查看: 2687|回复: 0
[NI驱动程序] NI-488.2Driver15.1.1f0-Linux 美国国家仪器IEEE488.2仪器驱动15.1.1F0Linux系统版下载
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2020-3-1 12:37:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-488.2为使用NI GPIB控制器和带有GPIB端口的NI嵌入式控制器的客户提供支持。
    NI-488.2仪器驱动程序包含了几个实用程序,用于应用程序开发和调试。NI-488.2包含了可自动处理所有总线管理的高级命令,因而用户就无需了解GPIB硬件产品或IEEE 488.2协议的编程细节。为了提供最大灵活性和功能,NI-488.2还包含了底层命令。
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员登录后购买附件下载查看
    488.2 15.1.1f0-Linux.txt (592 Bytes, 下载次数: 0, 售价: 10 元)
    NI-488.2 for Linux Readme
    Version 15.1.1
    February 2016
    This file contains important information about the NI-488.2 software
    for Linux, including installation issues, compatibility issues, API
    changes from previous drivers, and a list of FAQs. Refer to the
    Installation Guide in the Documentation directory on your NI-488.2 for Linux
    media for information about installing the software.
    This file supersedes any discrepant information presented in other NI-488.2
    documentation. Refer to www.ni.com/linux for the most recent information
    about Linux support at National Instruments.
    Supported GPIB Interfaces
    Installation
    Description of Utilities
    C/C++ Language Interface
    Compatibility with LabVIEW
    Compatibility with Previous NI-488.2 Drivers
    Uninstallation
    FAQs
    Documentation and Help
    Bug Fixes and Enhancements
    Linux Limitations
    Support for 32-bit Linux Distributions
    This release of NI-488.2 for Linux software supports the following
    distributions:
    CentOS 7
    openSUSE 13.1
    openSUSE 13.2
    Red Hat Enterprise Linux 6
    Red Hat Enterprise Linux 7
    Scientific Linux 6
    An X Windows graphical environment is required to run graphical configuration
    and troubleshooting utilities.
    For more information about supported Linux versions and distributions supported
    by NI, refer to ni.com/linux.
    PCI-GPIB
    PCI-GPIB/LP
    NI PCIe-GPIB
    PCI-8212
    PCI-8232
    PXI-GPIB
    PXI-8212
    PXI-8232
    GPIB-ENET/100*
    GPIB-ENET/1000
    To configure a supported GPIB interface, refer to the Installation Guide
    located in /usr/local/natinst/ni4882/docs/.
    * The GPIB-ENET/1000 has replaced the GPIB-ENET/100. Support for the
      GPIB-ENET/100 may not be maintained in future versions of NI-488.2 for
      Linux. The GPIB-ENET/1000 should be used for new designs.
    Installation
    To install NI-488.2 software for Linux, log in as root, and run the INSTALL
    script from the mounted drive or tarball directory, as follows:
    ./INSTALL
    The INSTALL script ensures that all requirements are met, checks and
    uninstalls existing installations if necessary, and then installs the NI-488.2
    software.
    The script uses rpm to install the packages on systems that support it or
    extracts the files directly on other systems.
    gpibexplorer    - GPIB Explorer is used to browse, add, and delete GPIB
                      interfaces.
    gpibtsw         - GPIB Troubleshooting Wizard is used to verify your
                      hardware and software installation.
    gpibintctrl     - GPIB Interactive Control is used to communicate with
                      GPIB devices interactively.
    firmwareupdate  - GPIB Firmware Update is used to upgrade firmware
                      on a GPIB-ENET/100 interface.
    Refer to the NI-488.2 User Manual for more information about using these
    utilities.
    ni4882.h          - NI-488.2 header file
    libni4882.so      - Dynamic library
    ni4882.o          - Object file that allows explicit loading of libni4882.so
    NI4882 API Examples:
    To have the ni4882 library loaded implicitly on program startup:
       gcc prog.c -lni4882
       g++ prog.cpp -lni4882
    To have the ni4882 library loaded explicitly when the program makes the
    first call into the library:
       gcc prog.c ni4882.o -ldl
       g++ prog.cpp ni4882.o -ldl
    For more NI-488.2 API use examples, refer to
    /usr/local/natinst/ni4882/examples/Readme.txt.
    The legacy GPIB API, libgpibapi.so, is still available for compatibility with
    existing applications. It provides only 32-bit support, and is not recommended
    for new development.
