查看: 3243|回复: 0
[LV工具模块] LabVIEW 2009SP1 MathScript Real-Time Module Win32ENG LV2009SP1文本数学脚本实时模块MSRT2009SP1 Win32位英文版下载
    昨天 16:03
    发表于 2020-2-25 14:42:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。
    百度网盘下载地址:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    MSRT2009SP1.txt (1.09 KB, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2009 SP1 MathScript RT Module Readme
    Version 9.0.1
    December 2009
    This file contains information to introduce you to the LabVIEW MathScript RT Module. This file also provides you with additional help resources you can use while working with the module.
       Mac OS
       Linux
    LabVIEW MathScript is a text-based language you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    The MathScript RT Module has the following requirements:
    • LabVIEW 2009 SP1 Full or Professional Development System
    (Windows) The MathScript RT Module supports the following operating systems for application development:
    • Windows XP (32-bit)
    • Windows 2000
    Note  The MathScript RT Module does not support Windows NT/Me/98/95 or the Windows Server non-R2 editions.
    Complete the following steps to install the MathScript RT Module.
    You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW Platform DVDs. You can find installation instructions for the module along with activation instructions in the following locations:
    • LabVIEW Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Mac OS
    Complete the following steps to install the LabVIEW MathScript RT Module on Mac OS.
    • Insert the LabVIEW MathScript RT Module installation CD and open LabVIEWMathScript9.0.pkg.
    Linux
    Complete the following steps to install the LabVIEW MathScript RT Module on Linux.
    • Insert the LabVIEW MathScript RT Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom
      sh ./INSTALL
      If you encounter the message bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To correct this issue, enter the following command:
      /bin/sh ./INSTALL
    Refer to the MathScript RT Module Functions and Fundamentals»Formulas and Equations books on the Contents tab of the LabVIEW Help for more information about the MathScript RT Module.
    Refer to the labview\examples\MathScript directory for LabVIEW examples for the MathScript RT Module. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The LabVIEW 2009 SP1 MathScript RT Module introduces the following enhancements and changes to LabVIEW MathScript. The LabVIEW 2009 MathScript RT Module does not contain these features.
    Determinism Guidelines
    National Instruments has tested a subset of functions and constructs possible in MathScript and found that they typically execute in a bounded amount of time on RT targets when used according to the guidelines in LabVIEW Help. Refer to the MathScript RT Module Functions»Guidelines for Using LabVIEW MathScript in Real-Time Applications book on the Contents tab of the LabVIEW Help for more information about reducing jitter and achieving bounded execution times for applications that contain MathScript Nodes.
    New MathScript Functions
    The MathScript RT Module includes the following functions of the rt class, which you can use to perform debugging and isolate sources of jitter on RT targets:
    • rt_debugoutput
    • rt_loadsend
    • rt_loguserevent
    • rt_starttrace
    • rt_stopsave
    • rt_stopsend
    • rt_tickcount
    • rt_wait
    • rt_waitmultiple
    Performance Improvements
    The LabVIEW MathScript Window and MathScript Nodes launch faster due to performance improvements.
    LabVIEW MathScripts compile faster at edit time in the MathScript Node due to performance improvements.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the MathScript RT Module.
    Windows 7 Issues
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the info code windows7.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2009 SP1 MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of the MathScript RT Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    118408Editing a VI with a MathScript Node that contains a very large script is very slow
    152620MathScript probe does not work on VI running on RT
    171904'cd' function does not work on Linux when you specify an absolute path as an input
    175141After building applications with MathScript, the MathScript VIs are broken
    175343Indexing row vectors with ':' character doesn't work in some cases
    1765068-bit signed and unsigned integers used in certain syntax breaks VIs
    176650Wiring enum values to MathScript Node breaks VI
    176783MathScript 'sort' function has reduced performance when only one output is requested
    176788MathScript Nodes with inputs that have undefined data types load slowly and report an internal error
    177105'voronoi' function causes LabVIEW to run out of memory when inputs are large
    182784Input variables to MathScript Nodes sometimes disappear from MathScript Probe window
    186044Building .exe with MathScript Node and certain MathScript syntax fails
    186744Subfunctions defined in .m files return 'unknown symbol' error when you call top-level function in MathScript Window
    189518Internal error returned when doing simple arithmetic in the MathScript Window
    189851VI breaks when returning conditionally defined variable from user-defined function without end-of-line semicolon
    193257Matrix power operator ^ only calculates power of 1st element if called directly in MathScript Node
    Important Information
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in the MathScript RT Module, refer to the Copyright topic of the LabVIEW Help.
    GMT+8, 2026-2-24 20:50
