查看: 3732|回复: 0
[LV工具模块] LabVIEW 2020 MathScript Real-Time Module X86WinZHCN LV2020文本数学脚本实时模块MSRT2020 Win32位中文版下载
    6 小时前
  • 签到天数: 3719 天
    连续签到: 46 天
    发表于 2020-5-26 22:58:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。自2016MSRT开始,WINDOWS系统LabVIEW增加64位版本MSRT。自2019MSRT开始,增加在线安装方式,同时增加中文、法语、德语、日语、韩语等多国语言版本。
    LabVIEW 2020 MathScript模块
    发布日期
    20-5-15
    包含的版本
    2020
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    语言
    中文
    在线安装版校验和
    (MD5)
    a3ea68d625aa784aabce7ed06dde9e14
    (SHA256)
    abb0af0ad3c79420068a5bc0bcef015acd15e78607ee575105229d9215d3c671
    离线安装版校验和
    (MD5) f5588ca4cedfa8f3a2b6dd145984a620
    (SHA256) afee032a9e184f4b1f8756c924c7167002f70a4fa09dd33be49241cbb4962750
    MSRT20.0CHNx86离线安装包和在线安装工具包:
    离线版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看 提取码: 请登录视觉论坛会员购买附件下载查看
    在线版:
    NI官方下载地址(可能无效或无法下载完成,需要网络没有被限制较稳定,特别是在线安装版):
    在线版:
    请登录视觉论坛会员购买附件下载查看
    离线版:
    请登录视觉论坛会员购买附件下载查看
    MSRT20.0CHNx86.txt (714 Bytes, 下载次数: 10, 售价: 10 圆)
    LabVIEW 2020 MathScript Module Readme
    March 2020
    This file contains important information about the LabVIEW MathScript Module, including system requirements, installation instructions, and known issues.
    Note  LabVIEW MathScript is no longer recommended for new designs. Visit ni.com/migratemathscript for more information and recommended alternatives.
    Limitations on Windows (64-bit), macOS, and Linux
    MathScript Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW MathScript is a text-based environment you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript Module has the following requirements:
    LabVIEW 2020 Full or Professional Development System
    At least 500 MB of disk space
    The MathScript Module supports the following operating systems:
    Windows        Windows 10 (version 1909)/8.1 Update 11/7 SP12
    Windows Server 2016
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    Note  Refer to MathScript Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 the MathScript Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 MathScript Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 MathScript Module to an unsupported OS. Additionally, after installing the LabVIEW 2020 MathScript Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport
    macOS        macOS 10.14 or 10.15
    Linux        openSUSE LEAP 15.0
    openSUSE LEAP 15.1
    Red Hat Enterprise Linux 7
    Red Hat Enterprise Linux 8
    CentOS 7
    CentOS 8
    Note  The LabVIEW 2020 MathScript Module for Linux requires a 64-bit distribution and does not support 32-bit applications.
    The MathScript Module on Windows (64-bit), macOS, and Linux does not support the libraries class of MathScript Module functions.
    (Windows)
    NI installs the MathScript Module using NI Package Manager. If you do not already have NI software installed, the MathScript Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the MathScript Module using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    (macOS, Linux)
    You can install the MathScript Module using the LabVIEW media for macOS/Linux. Refer to the LabVIEW Media Readme for macOS/Linux for instructions on how to install the MathScript Module.
    You can access the software and documentation known issues list online. Visit LabVIEW 2020 MathScript Module Known Issues for an up-to-date list of known issues.
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the MathScript Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the MathScript Module are located in the labview\examples\MathScript directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The MathScript Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2009–2020 National Instruments. All rights reserved.
    Notices are located in the \_Legal Information and directories.
    EULAs are located in the \Shared\MDF\Legal\license directory.
    Review \_Legal Information.txt for information on including legal information in installers built with NI products.
    375325G-01
    GMT+8, 2025-11-21 15:10