    This version of driver was tested with LabVIEW 2013 SP1, LabVIEW 2014 SP1, and
    LabVIEW 2015.
    This installation of NI-488.2 software may have issues installing over
    some previous versions of the NI-488.2 Drivers.  You should manually uninstall
    previous NI-488.2 drivers before installing this software.
    Uninstallation
    To uninstall the NI-488.2 software for Linux, log in as root, and run the
    UNINSTALL script from the mounted drive or tarball directory, as follows:
    ./UNINSTALL
    FAQs
    Q1: What action do I need to take if I upgrade/change my kernel?
    A1: Some action is required to make the existing NI-488.2 installation
        work for the new kernel. After upgrading your kernel, run
        updateNIDrivers utility as root. The utility is located in
        /usr/local/bin. Be sure to have sources for your new kernel properly
        installed on your system before running the utility. The utility
        rebuilds the driver using the new kernel sources and copies it into
        the appropriate location for the new kernel. For the changes to take
        place, you will be asked to reboot your machine after the utility
        completes.  Note that NI-488.2 supports only kernels provided as part
        of the supported distributions listed above.
    Q2: When I try to open Help from GPIB Explorer, I am prompted for my default
        web browser. What does this do?
    A2: This problem only occurs on systems where htmlview is not installed.
        Each user's response to this dialog box is stored in "~/natinst/.lvbrowser"
        (where ~ is the user's home directory). If you need to change this
        response, you can edit this file or simply delete it so that you will
        be prompted again when entering help.
    Q3: When I launch GPIB Explorer from a prompt opened using 'su', I am unable to
        launch Interactive Control from the GPIB Explorer menu.
    A3: When elevating to root privileges, use 'su -' instead of 'su'. This will
        properly configure the environment for the root user, and will resolve the
        issue launching Interactive Control.
    Q4: When launching 'gpibexplorer' or 'gpibtsw' using 'sudo', I see an error
        similar to "Unable to open X display."
    A4: This can be resolved by granting access to the root user to utilize the
        current display, and passing the display information to the 'sudo'
        command, as shown below:
          xhost local:root
          sudo DISPLAY=$DISPLAY gpibexplorer
    Q5: Why can't I discover a GPIB-ENET/100 or GPIB-ENET/1000 device in GPIB
        Explorer?
    A5: It is likely that your firewall is blocking the discovery of the
        device. You can get around this by disabling the firewall during
        discovery. This can be reverted after you have added the device.
    Q6: During installation, I get a message similar to the following one:
        "Kernel source does not appear to be configured for the running kernel.
         Configuration of kernel source is required to continue installation."
        I do have kernel sources installed. Is there anything else I need to do?
    A6: This problem is known to affect SUSE Linux, but it is possible that other
        distributions require similar steps to resolve this problem.
        On openSUSE, complete the following steps:
           1. Ensure you have installed kernel-source and kernel-syms packages
              corresponding to the version of the currently running kernel. You
              can determine the currently running kernel version by issuing the
              command "uname -r".
           2. Change the directory to the /usr/src/linux- directory,
              where corresponds to the currently running kernel version.
           3. Run "zcat /boot/symvers-.gz > Module.symvers" as root to
              prepare modversion support.
           4. Run "make cloneconfig" as root to configure the sources for the
           5. Run "make modules_prepare" as root to prepare the headers for
              compilation.
           6. Run the NI-488.2 for Linux INSTALL script.
    Q7: When launching GPIB Explorer or GPIB Troubleshooting Wizard on 64 bit
         Linux, I get an error message about missing "libXinerama.so.1" or other
         libraries.
    A7: The runtime engine for the applications depends on 32 bit version of
        libXinerama and several other libraries. These are not installed by
        default on some 64 bit Linux distributions. To solve this error, the 32
        bit version of the reported libraries should be installed.
    Q8: When launching GPIB Explorer on 32 bit Linux with 4GB of memory or more, I
         get an error message about "libnipalu.so failed to initialize. Perhaps you
         need to run updateNIDrivers. Aborted".
    A8: The NI-488.2 core driver is not able to run on a 32-bit system with more
         than 4GB of addressable memory. The work around for this problem is to
         limit the usable memory in the system to 4GB of addressable space.
         To limit the system memory, complete the following steps:
            1. In the grub boot menu, select the Linux version and press 'e' to edit
               the commands.
            2. Append "mem=4GB", with space before the option, to the Linux kernel
               executable (vmlinuz) line.
