查看: 3641|回复: 0
[NI驱动程序] NI-VISA2.5.2 Win32ENG 美国国家仪器虚拟仪器软件架构VISA2.5.2Windows版下载
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2020-3-3 11:01:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA2.5.2完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA2.5 Runtime:
    提取码:请购买附件下载查看
    NI-VISA2.5.2完整版:
    请购买附件下载查看
    NI-VISA2.5.2 Runtime:
    请购买附件下载查看
    NI-VISA2.5 Runtime:
    请购买附件下载查看
    VISA2.5.2Win.txt (945 Bytes, 下载次数: 0, 售价: 10 圆)
    This directory contains the following files:
    00readme.txt -- An ASCII file that gives driver information including installation procedures, bug fixes and errata.
    nivisa25.zip -- A compressed archive containing the installation for NI-VISA(TM) Software for Windows, Version 2.5. You will need to use a utility like WinZip or PKUnzip to open the archive and decompress the files.
    -------        Readme.txt --------
    National Instruments NI-VISA(TM) Software for Windows. Version 2.5.
    Copyright (c) 1995-2000 National Instruments Corporation. All rights reserved.
    CONTENTS OF THIS FILE
    Installing and Uninstalling NI-VISA 2.5
    LabWindows(TM)/CVI Run-Time Engine
    Support for new VISA Features
    Support for Multiple GPIB-VXI Controllers
    Support for Agilent/HP Controllers
    Using viPeekXX/viPokeXX Macros
    Improvements and Bug Fixes
    INSTALLING AND UNINSTALLING NI-VISA 2.5
    In general, we strongly recommend that you uninstall any currently installed
    versions of VISA before installing NI-VISA 2.5.
    After uninstalling NI-VISA, some DLLs and executables may remain in the
    NI-VISA directories. To complete the uninstall process, you must restart your
    machine. Note: the uninstaller application will not notify you when rebooting
    is necessary. If you plan to re-install NI-VISA, you should always reboot
    the machine after running the uninstaller.
    LABWINDOWS/CVI RUN-TIME ENGINE
    The Setup program now automatically installs the LabWindows/CVI Run-Time
    Engine when necessary. The NI-VISA interactive utility, VISAIC, requires the
    LabWindows/CVI Run-Time Engine 5.5 or later to be installed. When you install
    this utility, Setup also installs the LabWindows/CVI Run-Time Engine if it is
    not already present.
    SUPPORT FOR NEW VISA FEATURES
    The online help describes the new features of NI-VISA 2.5, but they are
    briefly listed here for your convenience.
    The VXI and GPIB functionality in NI-VISA 2.5 has been greatly expanded.
    There is a new VXI BACKPLANE resource for each VXI or GPIB-VXI chassis.
    There is a new GPIB INTFC resource for each GPIB board; this provides
    equivalent functionality to the NI-488 board-level functions. The online
    help lists all operations, attributes, and events that each VISA resource
    class supports.
    There is new functionality for Ethernet using raw (TCPIP::host::port::SOCKET)
    or VXI-11 (TCPIP::host::INSTR) protocols.
    NI-VISA 2.5 now supports Windows 2000 in addition to Windows NT, 98, and 95.
    NI-VISA 2.5 updates LabVIEW 5.x, LabWindows/CVI 5.x, and BridgeVIEW 2.x with
    the new VISA features.
    The best way to explore the new features is to use the Measurement&Automation
    Explorer, right-click on the new resource types, and click "Open VISA Session"
    to view the available operations, events, and attributes.
    SUPPORT FOR MULTIPLE GPIB-VXI CONTROLLERS
    NI-VISA supports multiple GPIB-VXI controllers in a single system. Because the
    National Instruments GPIB-VXI controller ships with a primary address of 1,
    NI-VISA automatically searches for any GPIB-VXI controllers at that address.
    If you have changed the primary address (for example, if you added a second
    GPIB-VXI controller to your system, and set the address of the second
    controller to 9), or if you have a GPIB-VXI controller from another vendor,
    you need to add it using Measurement&Automation Explorer so NI-VISA can find
    it. Right-click on "Devices and Interfaces" and select "Create New..." to add
    a new GPIB-VXI interface. Specify the controller's GPIB primary and secondary
    addresses, as well as the GPIB board to which it is connected. Then specify a
    new GPIB-VXI interface number and its logical address (usually 0).
