查看: 5722|回复: 0
[LV工具模块] LabVIEW 2019 Datalogging and Supervisory Control Module Win32Eng LV2019数据记录和监控模块DSC2019
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2020-2-23 18:47:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    NI在线安装工具:
    请购买附件下载查看
    DSC2019.txt (1.03 KB, 下载次数: 38, 售价: 10 圆)
    LabVIEW 2019 Datalogging and Supervisory Control Module Readme
    March 2019
    This file contains important information about the LabVIEW Datalogging and Supervisory Control (DSC) Module, including installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2019 DSC Module.
    LabVIEW Datalogging and Supervisory Control Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The LabVIEW DSC Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2019 Base, Full, or Professional Development System (32-bit)
    • At least 2.5 GB of disk space
    • 512 MB of RAM. NI recommends 1 GB of RAM.
    • Internet Explorer 6 Service Pack 1 or later
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2019.
    Note  The DSC Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
    The DSC Module supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    • In 2016 the LabVIEW DSC Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 DSC Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2019 DSC Module to an unsupported OS. Additionally, after installing the LabVIEW 2019 DSC Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    • Refer to LabVIEW Datalogging and Supervisory Control Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    You can also install the DSC Module using the LabVIEW 2019 Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    • The DSC Module requires the Microsoft SQL Server 2008 R2 Express. This component is installed by default when you install the DSC Module. Visit ni.com/info and enter the Info Code exafvc for information about how to configure the Microsoft SQL Server.
    • The Microsoft SQL Server 2008 R2 Express does not support Windows 10. You may encounter errors when installing the DSC Module on Windows 10 (earlier than version 1809). As a workaround, make sure you update your operating system to Windows 10 (version 1809).
    Licensing
    The DSC Module relies on licensing activation. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code lvdsc2019ki for an up-to-date list of known issues in the DSC Module.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2019 DSC Module. This is not an exhaustive list of issues fixed in the current version of the DSC Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    666934Citadel 4 Service does not need Local System privileges.
    666965Citadel 5 Service does not need Local System privileges.
    666974NI Domain Service does not need Local System privileges.
    669398NI PSP Service Locator service does not need Local System privileges.
    678291Documentation on block diagram of Write Single Register Response.vi (Modbus API) doesn't match functionality.
    700184Modbus API is not threadsafe, and hides application-destroying faults.
    709650Remove password for modbus APIs.
    717007Opening Modbus examples throws load warning about missing modules, when DSC Module is already installed.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Datalogging and Supervisory Control Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2000–2019 National Instruments. All rights reserved.
    375310F-01
    GMT+8, 2025-12-5 13:21