            3. Boot the Linux OS.
    Q9: When installing NI-488.2 2.9.1 or later with NI-VISA pre-installed, I
         receive the error message: "ERROR: failed to build nipxirmk.ko. nipxirmk.ko
         failed to update."
    A9: NI-VISA prior to version 5.2.0 has a compatibility issue with one of the
         core components of NI-488.2 2.9.1 or later. To avoid this error, please
         upgrade NI-VISA to 5.2.0 or above before installing NI-488.2.
    Q10: Launching ethernetconfig or gpibintctrl through GPIB Explorer causes the
         text utilities to launch twice in different terminals.
    A10: This problem is due to a bug (#646317 bugzilla) in gnome-terminal
         (2.32.1-6.1). This causes GPIB Explorer to believe that gnome-terminal
         has failed to launch, so it re-launches the utility in another terminal.
         You can simply close the duplicated window or update gnome-terminal to
         version 3.2.1 or above.
    Q11: Why can't I discover GPIB-ENET/1000 devices connected through a Link-Local
         address in GPIB Explorer?
    A11: This problem occurs if the network connection on the system has been
         configured for DHCP but there is no available DHCP server on the network.
         To fix this issue, complete the following steps:
            1. Install avahi-autoipd.
            2. Configure the current network connection to allow Link-Local
               addresses. This can be achieved through the network connection
               configuration utility on the system. Either create a new connection
               or edit the currently active connection. Under IPv4 settings set
               the connection method to Link-Local only.
    Q12: Why do NI I/O Trace and NI-VISA utilities generate console errors,
         segmentation faults, or display a corrupted screen when run on OpenSUSE?
    A12: Incompatibilities between the LabVIEW 2014 Run-Time Engine and recent
         versions of libgnomeui cause utilities included with NI-488.2 to work
         incorrectly and generate console errors.
         To fix this issue, run disableLabVIEWGnomeUI.sh installed in the following
         path:
         /usr/local/natinst/ni4882/bin/disableLabVIEWGnomeUI.sh
         This script disables GNOME-specific implementations in the LabVIEW 2014
         Run-Time Engine, allowing applications that depend on it to load and
         display properly.
    You can access NI-488.2 Help from GPIB Explorer.
    Linux Limitations
    Some features discussed in the NI-488.2 documentation and help (for example,
    GPIB Analyzer, GPIB Ethernet Wizard) are unavailable on Linux.
    Power Management
    NI-488.2 software for Linux does not support power management.
    You must disable the power management settings or make sure all GPIB handles
    are offline before the system enters the power management modes.
    fork() System Call
    NI-488.2 software for Linux does not work with the fork() system call.
    Specifically, the interface and device handles opened by the parent process
    are not properly inherited by the child process. Any attempt to use already
    opened handles in the child process will result in a Segmentation Fault for
    the child process.  A workaround is either to open a new interface/device
    handle in the child process or use threads instead of processes to implement
    multitasking. Linux provides a POSIX-compliant thread library called pthreads.
    The following items are a subset of issues fixed in this and previous NI-488.2
    releases. If you have a CAR ID, you can search this list to validate the issue
    has been fixed.
    NI-488.2 FOR LINUX 15.1.1
    The following specific issue was fixed in this release:
       564904: NI-488.2 for Linux Version 15.1 fails to install if NI-PAL and NI-KAL
               15.1 or later are already installed.
    The fix included in the NI-488.2 for Linux 15.1.1 patch affects only new
    installations of NI-488.2 on systems with NI-PAL and NI-KAL 15.1 or later
    already installed. If you already have NI-488.2 for Linux 15.1 installed,
    there is no need to install the NI-488.2 15.1.1 patch.
    Updated Linux distribution support.
    NI-488.2 now reports GPIB controller interfaces through the NI System
    Configuration API.
    The following specific issues were fixed in this release:
       121091: Calling ibonl when a board level ibwait is in progress could result
               in application crash.
       121181: A deadlock might occur when attempting to use a board handle with
               pending ibonl call on another thread.
    NI-488.2 FOR LINUX 3.2
    Modified the integer types used in ni4882.h and libni4882.so. All uses of
    'unsigned long' have been replaced with 'unsigned int' to improve compatibility
    with 64-bit compilers. This API has never been documented with prior versions
    of NI-488.2 for Linux, but ni4882.h and a 32-bit version of libni4882.so were
    installed on the system. Any user utilizing these files should update their
    applications according to the updated function prototypes in ni4882.h. This
    change does not impact ni488.h or libgpibapi.so.
