查看: 3086|回复: 0
[NI驱动程序] NI-488.2Driver17.0 Mac OS X 美国国家仪器IEEE488.2仪器驱动17.0苹果系统版下载
    12 小时前
  • 签到天数: 3668 天
    连续签到: 30 天
    发表于 2020-3-1 17:19:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-488.2为使用NI GPIB控制器和带有GPIB端口的NI嵌入式控制器的客户提供支持。
    NI-488.2仪器驱动程序包含了几个实用程序,用于应用程序开发和调试。NI-488.2包含了可自动处理所有总线管理的高级命令,因而用户就无需了解GPIB硬件产品或IEEE 488.2协议的编程细节。为了提供最大灵活性和功能,NI-488.2还包含了底层命令。
    链接:请注册视觉论坛会员登录后购买附件下载查看  提取码: 请购买附件下载查看
    提取码:请购买附件下载查看
    请购买附件下载查看链接
    488.2 17.0mac.txt (588 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-488.2 Version 17.0.0 for macOS Readme
    May 2017
    This file contains important information about NI-488.2 for macOS, including installation instructions, new features, and a partial list of bugs fixed for NI-488.2.
    Refer to ni.com for the latest information about NI-488.2.
    Driver Version Naming Changes
    List of Features not Supported in macOS
    Enhancements and Bug Fixes
    • Version 17.0
    • Version 15.5
    • Version 14.1
    • Version 3.0.1
    NI-488.2 supports the following operating systems:
    • Mac OS X version 10.11
    • macOS version 10.12
    The following table lists the NI application software versions, including service packs, supported by NI-488.2.
    NI Application SoftwareVersions Supported by This Release
    NI LabVIEW2016, 2017
    NI-VISA17.0
    Note:  NI I/O Trace 17.0 and later support NI-488.2 17.0. Previous versions of NI I/O Trace do not support NI-488.2 17.0 or later.
    The following list contains the NI hardware supported by NI-488.2 on macOS:
    • PCIe-GPIB
    • GPIB-USB-HS
    • GPIB-USB-HS+1
    • NI ExpressCard-GPIB
    • GPIB-ENET/1002
    • GPIB-ENET/1000
    1Analyzer functionality is not supported.
    2The GPIB-ENET/1000 has replaced the GPIB-ENET/100. Support for the GPIB-ENET/100 may not be maintained in future versions of NI-488.2 on macOS. The GPIB-ENET/1000 should be used for new designs.
    Refer to the NI-488.2™ for Mac OS X Getting Started Guide on the NI-488.2 for Mac OS X install media for installation instructions and system requirements.
    Uninstallation
    To uninstall NI-488.2 for Mac OS X, refer to Uninstall.txt in the /Applications/National Instruments/NI-488.2 directory on the system.
    NI-488.2 versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-488.2 for Windows 14.0 is the version of NI-488.2 released with LabVIEW 2014. The last version of NI-488.2 released under the old numbering scheme is NI-488.2 for Linux 3.2. The first version released under the new numbering scheme is NI-488.2 for Windows 14.0.
    The following features of NI-488.2 supported on Windows are not supported on Mac OS X:
    • GPIB analyzer support
    Known IssuesPower Management and Energy Saver Modes
    NI-488.2 for Mac OS X does not support power management. You must disable the Energy Saver Sleep Modes or make sure all GPIB handles are offline before the system enters Sleep Mode.
    Upgrading NI-488.2
    When upgrading NI-488.2 15.5 to later versions of NI-488.2, you may see a kernel panic on the initial boot after the upgrade. Refer to KB 7J6ELBBO for more details.
    Enhancements and Bug Fixes in Version 17.0
    NI-488.2 version 17.0 adds support for macOS 10.12 and LabVIEW 2017.
    Enhancements and Bug Fixes in Version 15.5Support for OS X 10.11
    NI-488.2 for Mac OS X, Version 15.5 adds support for OS X 10.11.
    Self-Test and Device Reset features are now available for all GPIB interfaces from within MAX.
    Self-Test and Device Reset features are now available for all GPIB interfaces from within Measurement & Automation Explorer (MAX). GPIB interfaces may be tested using the Self-Test feature, or tested programmatically through the System Configuration API. The Device Reset feature resets the selected GPIB hardware.
    Note:  Although the NI-488.2 Troubleshooting Wizard remains available in this release, the functionality is deprecated in favor of the Self-Test feature.
    Performance of MAX has been improved.The GPIB-ENET/1000 configuration page can be launched using the Device Configuration command in MAX.The following issues were resolved in NI-488.2 15.5.
    12109: Calling ibonl when a board level ibwait is in progress could result in application crash.
    121181: A deadlock might occur when attempting to use a board handle with pending ibonl call on another thread.
    433395: Extra delay on ibwait and ibstop was removed for GPIB Ethernet-based hardware.
    478063: GPIB-USB-HS+ might become unresponsive upon rebooting in a virtual machine.
