查看: 4679|回复: 0
[LV工具模块] LabVIEW 2013 Datalogging and Supervisory Control Module Win32Eng LV2013数据记录和监控模块DSC2013
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2020-2-23 14:37:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    Full
    文件大小: 841392928 字节 (802.41 MB)
    修改日期: 2020-02-23 12:38
    MD5: 10b17cb9e31d170ff525904c84fbec2c
    SHA1: 470cb68a1f926c909a5b6e1d924e254ec47f8793
    SHA256: a17ab07e10dfe5968d594bd0edd8f98fd99c4c4a02bfdcf4c230a93300749a2c
    SHA512: 2ce5fc28c4dcc10c37357a9d20611557a33f338a82b749d7fb5367b786511bcefb819d9b7ac7c4e45e19449b3021b12165b0c79e7af33ccca927dddc3c2312ad
    百度网盘下载和NI官方下载地址:
    请购买附件下载查看
    DSC2013.txt (781 Bytes, 下载次数: 14, 售价: 10 圆)
    RTS
    文件大小: 749159200 字节 (714.45 MB)
    修改日期: 2023-05-11 16:52
    MD5: cd03b1581c5b398332e9472e3472fc4a
    SHA1: e2aa999cdd364282326fc274cbb38e02254d2aeb
    SHA256: 7aa9c2b0df0138370070958c1b73dce9c0f21e87b4c7ebe5366af24f7f68ec3f
    CRC32: 28914292
    百度网盘下载和NI官方下载地址:
    DSC_RTS2013.txt (399 Bytes, 下载次数: 0, 售价: 8 圆)
    LabVIEW 2013 Datalogging and Supervisory Control Module Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW 2013 Datalogging and Supervisory Control (DSC) Module, including installation instructions, a partial list of bugs fixed for the LabVIEW 2013 DSC Module, and known issues. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit, for upgrade and compatibility issues of the DSC Module and a complete list of the new features and changes from the DSC Module 2012.
    The LabVIEW Datalogging and Supervisory Control (DSC) Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, provides support for Touch Panel devices running Windows Embedded Standard, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    • 512 MB of RAM. National Instruments recommends 1 GB of RAM
    • Internet Explorer 6 Service Pack 1 or later
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    LabVIEW Datalogging and Supervisory Control Module Updates and Notifications
    You can access the software and documentation known issues list online. National Instruments website for an up-to-date list of known issues in the DSC Module
    The following items are the IDs and titles of a subset of issues fixed in the 2013 DSC Module. This is not an exhaustive list of issues fixed in the current version of the current version of the DSC Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    93751Alarm properties are set to default values when it is disabled and enabled again via properties nodes
    252427Cannot set a shared variable as U32 Bit Field type from the shared variable dialog in a LabVIEW project
    349645The Shared Variable Engine and LabVIEW AckType enum values are defined in a different order
    356183The NI DSC OPC UA API and QuickClient are not compatible with the COPA-DATA ZenOPCsvr
    364404LabVIEW returns "Library not found or failed to load" error messages after you close and reopen a VI
    370238LabVIEW crashes if the Alarm Properties window is open while an alarm is automatically acknowledged
    397993The Read Traces VI hangs when reading a remote trace as an executable
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Datalogging and Supervisory Control Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Datalogging and Supervisory Control Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Datalogging and Supervisory Control Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2000–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-5 13:21