    Added 64-bit Application Interface. NI-488.2 for Linux, Version 3.2, adds a
    64-bit application interface that allows users to create 64-bit applications
    using libni4882.so. Using the 32-bit version of libni4882.so, users can use
    the same NI4882 API to build corresponding 32-bit applications with no source
    code changes. For more information about the new NI4882 API, refer to the
    NI-488.2 Help. You can access NI-488.2 Help from GPIB Explorer. To start GPIB
    Explorer from a terminal, enter the following command,
    /usr/local/bin/gpibexplorer. In GPIB Explorer, select
    Help>>NI-488.2 Help from the menu bar.
    NI I/O Trace functionality is limited to use with 32-bit GPIB APIs. As of this
    release, it does not function with 64-bit applications.
    The command line utility ethernetconfig has been replaced with an interactive
    utility accessible through gpibexplorer. Several usability improvements and bug
    fixes were also made in gpibexplorer.
       122997: The EOIP status bit could remain set incorrectly if an ibwrta or
               ibrda call returns an EDVR error.
       171688: An ibnotify callback could fail to be triggered by END if the notify
               condition included END but not CMPL.
       205182: Asynchronous transfers could sometimes report EABO even though the
               transfer completed successfully.
       359887: GPIB Help could not be opened from the GPIB Troubleshooting Wizard
               if it had not already been opened from GPIB Explorer.
       372832: A callback from ibnotify might not be invoked after an asynchronous
               transfer was completed if the notify mask only contained END.
       374822: Calling ibonl while ibnotify is pending could cause the process to
               crash under some circumstances.
       380705: Aborting an ibrda very quickly after starting it could allow a
               PCI-based GPIB interface to receive data when addressed as a
               listener, without a read in progress. This data was lost, and
               could not be recovered.
       404267: In some situations, the GPIB-ENET/1000 could hang while performing
               asynchronous transfers. This included fixes in both the NI-488.2
               driver and the GPIB-ENET/1000 firmware. Users of the GPIB-ENET/1000
               should update the GPIB-ENET/1000 firmware to version 1.1.0 to
               receive the full benefit of this fix.
       405414: In some cases the DCAS bit was not correctly cleared after being
               reported, causing it to be reported with subsequent calls.
       406437: GPIB Explorer and GPIB Troubleshooting Wizard could fail silently if
               needed libraries were missing from the system. They now provide more
               explicit error information if supporting libraries are missing.
       418661: In some situations, when an ibnotify callback function was triggered
               due to the completion of an asynchronous transfer, the ibcnt and
               ibcntl variables would be incorrect.
       425931: Calling ibstop with an asynchronous operation in progress would
               sometimes not report an EABO error as expected.
    NI-488.2 FOR LINUX 2.9.1
    Added support for the GPIB-ENET/1000.
    The serial number of a GPIB-ENET/100 can now be queried using the ibask
    function call.
    NI Spy has been replaced with NI I/O Trace.
    258317: GPIB Explorer could incorrectly display an error indicating an
            installation problem if no NI GPIB hardware was installed in the
            system. This has been fixed.
    257930: Adjust the layout in GPIB Explorer to avoid display problems in some
            Linux distribution.
    231554: In multi-threaded use cases, a small amount of memory was leaked from
            each thread which made calls into the NI-488.2 driver. This has been
            fixed.
    186438: In some multi-process use cases, the bus was not properly readdressed
            and caused EADR errors. This has been fixed.
    182620: PCI-based GPIB interfaces (PCI, PCIe, PMC, PXI) were not waiting the
            recommended time of 1.5 ms for instruments to respond to ibln() and
            FindLstn() calls. This typically would affect only older instruments
            with significantly slow response time and does not affect most recent
            instruments. This has been fixed.
    173210: BIOS incompatibilities on some systems prevented PXI-GPIB DMA from
            functioning properly across a MXI-Express link. Affected systems
            would fail all transfers larger than 32 bytes when configured for DMA
            mode. This has been fixed.
    139493: Upgrading from NI-488.2 2.5.1 to a newer version of the driver left
            behind references to gpibprtk.ko. This has been fixed.
    93563: When htmlview is available, user is no longer required to specify a
           web browser path to open help files.
    93417: Large transfers may fail on machine with over 4GB of Memory.
