查看: 3867|回复: 0
[NI驱动程序] NI-VISA18.5 Windows Driver美国国家仪器虚拟仪器软件架构VISA18.5 Windows版驱动下载
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2020-3-3 22:04:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA18.5完整版和运行时:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA18.5完整版和运行时:
    请购买附件下载查看
    VISA18.5W.txt (959 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VISA 18.5 for Windows Readme
    September 2018
    This file contains important information about NI-VISA, including supported platforms, new features, and information about bugs fixes and known issues for NI-VISA 18.5.
    Note: The Measurement Studio VisaNS .NET class library is being deprecated and superseded by an IVI-compliant NI-VISA .NET API. Refer to the New Features section for more information.
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, Serial, Ethernet, and/or USB interfaces.
    NI-VISA 18.5 for Windows supports the following platforms:
    • Windows 10 x86, x64
    • Windows 8.11 x86, x64
    • Windows 7 SP12 x86, x64
    • Windows Embedded Standard 7 SP12 x86, x64
    • Windows Server 2008 R2 (64-bit version only)3
    • Windows Server 2012 R2 (64-bit)1, 3
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • NI Linux® Real-Time
    • LabVIEW NXG 2.0, 2.1, 3.0
    While this distribution targets all of these platforms, you can run setup.exe only on the Windows variants.
    3 NI-VISA does not support the Windows Server non-R2 editions.
    Note  In 2016 NI-VISA dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-VISA will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-VISA to an unsupported OS. Additionally, after installing NI-VISA, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-VISA 18.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-VISA
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW NXG2.0, 2.1, 3.0
    LabWindows/CVI2012 and later
    Measurement Studio2013
    Microsoft Visual Studio Support for the IVI-Compliant NI-VISA .NET Class Library
    If you are using the IVI-compliant NI-VISA .NET Class Library, the .NET 4.6.2 Framework (minimum) is required. You can use the NI-VISA .NET Class Library with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET 4.0 Framework or later. You can use the NI-VISA .NET Class Library in 32-bit or 64-bit applications.
    Microsoft Visual Studio Support for the VisaNS .NET Class Library
    Note: The Measurement Studio VisaNS .NET Class Library is being deprecated and superseded by an IVI-compliant NI-VISA .NET Class Library. Refer to the New Features section for more information.
    The following table lists the programming languages and Microsoft Visual Studio versions supported by this version of the VisaNS .NET Class Library. Earlier versions of NI-VISA support other application software and language versions. For more information on Visual Studio compatibility with earlier versions of VISA, refer to ni.com/info and enter the info code NETlegacydrivers. To find and download an earlier version of a driver, refer to ni.com/downloads.
    Programming LanguageVisual Studio Versions Supported by VisaNS
    .NET Framework 4.0 Languages
    (Visual C# and Visual Basic .NET)
    2010
    .NET Framework 4.5 Languages
    2012
    .NET Framework 4.5.1 Languages
    2013
    Installation InstructionsInstalling NI-VISA for LabVIEW
    You can install all of your LabVIEW products—including NI-VISA—using the LabVIEW 2018 Platform media.
    Before you install NI-VISA 18.5, NI recommends that you uninstall any versions of VISA prior to NI-VISA 2.0.1.
    After uninstalling NI-VISA, some DLLs and executables may remain in the NI-VISA directories. To complete the uninstall process, you must restart your machine.
    Note: The uninstaller application does not notify you when rebooting is necessary. If you plan to reinstall NI-VISA, you always should reboot the machine after running the uninstaller.
    Installing NI-VISA for LabVIEW NXG
    Agilent/HP Controller Support
    NI-VISA now works with Agilent/HP GPIB and VXI controller cards. To use this feature, go into MAX, select Tools»NI-VISA»VISA Options, choose the Passports tab, and enable the NiVisaTulip.dll Passport. NI-VISA automatically finds and accesses any GPIB or VXI devices. However, NI-VISA does not configure the Agilent/HP hardware; you still must do that with the Agilent/HP I/O Config utility.
    If you have both NI and Agilent/HP controllers in the same system, you must configure the cards at different system addresses, such as GPIB0 and GPIB1. If both vendors try to use the same interface address, NI-VISA reports an error from viFindRsrc or VISA Find Resources.
    Creating and Digitally Signing Catalog Files
    (Windows 8.1, Windows 10) If you generate an INF file using the NI-VISA Driver Wizard, you must create and digitally sign a Windows Catalog (.cat) file before you can install the INF file on a Windows 8.1 or Windows 10 machine. For more information about digitally signing a .cat file for Windows 8.1 or later, visit ni.com/info and enter the Info Code INFWin8.
    For more information about creating and signing catalog files, Microsoft has a Kernel-Mode Code Signing Walkthrough whitepaper that describes the details of this process. The generated catalog file should reference only the INF file.
    New FeaturesNI-VISA 18.5
    Added support for LabVIEW NXG 3.0
    NI-VISA 17.5
    Added support for LabVIEW NXG 2.0.
    NI-VISA 17.0
    Dropped support for GPIB-VXI controllers.
    NI-VISA 15.5
    Updated documentation for NI-VISA .NET API, available in your Users/Public/Documents/National Instruments/NI-VISA/Documentation directory.
    Improved performance of viInXX and viOutXX functions.
    NI-VISA 15.0
    Added support for the industry standard API for VISA .NET as specified by the IVI Foundation in VPP 4.3.6. NI recommends this API for developing new .NET applications using NI-VISA. Support for the legacy VisaNS API will be removed in a future release. For more information about upgrading from VisaNS to the new VISA .NET API, visit ni.com/info and enter the Info Code VISANETUpgrade.
    NI-VISA 14.0
    Added support for NI Linux Real-Time x64.
    Added support for viMapTrigger and viAssertTrigger on PXI resources to use PXI-9 compliant trigger managers if available.
    Added support for viGpibControlREN on TCPIP resources that use the VXI-11 protocol.
    You can access the software and documentation known issues list online. For a list of known issues with NI-VISA 18.5, visit ni.com/info and enter the Info Code NIVISA185KnownIssues.
    For a list of bug fixes for NI-VISA, visit ni.com/info and enter the Info Code NIVISAFixList.
    Refer to the NI-VISA Help, accessible from LabVIEW by selecting Help>>LabVIEW Help, for information about NI-VISA.
    Select Help�Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-VISA are located in the labview\examples\Instrument IO\VISA directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG with NI-VISA.
    Installing NI-VISA
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-VISA for LabVIEW NXG.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 3.0 and NI-VISA.
    • Complete the installer instructions to download LabVIEW NXG 3.0 and NI-VISA.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1995–2018 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help>>;Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    374899J-01
    GMT+8, 2026-2-3 07:41
