查看: 6870|回复: 1
[LV工具模块] LabVIEW 2019 Datalogging and Supervisory Control Module Run-Time System Win32Eng LV2019数据记录和监控模块运行时系统2019DSC-RTS
    昨天 16:03
    发表于 2020-2-23 18:52:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    百度网盘下载离线安装版:
    链接:
    请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方离线安装下载地址(可能无效或无法下载完成):
    请购买附件下载查看
    NI官方在线安装工具:
    请购买附件下载查看
    DSC2019RTS.txt (1.17 KB, 下载次数: 15, 售价: 10 圆)
    LabVIEW 2019 Datalogging and Supervisory Control Runtime Readme
    March 2019
    This file contains important information about the LabVIEW Datalogging and Supervisory Control (DSC) Runtime, including installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2019 DSC Runtime.
    LabVIEW Datalogging and Supervisory Control Runtime Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The LabVIEW DSC Runtime allows you to run applications built with LabVIEW, the DSC Module, and the LabVIEW Application Builder on a computer without the DSC Module installed. The DSC Runtime contains components that enable the DSC Module features in the built applications.
    The DSC Runtime has the following requirements:
    • Depending on the components you choose to install, the computer must have the following amount of free disk space:
      • 1.0 GB free disk space if you install all components of the DSC Runtime except the Shared Variable Logging Support component
      • 2.5 GB free disk space if you install all components of the DSC Runtime
    • At least 512 MB of RAM
    The DSC Runtime supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    • In 2016 the LabVIEW DSC Runtime dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 DSC Runtime will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2019 DSC Runtime to an unsupported OS. Additionally, after installing the LabVIEW 2019 DSC Runtime, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    • Refer to LabVIEW Datalogging and Supervisory Control Runtime Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    You can also install the DSC Runtime by using the LabVIEW 2019 Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Note  The NI OPC Servers application installed with the DSC Runtime provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code lvdsc2019ki for an up-to-date list of known issues in the DSC Runtime.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2019 DSC Runtime. This is not an exhaustive list of issues fixed in the current version of the DSC Runtime. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    666934Citadel 4 Service does not need Local System privileges.
    666965Citadel 5 Service does not need Local System privileges.
    666974NI Domain Service does not need Local System privileges.
    669398NI PSP Service Locator service does not need Local System privileges.
    678291Documentation on block diagram of Write Single Register Response.vi (Modbus API) doesn't match functionality.
    700184Modbus API is not threadsafe, and hides application-destroying faults.
    709650Remove password for modbus APIs.
    717007Opening Modbus examples throws load warning about missing modules, when DSC Module is already installed.
    The Datalogging and Supervisory Control Runtime will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2000–2019 National Instruments. All rights reserved.
    375311F-01
  • 签到天数: 6 天
    发表于 2020-12-14 11:48:40 | 显示全部楼层 来自:陕西省西安市 电信
    GMT+8, 2026-2-24 17:54