    57772: GPIB Explorer could not launch on RedHat 5 with SELinux enabled. This has
           been fixed.
    NI-488.2 Drops Support for 32-bit Linux Distributions in 2016
    NI-488.2 will drop support for Intel 32-bit versions of Linux distributions
    as of July 1, 2016. Versions of NI-488.2 that ship after July 1, 2016 may
    install and execute on Intel 32-bit distributions, but official support is
    not provided.
    COPYRIGHT:
    (c) 2007-2016 National Instruments.
    All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted
    in any form, electronic or mechanical, including photocopying, recording,
    storing in an information retrieval system, or translating, in whole or in
    part, without the prior written consent of National Instruments Corporation.
    NI respects the intellectual property of others, and we ask
    our users to do the same. NI software is protected by copyright and other
    intellectual property laws. Where NI software may be used to reproduce
    software or other materials belonging to others, you may use NI software
    only to reproduce materials that you may reproduce in accordance with the
    terms of any applicable license or other legal restriction.
    If you are an agency, department, or other entity of the United States
    Government ("Government"), the use, duplication, reproduction, release,
    modification, disclosure or transfer of the technical data included in this
    manual is governed by the Restricted Rights provisions under Federal
    Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal
    Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for
    military agencies.
    Content from the IVI specifications reproduced with permission from the IVI
    Foundation.
    The IVI Foundation and its member companies make no warranty of any kind with
    regard to this material, including, but not limited to, the implied warranties
    of merchantability and fitness for a particular purpose. The IVI Foundation and
    its member companies shall not be liable for errors contained herein or for
    incidental or consequential damages in connection with the furnishing,
    performance, or use of this material.
    Credits
    The following section summarizes the third party software used by this product.
    DOCUMENTATION NOTICE FOR SOCKET++ LICENSE
    This product includes code from Socket++ 1.10 licensed by a third party or
    parties pursuant to the Socket++ License, and that is subject to the following
    notice(s):
    Copyright (C) 1992,1993,1994 Gnanasekaran Swaminathan
    Permission is granted to use at your own risk and distribute this software in
    source and binary forms provided the above copyright notice and this paragraph
    are preserved on all copies. This software is provided "as is" with no express
    or implied warranty.
    DOCUMENTATION NOTICE FOR THE ZLIB LICENSE
    This product includes code from TinyXML 2.6.1 licensed by a third party or
    parties pursuant to the zlib software license, and that is subject to the
    following notice(s):
    Original code (2.0 and earlier)copyright (c) 2000-2006
    Lee Thomason (www.grinninglizard.com)
    This software is provided 'as-is', without any express or implied warranty.  In
    no event will the authors be held liable for any damages arising from the use of
    this software.
    Permission is granted to anyone to use this software for any purpose, including
    commercial applications, and to alter it and redistribute it freely, subject to
    the following restrictions:
    1. The origin of this software must not be misrepresented; you must not claim
    that you wrote the original software. If you use this software in a product, an
    acknowledgment in the product documentation would be appreciated but is not
    required.
    2. Altered source versions must be plainly marked as such, and must not be
    misrepresented as being the original software.
    3. This notice may not be removed or altered from any source distribution.
    DOCUMENTATION NOTICE FOR THE BSD 2-CLAUSE LICENSE
    This product includes code from tinydir 1.0 licensed by a third party or parties
    pursuant to the 2-clause BSD license, and that is subject to the following
    notice(s):
    Copyright (c) 2013, Cong Xu
    Redistribution and use in source and binary forms, with or without modification,
    are permitted provided that the following conditions are met:
       1. Redistributions of source code must retain the above copyright notice,
       this list of conditions and the following disclaimer.
       2. Redistributions in binary form must reproduce the above copyright notice,
       this list of conditions and the following disclaimer in the documentation
       and/or other materials provided with the distribution.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER ''AS IS'' AND ANY EXPRESS OR
    IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
    MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
    SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
    PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY
    , WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
    OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    OF THE POSSIBILITY OF SUCH DAMAGE.
    The views and conclusions contained in the software and documentation are those
    of the authors and should not be interpreted as representing official policies,
    either expressed or implied, of THE COPYRIGHT HOLDER.
