查看: 2977|回复: 0
[TestStand] NI TestStand 4.2.1 and Patch 美国国家仪器测试序列管理软件TS4.2.1及补丁下载
    发表于 2020-2-29 18:01:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    TestStand是一款旨在帮助测试和验证工程师快速构建和部署自动化测试系统的应用软件。
    TestStand是一款可立即运行的测试管理软件,可帮助您快速开发自动化测试和验证系统。您可以使用TestStand来开发、执行和部署测试系统软件。还可以通过在TestStand中开发测试序列来扩展系统的功能,这些测试序列可集成使用任何编程语言编写的代码模块。TestStand还为报告生成、数据库记录以及与其他企业系统的连接提供了可扩展的插件。您可以使用易用的操作界面将测试系统部署到生产环境中。
    TestStand4.2.1
    链接: 请注册视觉论坛会员登录后购买附件下载查看 提取码: 请购买附件下载查看
    TestStand4.2.1Patch231482补丁
    TestStand4.2.1
    请购买附件下载查看
    请购买附件下载查看
    TS4.2.1.txt (1.03 KB, 下载次数: 3, 售价: 10 圆)
    NI TestStand™ 4.2.1 Readme
    November 2009
    This document contains information about bugs fixed in NI TestStand 4.2.1. Refer to the What's New in TestStand topics for TestStand 4.2 in the NI TestStand Help for information about other changes since TestStand 4.1, including new features. Refer to the What's New in TestStand topics for previous versions of TestStand in the NI TestStand Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    TestStand 4.2.1 does not include the LabVIEW 2009 Run-Time Engine. To include the LabVIEW 2009 Run-Time Engine in a TestStand deployment installer, you must install LabVIEW 2009 on the computer from which you create the deployment, and you must select the run-time component in the Drivers and Components dialog box of the TestStand Deployment Utility.
    To execute VIs on a remote LabVIEW 2009 system, TestStand requires Remote Execution Support for NI TestStand for LabVIEW 2009. Refer to the Remote Execution section of Chapter 7, Using LabVIEW 8.x with TestStand, in the Using LabVIEW and LabWindows/CVI with TestStand manual for more information about installing remote execution support.
    Refer to the NI TestStand Version 4.2 Release Notes for information about getting started with TestStand, such as system requirements, installation instructions, and descriptions of the TestStand licenses. If you do not activate a TestStand license, TestStand operates in evaluation mode.
    Supported Platforms
    Installing TestStand Silently
    Licensing
    Upgrading TestStand 4.2 to TestStand 4.2.1
    Installing TestStand 4.2.1 Deployment Software
    TestStand 4.2 to TestStand 4.2.1 Bug Fixes
    TestStand 4.1 to TestStand 4.2 Bug Fixes
    Additional Information
    Supported Platforms
    TestStand 4.2.1 supports Microsoft Windows 2000/XP (32-bit), Windows Vista (32- and 64-bit), and Windows 7 (32- and 64-bit) but does not support Windows 95/98/Me/NT, any Windows Server edition, or Windows XP (64-bit). Refer to the NI TestStand Version 4.2 Release Notes for a list of other recommended system requirements. Refer to the National Instruments KnowledgeBase article 50O9851O, Does TestStand support calling VIs using LabVIEW 64-Bit? on the National Instruments Web site for information about LabVIEW 64-bit support.
    Note: TestStand 4.2.1 is the last version to support Windows 2000.
    You can install TestStand without viewing any installation dialog boxes. Refer to the National Instruments KnowledgeBase article 4CJDP38M, Automating the Installation of a Single Installer, on the National Instruments Web site for information about installing National Instruments software silently. Refer to the NI TestStand Version 4.2 Release Notes for more information about installing TestStand.
    Licensing
    TestStand relies on licensing activation. You must activate a valid TestStand license before you can run TestStand. To activate TestStand, use the serial number you received as part of your installation package. Refer to the NI TestStand Version 4.2 Release Notes for more information about licensing in TestStand.
    You can install TestStand 4.2 and TestStand 4.2.1 on the same computer and run applications in both versions, or you can upgrade an existing TestStand 4.2 installation to TestStand 4.2.1. TestStand 4.2 and TestStand 4.2.1 use separate directories for the , , and directories.
    Complete the following steps to upgrade an existing TestStand 4.2 installation to TestStand 4.2.1.
    • Navigate to Add/Remove Programs on the Windows Control Panel, select National Instruments Software, and run the TestStand 4.2 uninstaller.
    • Install TestStand 4.2.1.
    • Move any custom components you added to the TestStand 4.2 directory to the TestStand 4.2.1 directory. Custom components include code templates, engine callbacks, icons, language files, models, run-time servers, step types, tools, and type palettes.
    • Move any configuration files you want to use from the TestStand 4.2 directory to the TestStand 4.2.1 directory.
    When you install TestStand 4.2 and TestStand 4.2.1 on the same computer, TestStand 4.2.1 cannot directly access the custom components in TestStand 4.2. You must copy custom components you added to the TestStand 4.2 directory to the TestStand 4.2.1 directory. You can copy the configuration files you want to use from the TestStand 4.2 directory to the TestStand 4.2.1 directory, or you can configure TestStand 4.2.1 to use the files in the TestStand 4.2 directory or in an alternate shared directory.
    Use the TestStand Version Selector to switch to TestStand 4.2, 4.2.1, or any other version installed on the computer before you launch a TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    Refer to the TestStand Directory Structure section of Chapter 8, Customizing and Configuring TestStand, of the NI TestStand Reference Manual for the location of the , , and directories.
    You can install deployments for TestStand 4.2 and TestStand 4.2.1 on the same computer. Use the TestStand Version Selector to select the active version of TestStand before you launch the deployed TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    Refer to the List of Known Issues in TestStand 4.2.x on the National Instruments Web site for a list of known issues in TestStand 4.2.x.
    Use this Toggle Expansion button to expand or collapse the following sections. You must enable the Allow Blocked Content option in Microsoft Internet Explorer to collapse each section. You must expand each section you want to print or search.
    TestStand Engine
    TestStand Sequence Editor
    LabWindows/CVI
    Database
    Microsoft Visual Studio
    Miscellaneous
    TestStand Engine
    User Interfaces
    LabWindows/CVI
    ActiveX/COM Adapter
    C/C++ DLL Adapter
    Database
    Miscellaneous
    Refer to the Technical Support page at ni.com/support and search for TestStand to access the TestStand Support Web page, which contains online documentation, KnowledgeBase articles, tutorials, example code, discussion forums, and other resources.
    National Instruments, NI, ni.com, NI TestStand, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-12-8 08:06
