查看: 3815|回复: 0
[LV工具模块] LabVIEW 2015 MathScript Real-Time Module Linux/MAC LV2015文本数学脚本实时模块MSRT2015 Linux/MAC系统英文版下载
    昨天 16:03
    发表于 2020-2-25 17:48:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。
    百度网盘下载地址:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    MSRT2015Linux-MAC.txt (857 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2015 MathScript RT Module Readme
    June 2015
    This file contains important information about the LabVIEW MathScript RT Module, including installation instructions, a partial list of bugs fixed for LabVIEW 2015 MathScript RT Module, and known issues.
    LabVIEW MathScript is a text-based environment you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript RT Module has the following requirements:
    • LabVIEW 2015 Full or Professional Development System (32-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    (Windows) MathScript RT Module runs on 32-bit Windows operating systems. You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW 2015 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    (OS X) MathScript RT Module runs on 32-bit OS X operating systems. Complete the following steps to install the MathScript RT Module on OS X.
    • Insert the MathScript RT Module installation media and open LabVIEW 2015 MathScript RT Module.pkg from the Mac OS X subdirectory.
    To uninstall the MathScript RT Module on OS X, manually delete the following files and directories:
    • /Applications/National Instruments/LabVIEW 2015/resource/mathscript.rsc
    • /Applications/National Instruments/LabVIEW 2015/examples/MathScript/
    • /Applications/National Instruments/LabVIEW 2015/vi.lib/imath/
    • /Applications/National Instruments/LabVIEW 2015/vi.lib/imathl/
    • /Library/Caches/National Instruments/InstCache/15.0/
    • ~/Documents/LabVIEW Data/MathScriptVIs/
    • /Library/Application Support/National Instruments/example finder/1.0/products/labview/15.0/exbins/english/lvexmscript.bin4
    (Linux) MathScript RT Module runs on 32-bit and 64-bit Linux operating systems. Complete the following steps to install the MathScript RT Module on Linux.
    • Insert the MathScript RT Module installation media. Use mount /mnt/cdrom to mount the media. On some systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter the following command according to the Linux operating system on which you run the MathScript RT Module:
      cd /mnt/cdrom/Linux_32-bit or cd /mnt/cdrom/Linux_64-bit
      sh ./INSTALL
    To uninstall the MathScript RT Module on Linux, enter the following command:
    sh ./UNINSTALL
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the MathScript RT Module.
    The following items are the IDs and titles of a subset of issues fixed in the MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of the MathScript RT Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    474126Crosscorr execution time significantly increases with larger data sets
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help, for information about the MathScript RT Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the MathScript RT Module are located in the labview\examples\MathScript directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW MathScript RT Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW MathScript RT Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of MathScript RT Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2009–2015 National Instruments. All rights reserved.
    375325A-01
    GMT+8, 2026-2-24 20:52