    DOCUMENTATION NOTICE FOR APACHE LICENSE (2.0)
    This product includes code from mDNSResponder licensed by a third party or
    parties pursuant to the Apache License, Version 2.0, and that is subject to the
    Licensed under the Apache License, Version 2.0 (the "License"); you may not use
    this file except in compliance with the License. You may obtain a copy of the
    License at
    http://www.apache.org/licenses/LICENSE-2.0
    Unless required by applicable law or agreed to in writing, software distributed
    under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
    CONDITIONS OF ANY KIND, either express or implied. See the License for the
    specific language governing permissions and limitations under the License.
    Copyright (c) 1997-2006 Apple Computer, Inc. All rights reserved.
    DOCUMENTATION NOTICE FOR THE BSD 3-CLAUSE LICENSE
    parties pursuant to the 3-clause BSD license, which can be found below and that
    is subject to the following notice(s):
    Redistributions of source code must retain the above copyright notice, this list
    Redistributions in binary form must reproduce the above copyright notice, this
    list of conditions and the following disclaimer in the documentation and/or
    Neither the name of Apple Computer, Inc. nor the names of its contributors may
    be used to endorse or promote products derived from this software without
    specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
    ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
    WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
    DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
    ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
    (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
    ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
    SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    DOCUMENTATION NOTICE FOR THE NICTA PUBLIC SOFTWARE LICENSE
    parties pursuant to the NICTA Public Software License, which can be found below
    and that is subject to the following notice(s):
    This software is licensed under the NICTA Public Source License version 1.0
    NICTA Public Software Licence
    Version 1.0
    Copyright © 2004 National ICT Australia Ltd
    By this licence, National ICT Australia Ltd (NICTA) grants permission, free of
    charge, to any person who obtains a copy of this software and any associated
    documentation files ("the Software") to use and deal with the Software in source
    code and binary forms without restriction, with or without modification, and to
    permit persons to whom the Software is furnished to do so, provided that the
    of conditions and the following disclaimers.
    list of conditions and the following disclaimers in the documentation and/or
    The name of NICTA may not be used to endorse or promote products derived from
    this Software without specific prior written permission.
    EXCEPT AS EXPRESSLY STATED IN THIS LICENCE AND TO THE FULL EXTENT PERMITTED BY
    APPLICABLE LAW, THE SOFTWARE IS PROVIDED "AS-IS" AND NICTA MAKES NO
    REPRESENTATIONS, WARRANTIES OR CONDITIONS OF ANY KIND, EXPRESS OR IMPLIED,
    INCLUDING, WITHOUT LIMITATION, ANY REPRESENTATIONS, WARRANTIES OR CONDITIONS
    REGARDING THE CONTENTS OR ACCURACY OF THE SOFTWARE, OR OF TITLE,
    MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, NONINFRINGEMENT, THE ABSENCE
    OF LATENT OR OTHER DEFECTS, OR THE PRESENCE OR ABSENCE OF ERRORS, WHETHER OR NOT
    DISCOVERABLE.
    TO THE FULL EXTENT PERMITTED BY APPLICABLE LAW, IN NO EVENT WILL NICTA BE LIABLE
    ON ANY LEGAL THEORY (INCLUDING, WITHOUT LIMITATION, NEGLIGENCE) FOR ANY LOSS OR
    DAMAGE WHATSOEVER, INCLUDING (WITHOUT LIMITATION) LOSS OF PRODUCTION OR
    OPERATION TIME, LOSS, DAMAGE OR CORRUPTION OF DATA OR RECORDS; OR LOSS OF
    ANTICIPATED SAVINGS, OPPORTUNITY, REVENUE, PROFIT OR GOODWILL, OR OTHER ECONOMIC
    LOSS; OR ANY SPECIAL, INCIDENTAL, INDIRECT, CONSEQUENTIAL, PUNITIVE OR EXEMPLARY
    DAMAGES ARISING OUT OF OR IN CONNECTION WITH THIS LICENCE, THE SOFTWARE OR THE
    USE OF THE SOFTWARE, EVEN IF NICTA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
    DAMAGES.
    If applicable legislation implies warranties or conditions, or imposes
    obligations or liability on NICTA in respect of the Software that cannot be
    wholly or partly excluded, restricted or modified, NICTA's liability is limited,
    to the full extent permitted by the applicable legislation, at its option, to:
    a. in the case of goods, any one or more of the following:
      i. the replacement of the goods or the supply of equivalent goods;
      ii. the repair of the goods;
      iii. the payment of the cost of replacing the goods or of acquiring equivalent
         goods;
      iv. the payment of the cost of having the goods repaired; or
    b. in the case of services:
      i. the supplying of the services again; or
      ii. the payment of the cost of having the services supplied again.
