查看: 5285|回复: 0
[LV工具模块] LabVIEW 2014 Datalogging and Supervisory Control Module Win32Eng LV2014数据记录和监控模块DSC2014
    昨天 16:03
    发表于 2020-2-23 14:47:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    EXE版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ZIP版:
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)(EXE与ZIP内容一样,EXE为NI当年发行时的版本,ZIP为NI后面重新压制的版本):
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    DSC2014.txt (929 Bytes, 下载次数: 20, 售价: 10 圆)
    LabVIEW 2014 Datalogging and Supervisory Control Module Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW 2014 Datalogging and Supervisory Control (DSC) Module, including installation instructions, new features, known issues, and a partial list of bugs fixed for the LabVIEW 2014 DSC Module.
    The LabVIEW Datalogging and Supervisory Control (DSC) Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2014 Base, Full, or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    • 512 MB of RAM. National Instruments recommends 1 GB of RAM.
    • Internet Explorer 6 Service Pack 1 or later
    • One of the following operating systems for application development:
      • Windows XP Service Pack 3 or later
      Note:
      • The DSC Module does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
      • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Note:
    • The DSC Module requires the Microsoft SQL Server 2008 R2 Express. This component is installed by default when you install the DSC Module. Refer to How Do I Configure the Microsoft SQL Server? at ni.com/kb for information about how to configure the Microsoft SQL Server.
    Licensing
    The DSC Module relies on licensing activation. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    The LabVIEW 2014 DSC Module includes the Modbus VIs for you to establish Modbus communication in LabVIEW.
    The new Modbus palette, available on the Data Communication palette, provides VIs that you can use to build control systems with specific performance or rate requirements using Modbus. By using the Modbus VIs, you can control the requests that Modbus masters generate, determine when to send these requests, and operate on the responses that Modbus slaves send.
    Refer to the VI and Function Reference»Data Communication VIs and Functions»Modbus VIs book on the Contents tab in the LabVIEW Help for information about the Modbus VIs.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the DSC Module.
    The following items are the IDs and titles of a subset of issues fixed in the DSC Module. This is not an exhaustive list of issues fixed in the current version of the DSC Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    405808Partial data pages appear to be missing from the destination database after a trace archive
    426256The Read (String) instance VI on the OPC UA Server palette leaks memory
    430776Error -1967353902 occurs when you use serial ports other than COM1 for Modbus
    The 2014 DSC Module does not have any upgrade and compatibility issues. For upgrade and compatibility issues specific to previous versions of the DSC Module, refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes at ni.com.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Datalogging and Supervisory Control Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Datalogging and Supervisory Control Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Datalogging and Supervisory Control Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2000–2014 National Instruments. All rights reserved.
    GMT+8, 2026-2-24 20:51