    518983: As a result of an issue introduced in NI-488.2 14.1, GPIB-USB-HS I/O bus communication can hang until the handle to the GPIB interface is closed when all of the following conditions are true:
    • The affected interface is not CIC (Controller in Charge)
    • A read or write is in progress
    • An ibwait including the DCAS bit is in progress
    • A device clear is received during the I/O transfer
    545813: On OS X 10.11, signal termination (for example, Control + C) of a pending ibwrt with a large buffer causes subsequent ibfind to fail for GPIB-USB-HS.
    546910: GPIB Explorer and Troubleshooting Wizard fail to launch after upgrading from 3.0.1 or below to 14.1 on Mac OS X 10.11.
    Enhancements and Bug Fixes in Version 14.1Updated integer types in ni4882.h
    Modified the integer types used in ni4882.h and NI4882.Framework. All uses of unsigned long have been replaced with unsigned int to improve compatibility with 64-bit compilers. This API has never been documented with prior versions of NI-488.2 for Mac OS X, but ni4882.h and a 32-bit version of NI4882.framework were installed on the system. Any user utilizing these files should update their applications according to the updated function prototypes in ni4882.h. This change does not impact ni488.h or NI488.framework.
    Note:  This change remains binary compatible with any user who may have previously compiled against NI4882.Framework.
    New 64-bit Application Interface
    NI-488.2 for Mac OS X, Version 14.1, adds a 64-bit application interface that allows users to create 64-bit applications using the NI4882 framework. Using the 32-bit version of NI4882 framework, users can use the same NI4882 API to build corresponding 32-bit applications with no source code changes. For more information about the new NI4882 API, refer to the NI-488.2 Help. You can access NI-488.2 Help from GPIB Explorer by selecting Help»Help Topics»NI-488.2 from the menu bar.
    Added NI-MAX and NI-VISA
    NI-488.2 for Mac OS X, Version 14.1, installs NI-VISA and NI-MAX by default. Installation can be customized by selecting Customize button during the Installation Type step.
    Support for NI System Configuration API
    NI-488.2 now reports GPIB controller interfaces through the NI System Configuration API.
    The following issues were resolved in NI-488.2 for Mac OS X, Version 14.1.
    122997: The EOIP status bit could remain set incorrectly if an ibwrta or ibrda call returned an EDVR error.
    171688: An ibnotify callback could fail to be triggered by END if the notify condition included END but not CMPL.
    205182: Asynchronous transfers could sometimes report EABO even though the transfer completed successfully.
    240000: On GPIB-USB-B and GPIB-USB-HS controllers, ibwait and ibnotify could fail to detect the CIC, LACS, and TACS bits.
    332479: On GPIB-USB-B and GPIB-USB-HS controllers, the first I/O operation after device insertion could be terminated prematurely.
    374822: Calling ibonl while ibnotify is pending could cause the process to crash under some circumstances.
    380705: Aborting an ibrda very quickly after starting it could allow a PCI-based GPIB interface to receive data when addressed as a listener, without a read in progress. The data is then lost and cannot be recovered.
    394848: If a GPIB controller is connected to a USB port on a Thunderbolt display, disconnecting and then reconnecting the display can cause the host machine to become unresponsive.
    404267: In some situations, the GPIB-ENET/1000 could hang while performing asynchronous transfers. This included fixes in both the NI-488.2 driver and the GPIB-ENET/1000 firmware. Users of the GPIB-ENET/1000 should update the GPIB-ENET/1000 firmware to version 1.1.0 to receive the full benefit of this fix.
    405414: In some cases the DCAS bit was not correctly cleared after being reported, causing it to be reported with subsequent calls.
    425931: Calling ibstop with an asynchronous operation in progress would sometimes not report an EABO error as expected.
    Enhancements and Bug Fixes in Version 3.0.1Support for 64-bit Mac OS X Kernel
    NI-488.2 for Mac OS X now functions when using a 64-bit Mac OS X kernel.
    Support for GPIB-ENET/1000 Controllers
    The GPIB-ENET/100 has been replaced by the GPIB-ENET/1000. The GPIB-ENET/1000 is configured using a web interface. This interface may be launched from within GPIB Explorer, or by discovering the GPIB-ENET/1000 web server using the BonJour pane in the Safari web browser.
    Revised Method for Configuring GPIB Ethernet Devices
    The standalone Ethernet Config and Firmware Update utilities are no longer installed. Ethernet devices are now discovered and configured from within GPIB Explorer. NI-488.2 for Mac OS X no longer includes a utility to update the firmware on a GPIB-ENET/100 device. Should you require this capability, contact National Instruments for support.
    Replacing NI Spy
    NI Spy is replaced by NI I/O Trace.
    Refer to the NI-488.2 Help, accessible from the GPIB Explorer by selecting Help»NI-488.2 Help from the menu bar.
    Legal InformationCopyright
    © 1995–2017 National Instruments. All rights reserved.
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    375739B-01
    GMT+8, 2025-9-30 22:01
