查看: 3409|回复: 1
[LabVIEW] NI LabVIEW NXG 5.0.0 Win64Eng LV NXG5.0.0 64位Windows英文专业版
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
    发表于 2020-5-19 16:37:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI LabVIEW NXG 5.0.0  x64Win English LV NXG5.0.0 64位Windows英文专业版
    LabVIEW NXG 5.0
    发布日期:
    20-5-15
    包含的版本:
    5.0.0
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    中文
    德语
    日语
    法语
    英文
    韩语
    文件大小: 3772829696 字节 (3.51 GB)
    修改日期: 2020-05-12 03:29
    MD5: ecc52824d7308e49b7465ce61f335a7f(官方正确)
    SHA1: ceb735e84b1422ae4a0c1b6d19b0cddd9bac9a91
    SHA256: 162b365fcfc29c0f9fbb6e547b0f2dc6b9dea1e7ff56087d04bcd9dbbf8c725c
    CRC32: 9f5525e8
    NI官方下载地址和百度网盘下载地址:
    请注册视觉论坛会员登录后购买附件下载查看
    LabVIEW NXG 5.0.txt (754 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW NXG 5.0 Readme
    May 2020
    This file contains important information about LabVIEW NXG, including system requirements, supported operating systems, and known issues for LabVIEW NXG 5.0.
    LabVIEW NXG Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and all 32-bit Windows Operating Systems in 2021
    Use LabVIEW NXG to automate benchtop measurements using NI data acquisition hardware and benchtop instruments. Start taking measurements quickly with interactive panels to acquire and visualize data sets. When you need more customization, you can create your own applications using the graphical programming environment.
    LabVIEW NXG has the following minimum system requirements:
    • Pentium 4 G1 equivalent (Intel i5 equivalent or higher recommended)
    • 10 GB disk space (20 GB or higher recommended)
    • Installation on a solid state drive (SSD) recommended
    • 2 GB RAM (8 GB or higher recommended)
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    LabVIEW NXG 5.0 supports the 64-bit version of the following operating systems:
    • Windows 10 (version 1909)/8.1 Update 11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  Refer to LabVIEW NXG Drops Support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows Operating Systems in 2021 for information about future OS support.
    NI installs LabVIEW NXG using NI Package Manager. If you do not already have NI software installed, LabVIEW NXG installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com for more information and steps to resolve this issue.
    • Use the serial number that is included with your software to activate LabVIEW NXG. For more information on LabVIEW NXG activation, refer to National Instruments Software Activation.
    LabVIEW NXG 5.0 adds new functionality to the previous release. Refer to LabVIEW NXG 5.0 New Features for a list of new features and changes.
    You can access an up-to-date list of known issues for a particular release of LabVIEW NXG on the NI website.
    Search for items using the search bar in the upper right corner of the LabVIEW window.
    View context help in LabVIEW NXG by pressing and hovering over an object. Refer to the LabVIEW NXG Manual, accessible from Help»Online Manual, for more information about LabVIEW NXG.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    LabVIEW examples are located in the labview\examples directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW NXG Drops Support for Windows 7 and Windows Server 2008 R2 in 2021
    LabVIEW NXG will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2017-2020 National Instruments. All rights reserved.
    376808H-01
  • 签到天数: 6 天
    发表于 2020-5-20 15:27:40 | 显示全部楼层 来自:辽宁省沈阳市 联通
    NI国内网站已经更新中文版了,请问如何才能得到下载链接呢?谢谢!
    GMT+8, 2025-9-10 01:07