    DOCUMENTATION NOTICE FOR OPENSSL
    parties pursuant to the OpenSSL software license, which can be found below and
    Copyright (c) 1998-2008 The OpenSSL Project.  All rights reserved.
    Copyright (C) 1995-1998 Eric Young (eay@cryptsoft.com). All rights reserved.
    This product includes software developed by the OpenSSL Project for use in the
    OpenSSL Toolkit (http://www.openssl.org/).
    This product includes cryptographic software written by Eric Young
    This product includes software written by Tim Hudson (tjh@cryptsoft.com).
    * Copyright (c) 1998-2008 The OpenSSL Project. All rights reserved.
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    * 1. Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * 2. Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in
    * the documentation and/or other materials provided with the
    * distribution.
    * 3. All advertising materials mentioning features or use of this
    * software must display the following acknowledgment:
    * "This product includes software developed by the OpenSSL Project
    * for use in the OpenSSL Toolkit. (http://www.openssl.org/)"
    * 4. The names "OpenSSL Toolkit" and "OpenSSL Project" must not be used to
    * endorse or promote products derived from this software without
    * prior written permission. For written permission, please contact
    * openssl-core@openssl.org.
    * 5. Products derived from this software may not be called "OpenSSL"
    * nor may "OpenSSL" appear in their names without prior written
    * permission of the OpenSSL Project.
    * 6. Redistributions of any form whatsoever must retain the following
    * acknowledgment:
    * for use in the OpenSSL Toolkit (http://www.openssl.org/)"
    * THIS SOFTWARE IS PROVIDED BY THE OpenSSL PROJECT ``AS IS'' AND ANY
    * EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
    * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE OpenSSL PROJECT OR
    * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
    * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
    * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
    * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
    * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
    * This product includes cryptographic software written by Eric Young
    * (eay@cryptsoft.com). This product includes software written by Tim
    * Hudson (tjh@cryptsoft.com).
    /* Copyright (C) 1995-1998 Eric Young (eay@cryptsoft.com)
    * All rights reserved.
    * This package is an SSL implementation written
    * by Eric Young (eay@cryptsoft.com).
    * The implementation was written so as to conform with Netscapes SSL.
    * This library is free for commercial and non-commercial use as long as
    * the following conditions are aheared to. The following conditions
    * apply to all code found in this distribution, be it the RC4, RSA,
    * lhash, DES, etc., code; not just the SSL code. The SSL documentation
    * included with this distribution is covered by the same copyright terms
    * except that the holder is Tim Hudson (tjh@cryptsoft.com).
    * Copyright remains Eric Young's, and as such any Copyright notices in
    * the code are not to be removed.
    * If this package is used in a product, Eric Young should be given attribution
    * as the author of the parts of the library used.
    * This can be in the form of a textual message at program startup or
    * in documentation (online or textual) provided with the package.
    * are met:
    * 1. Redistributions of source code must retain the copyright
    * notice, this list of conditions and the following disclaimer in the
    * documentation and/or other materials provided with the distribution.
    * 3. All advertising materials mentioning features or use of this software
    * must display the following acknowledgement:
    * "This product includes cryptographic software written by
    * Eric Young (eay@cryptsoft.com)"
    * The word 'cryptographic' can be left out if the rouines from the library
    * being used are not cryptographic related :-).
    * 4. If you include any Windows specific code (or a derivative thereof) from
    * the apps directory (application code) you must include an acknowledgement:
    * "This product includes software written by Tim Hudson (tjh@cryptsoft.com)"
    * THIS SOFTWARE IS PROVIDED BY ERIC YOUNG ``AS IS'' AND
    * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
    * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
    * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
    * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
    * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
    * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
    * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
    * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
    * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
    * SUCH DAMAGE.
    * The licence and distribution terms for any publically available version or
    * derivative of this code cannot be changed. i.e. this code cannot simply be
    * copied and put under another distribution licence
    * [including the GNU Public Licence.]
    TRADEMARKS:
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for
    information on NI trademarks. Other product and company names
    mentioned herein are trademarks or trade names of their respective companies.
    PATENTS:
    For patents covering the NI products/technology, refer to the
    appropriate location: Help» Patents in your software, the patents.txt file on
    your media, or the NI Patent Notice at ni.com/patents.
    GMT+8, 2025-7-2 05:36
