查看: 3246|回复: 0
[TestStand] NI TestStand 4.2 美国国家仪器测试序列管理软件TS4.2下载
    4 小时前
  • 签到天数: 3810 天
    发表于 2020-2-29 17:41:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    TestStand是一款旨在帮助测试和验证工程师快速构建和部署自动化测试系统的应用软件。
    TestStand是一款可立即运行的测试管理软件,可帮助您快速开发自动化测试和验证系统。您可以使用TestStand来开发、执行和部署测试系统软件。还可以通过在TestStand中开发测试序列来扩展系统的功能,这些测试序列可集成使用任何编程语言编写的代码模块。TestStand还为报告生成、数据库记录以及与其他企业系统的连接提供了可扩展的插件。您可以使用易用的操作界面将测试系统部署到生产环境中。
    TestStand4.2
    链接: 请注册视觉论坛会员登录后购买附件下载查看 提取码: 请购买附件下载查看
    TestStand4.2
    请购买附件下载查看
    TS4.2.txt (806 Bytes, 下载次数: 2, 售价: 10 圆)
    TestStand ATML Toolkit 1.0
    文件大小: 46010912 字节 (43.88 MB)
    修改日期: 2009-09-12 02:18
    MD5: 435bb272c99a3d3c7a60a053170e525a
    SHA1: d91edfb3a2c3e231adc2cade6d7ddba7bf7b69c3
    SHA256: 74688b4de7929bedbaaed8b44c2abbcb523b6cfce60cb16ccbb07474db239eeb
    CRC32: dfd54779
    TestStand ATML Toolkit1.0.txt (506 Bytes, 下载次数: 0, 售价: 10 圆)
    NI TestStand™ 4.2 Readme
    May 2009
    This document contains information about bugs fixed in NI TestStand 4.2. Refer to the What's New in TestStand topics for TestStand 4.2 in the NI TestStand Help for information about other changes since TestStand 4.1, including new features. Refer to the What's New in TestStand topics for previous versions of TestStand in the NI TestStand Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    Refer to the NI TestStand Version 4.2 Release Notes for information about getting started with TestStand, such as system requirements, installation instructions, and descriptions of the TestStand licenses. If you do not activate a TestStand license, TestStand operates in evaluation mode.
    Supported Platforms
    Installing TestStand Silently
    Licensing
    Additional Information
    Supported Platforms
    TestStand supports Windows 2000/XP (32-bit) and Windows Vista (32-bit and 64-bit) but does not support Windows 95/98/Me/NT, any Windows Server edition, or Windows XP (64-bit). Refer to the NI TestStand Version 4.2 Release Notes for a complete list of recommended system requirements.
    You can install TestStand without viewing any installation dialog boxes. Refer to the National Instruments KnowledgeBase article 4CJDP38M, Automating the Installation of a Single Installer, on the National Instruments Web site for information about installing National Instruments software silently. Refer to the NI TestStand Version 4.2 Release Notes for more information about installing TestStand.
    Licensing
    TestStand relies on licensing activation. You must activate a valid TestStand license before you can run TestStand. To activate TestStand, use the serial number you received as part of your installation package. Refer to the NI TestStand Version 4.2 Release Notes for more information about licensing in TestStand.
    Refer to the List of Known Issues in TestStand 4.2 on the National Instruments Web site for a list of known issues in TestStand 4.2.
    Use this Toggle Expansion button to expand or collapse all the sections. You must enable the Allow Blocked Content option in Microsoft Internet Explorer to collapse each section. You must expand each section you want to print or search.
    TestStand Engine
    TestStand Sequence Editor
    TestStand Deployment Utility
    User Interfaces
    LabWindows/CVI
    ActiveX/COM Adapter
    C/C++ DLL Adapter
    Database
    Miscellaneous
    Refer to the Technical Support page at ni.com/support and search for TestStand to access the TestStand Support Web page, which contains online documentation, KnowledgeBase articles, tutorials, example code, discussion forums, and other resources.
    National Instruments, NI, ni.com, NI TestStand, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2026-2-27 13:32
