查看: 3259|回复: 0
[LV工具模块] LabVIEW 2012 MathScript Real-Time Module MAC LV2012文本数学脚本实时模块MSRT2012 MAC英文版下载
    昨天 16:03
    发表于 2020-2-25 17:11:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。
    百度网盘下载地址:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    MSRT2012-MAC.txt (933 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 MathScript RT Module Readme
    Version 12.0
    June 2012
    This file contains important information about the LabVIEW 2012 MathScript RT Module, including installation instructions, new features, and known issues.
       Mac OS X
       Linux
    LabVIEW MathScript is a text-based environment you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript RT Module has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    Refer to the LabVIEW Readme file in the labview directory for additional system requirements and supported operating systems for LabVIEW 2012.
    Complete the following steps to install the MathScript RT Module.
    You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Mac OS X
    Complete the following steps to install the LabVIEW MathScript RT Module on Mac OS X.
    • Insert the LabVIEW MathScript RT Module installation CD and open LabVIEW MathScript 2012.mpkg from the Mac OS X subdirectory.
    Delete the following files or directories on the computer to manually uninstall the LabVIEW MathScript RT Module on Mac OS X:
    • /Applications/National Instruments/LabVIEW 2012/resource/mathscript.rsc
    • /Applications/National Instruments/LabVIEW 2012/examples/MathScript/
    • /Applications/National Instruments/LabVIEW 2012/vi.lib/imath/
    • /Applications/National Instruments/LabVIEW 2012/vi.lib/imathl/
    • /Library/Caches/National Instruments/InstCache/12.0/
    • ~/Documents/LabVIEW Data/MathScriptVIs/
    • /Library/Application Support/National Instruments/example finder/1.0/products/labview/12.0/exbins/english/lvexmscript.bin4
    Linux
    Complete the following steps to install the LabVIEW MathScript RT Module on Linux.
    • Insert the LabVIEW MathScript RT Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom/Linux
      sh ./INSTALL
      If you encounter the message bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To correct this issue, enter the following command:
      /bin/sh ./INSTALL
    To run a script that uninstalls the MathScript RT Module on Linux, enter the following command:
    sh ./UNINSTALL
    The LabVIEW 2012 MathScript RT Module introduces the following enhancements and changes.
    MathScript Support for Cell Arrays
    In the LabVIEW 2012 MathScript RT Module, you can organize data with different types and sizes in a single variable for use in the LabVIEW MathScript Window or the MathScript Node. Every cell in a cell array can store data with a different type and size than the data in the other cells in the cell array. Refer to the MathScript RT Module»Organizing Data with Different Types and Sizes in Variables topic on the Contents tab of the LabVIEW Help for more information about cell arrays.
    When you pass a 1D array of strings from the block diagram into a MathScript Node, by default, MathScript pads the strings with spaces until all the strings are the same length as the longest string. In the LabVIEW 2012 MathScript RT Module, you can pass a 1D array of strings into a MathScript Node and right-click the input terminal on the node to select String Representation»Cell Array. When you specify to use cell arrays, MathScript maintains the length of each string in the array without adding any spaces. Refer to the MathScript RT Module»Using MathScript Nodes»Debugging MathScripts» Passing Data in and out of the MathScript Node topic on the Contents tab of the LabVIEW Help for more information about passing cell arrays, and other data types, in and out of the MathScript Node.
    New MathScript Functions
    The MathScript RT Module 2012 includes the following new functions. You can use these functions in the LabVIEW MathScript Window or a MathScript Node.
    • The cells class contains cell and is_cell.
    • The structs class contains getfieldnames and order_fields.
    Refer to MathScript RT Module»MathScript RT Module Functions book on the Contents tab of the LabVIEW Help for more information about built-in MathScript functions.
    MathScript Function Change
    The expm1 function computes the base e exponential of the input elements minus 1.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the MathScript RT Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of the MathScript RT Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    242487Cannot drag multiple variables between local and global categories
    253318The ode_bdf15 function takes too long to execute
    279449Save All also tries to save the plot window generated by the plot function
    281000LabVIEW MathScript hangs when loading a script with a large model
    309671MathScript does not handle an enum inside of a struct correctly when passed into a MathScript Node
    336366Assigning an empty matrix to a field of a structure returns error -90042 for an array of structures
    Refer to the MathScript RT Module book on the Contents tab of the LabVIEW Help for more information about the MathScript RT Module.
    Refer to the labview\examples\MathScript directory for LabVIEW examples for the MathScript RT Module. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2009–2012 National Instruments. All rights reserved.
    GMT+8, 2026-2-24 20:51