    If you are using a GPIB-VXI command module from another vendor, you also need
    to obtain and install that vendor's VISA GPIB-VXI component.
    If you have a GPIB device at primary address 1 and that device does not
    recognize "*IDN?", you should disable the GPIB-VXI auto-detect feature in
    Measurement&Automation Explorer from the Tools>>NI-VISA>>VISA Options menu.
    SUPPORT FOR AGILENT/HP CONTROLLERS
    NI-VISA now has the capability to work with Agilent/HP GPIB and VXI controller
    cards. To use this feature, go into the Measurement&Automation Explorer, use
    the VISA Passport editor from the Tools>>NI-VISA>>Passport Editor menu, and
    enable the NiVisaTulip.dll Passport. NI-VISA will automaticaly find and access
    any GPIB or VXI devices. However, NI-VISA will not configure the Agilent/HP
    hardware; you must continue to do that with the Agilent/HP I/O Config utility.
    If you have both National Instruments and Agilent/HP controllers in the same
    system, you must configure the cards at different system addresses, such as
    GPIB0 and GPIB1. If both vendors try to use the same interface address,
    NI-VISA will report an error from viFindRsrc or VISA Find Resources.
    USING viPeekXX/viPokeXX MACROS
    Users who want to use the viPeekXX/viPokeXX macros for platforms on which the
    macros are available must define a macro called NIVISA_PEEKPOKE before
    including "visa.h". Please note that the macros are currently available only
    on the following platforms:
    - Win32 (All C compilers)
    - Solaris (LabWindows/CVI only)
    If you have used these macros with a version of NI-VISA prior to 2.0, your
    application will continue to run, but the peek/poke performance will decrease.
    You should relink with the libraries supplied with this installation to regain
    the prior peek/poke performance.
    IMPROVEMENTS AND BUG FIXES
    GPIB performance has improved. Its performance is now identical to NI-488.
    If you are using the GPIB-ENET controller, the previous version of NI-VISA
    would take a minute or more to time out if a GPIB-ENET controller were not
    connected or powered on. The timeout is now much shorter.
    Serial performance has improved. It no longer consumes excessive CPU time
    during read operations when the data is not immediately available.
    The VISA serial driver now works with baud rates higher than 256000. NI-VISA
    will allow any baud rate that the Windows driver will accept.
    If you set the Flow Control serial setting in T&M Explorer, it was not stored
    properly. This has been fixed in Measurement&Automation Explorer.
    This version of NI-VISA incorporates general bug fixes and improvements for
    GPIB-VXI. The NI-VISA code instrument will now load properly in configurations
    where it previously failed.
    If a GPIB-VXI chassis is reset while an application has VISA loaded, the
    GPIB-VXI would previously become accessible only as GPIB but not GPIB-VXI.
    This release of NI-VISA will now properly re-detect the GPIB-VXI.
    Fixed bug with the GPIB-VXI and hardware triggers.
    Fixed bug for PXI in Windows NT where it would occasionally crash on exit.
    Fixed bug for PXI where repeated calls to viOpen or VISA Open would
    occasionally return an undocumented status code.
    The documentation now includes resource strings and valid parameter values
    for PXI operations.
    The PXI Driver Development Wizard will now also generate a .inf file for
    Windows 2000.
    formatted I/O, especially with very large buffers and with the following
    modifiers: "%b", ",", "#", "!ob", "!ol", and "%[".
    The documentation for viPrintf and viFlush better describes when formatted
    I/O buffers are sent. The documentation for viScanf better describes the ","
    and "#" modifiers.
    Added capability to see low-level VISA formatted I/O buffers in NI Spy.
    Improved NI Spy performance when capturing calls, logging to disk, and
    opening files.
    Fixed bug with starting NI Spy while DLL's are in use.
    Fixed bugs in NI Spy where invalid buffer addresses or invalid buffer sizes
    would previously cause NI Spy to crash.
    Fixed installer bugs where the PATH and VXIPNPPATH environment variables were
    occasionally incorrect, especially with long directory names on Windows 95/98.
    KNOWN ISSUES
    Installing this on a system with NI-VISA 2.01 might remove T&M Explorer even
    if NI-VXI is installed.
    GMT+8, 2026-2-3 04:40
