查看: 5345|回复: 1
[LV工具模块] LabVIEW 2015 Datalogging and Supervisory Control Module Win32Eng LV2015数据记录和监控模块DSC2015
    昨天 16:03
    发表于 2020-2-23 14:56:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    百度网盘下载(EXE与ZIP内容一样,EXE为NI当年发行时的版本,ZIP为NI后面重新压制的版本):
    EXE版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看ZIP版:
    提取码: 请购买附件下载查看
    NI下载器下载:
    提取码: 请购买附件下载查看
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    DSC2015.txt (1.08 KB, 下载次数: 29, 售价: 10 圆)
    LabVIEW 2015 Datalogging and Supervisory Control Module Readme
    June 2015
    This file contains important information about the LabVIEW Datalogging and Supervisory Control (DSC) Module, including installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2015 DSC Module.
    The LabVIEW Datalogging and Supervisory Control (DSC) Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2015 Base, Full, or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    • 512 MB of RAM. NI recommends 1 GB of RAM.
    • Internet Explorer 6 Service Pack 1 or later
    • One of the following operating systems for application development:
      • Windows 8.1/8.0/7/Vista (32-bit and 64-bit)
      • Windows XP SP3
      • The DSC Module does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
      • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2015 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    • The DSC Module requires the Microsoft SQL Server 2008 R2 Express. This component is installed by default when you install the DSC Module. Visit ni.com/info and enter the Info Code exafvc for information about how to configure the Microsoft SQL Server.
    Licensing
    The DSC Module relies on licensing activation. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the DSC Module.
    The following items are the IDs and titles of a subset of issues fixed in the DSC Module. This is not an exhaustive list of issues fixed in the current version of the DSC Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    508633LabVIEW hangs when connection is lost to an OPC tag
    516294When unacknowledged alarms are present in a shared variable library, the shared variable library disappears
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Datalogging and Supervisory Control Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Datalogging and Supervisory Control Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW Datalogging and Supervisory Control Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2000–2015 National Instruments. All rights reserved.
    375310A-01
  • 签到天数: 6 天
    发表于 2022-12-31 09:19:58 | 显示全部楼层 来自:陕西省 移动数据上网公共出口
    您好,我想下载一个LABVIEW2015用的modbus RTU 读取寄存器的插件,是数据记录和监控模块2015么
    GMT+8, 2026-2-24 20:52
