TA的每日心情 | 怒 昨天 10:09 |
签到天数: 3735 天 连续签到: 62 天 [LV.Master]2000FPS
NI LabVIEW 7.1.1f2 Update for Windows LV7.1.1f2升级补丁32位
LV 7.1.1 F2
百度网盘和官方下载地址:
LV7.1.1f2update.txt
(186 Bytes, 下载次数: 0, 售价: 5 圆)
YOU NEED TO HAVE LabVIEW 7.1.1 INSTALLED!
The fixes are provided as a zip file. Back up the original files before replacing
them with the fixes. The fixes only affect the development environment, there is
no need to update the Run-Time Engine.
LV711f2.zip is for the LabVIEW development system and should be unzipped to the
..\National Instrumenst\LabVIEW 7.1 folder. It contians three files:
labview.exe
resource\labview.rsc
resource\DNCompInfo.dll
NOTE: If LabVIEW 7.1 installation is repaired after applying the patch, then the
patch needs to be reapplied.
Summary of Updates
1. LabVIEW crashes when browsing for a .NET Assembly if .NET 2.0 is installed
If .NET 2.0 is installed, then LabVIEW may crash when the Select .NET Constructor
dialog is displayed, for example after dropping a new constructor node. In some cases
the dialog appears, but the Assembly list is empty.
2. .NET Primary Interop Assembly name shown instead of ActiveX servername
If an ActiveX server has a .NET Primary Interop Assembly to allow it be used in .NET,
then when browsing for an ActiveX server, the information about the Primary Interop
Assembly is shown instead of the ActiveX server information.
