPILERSUPP)>\include
    32-bit MSVC import libraries<$(NIEXTCCOMPILERSUPP)>\lib32\msvc
    64-bit MSVC import libraries<$(NIEXTCCOMPILERSUPP)>\lib64\msvc
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI Vision Builder AI 2019.
    Refer to the NI website for an up-to-date list of all bug fixes in this release.
    See Additional Resources.
    To migrate an inspection to LabVIEW, Vision Builder AI 2019 requires LabVIEW 2019 or later and NI Vision Development Module 2019 or later.
    Some Vision Builder AI steps require additional software to successfully migrate an inspection to LabVIEW.
    • OPC UA requires the LabVIEW OPC UA Toolkit.
    • Ethernet/IP or Ethernet/IP adapter require NI-Industrial Communications for Ethernet/IP.
    Refer to the following table for software requirements to migrate specific steps. Driver versions must support the target version of LabVIEW for migration.
    Step Name
    Requirement
    Acquire ImageNI-IMAQ
    Acquire Image (IEEE 1394, GigE, or USB)NI-IMAQdx
    Acquire Image (Smart Camera)NI-IMAQdx
    Generate PulseNI-IMAQ
    Generate Pulse (Vision RIO)NI-IMAQ I/O for PCIe-8237R and PCIe-825xR boards, and Compact Vision Systems
    NI Industrial Controller Device Drivers for industrial controllers
    Read/Write I/ONI-IMAQ
    Read/Write I/O (NI-DAQmx)NI-DAQmx
    Read/Write I/O (Vision RIO)NI-IMAQ I/O for PCIe-8237R and PCIe-825xR boards, and Compact Vision Systems
    Note: NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O are available on the NI Vision Acquisition Software DVD included with Vision Builder AI. The NI Industrial Controller Device Drivers DVD is provided separately with industrial controller devices. To download NI-DAQmx, visit ni.com/downloads/products/.
    Software Requirements for the Run LabVIEW VI Step
    The Run LabVIEW VI step in Vision Builder AI 2019 supports VIs saved in LabVIEW 2019 or earlier.
    Vision Builder AI supports the following types of image acquisition and I/O devices:
    • National Instruments image acquisition devices
    • IEEE 1394 industrial digital cameras
    • GigE Vision cameras
    • DirectShow-compatible USB cameras
    • IP cameras
    • Digital or analog I/O from NI data acquisition (DAQ) devices
    • Serial devices
    Note: You must install driver software to acquire images from an image acquisition device connected to the development computer.
    National Instruments Image Acquisition Devices
    This version of Vision Builder AI supports National Instruments image acquisition devices that require NI-IMAQ driver version 4.6.4 or later. Specific devices may require later versions.
    Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
    IEEE 1394 Cameras, GigE Vision Cameras, DirectShow-Compatible USB Cameras, and IP Cameras
    This version of Vision Builder AI supports IEEE 1394 cameras, GigE Vision cameras, USB3 Vision, DirectShow-compatible USB cameras, certain IP cameras, and requires NI-IMAQdx driver version 3.3 or later. Specific devices may require later versions.
    To acquire an image from one of these camera types when the camera is connected to the host computer, use the Acquire Image (1394, GigE, or USB) step. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
    You must configure an IEEE 1394 camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure an IEEE 1394 camera to use the NI-IMAQdx driver.
    • Launch MAX.
    • In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
    • Expand NI-IMAQdx Devices to obtain a list of available cameras.
    • Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
    NI Analog and Digital I/O Devices
    This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Virtual Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
    Serial Communication
    To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA on the PC to use the serial port on a remote target.
    Deployment Policy for Vision Builder AI
    Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
    Licensing Options
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Vision Builder AI offers the following licensing options:
    • Vision Builder AI Full-Featured (778649-35)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Full-Featured for NI Real-Time Targets—Allows full access to all Vision Builder AI features on supported real-time targets, which can be used to configure, benchmark, and deploy inspections. This license is only included with certain hardware targets and does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Runtime (779799-35)—Allows you to deploy existing inspections to a Windows-based host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
    • Vision Builder AI Development Toolkit (779343-35)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
    Windows Firewall
    If you are using the Windows Firewall and launch Vision Builder AI, a dialog box may prompt you to allow Vision Builder AI to receive information over the network. Select Allow access so that Vision Builder AI can communicate with your remote target.
    Additional ResourcesHow do I get started?
    Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
    Where can I find reference information?
    Reference information for Vision Builder AI can be accessed through the following methods:
    • From within Vision Builder AI by clicking the Show Context Help button.
    • Select Start»All Programs»National Instruments»Vision Builder AI 2019»Vision Builder AI 2019 Documentation on your PC.
    The following documents are provided with Vision Builder AI as online help:
    • NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    • NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
    • NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
    Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
    The following documents are provided with Vision Builder AI as Adobe PDF documents:
    • Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
    • NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
    Where can I find examples?
    Access examples of common Vision Builder AI inspections by selecting Start»All Programs»National Instruments»Vision Builder AI 2019»Vision Builder AI 2019 Examples on your PC.
    Where else can I go for Vision Builder AI information?
    Visit ni.com/vision and the NI Developer Zone at ni.com/zone for the most up-to-date information about Vision Builder AI.
    ©2002-2019 National Instruments. All rights reserved.
    375131F-01
  • 签到天数: 11 天
    发表于 2020-9-9 17:20:02 | 显示全部楼层 来自:福建省泉州市 电信
  • 签到天数: 2 天
    发表于 2022-6-18 21:14:44 | 显示全部楼层 来自:广东省清远市 移动
  • 签到天数: 2 天
    发表于 2022-6-18 21:15:20 | 显示全部楼层 来自:广东省清远市 移动
    NI官方下载地址:
    离线安装版:
    请登陆论坛账号后购买附件下载查看
    GMT+8, 2026-2-25 03:05
