查看: 3691|回复: 0
[LV工具模块] LabVIEW 2009 NI SoftMotion Module Win32 NI运动控制模块2009 适用LV2009
    昨天 16:03
    发表于 2020-6-16 15:52:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2009 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    SMM2009.txt (289 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2009 NI SoftMotion™ Module Readme
    June 2009
    This document contains information to introduce you to the LabVIEW NI SoftMotion Module including installation information, a list of changes in this version of NI SoftMotion, and information about known issues for this version of NI SoftMotion.
    Contents
    General Information
    The LabVIEW NI SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings and tune your servo motors, program motion profiles with a function block API, create custom motion applications, and simulate your designs created in SolidWorks.
    For more information about function block programming and using function blocks with the NI SoftMotion Module refer to Motion Profile Development using the Function Block API at zone.ni.com.
    Note: Refer to the NI SoftMotion Selection Guide at zone.ni.com for a description of the different NI SoftMotion packages available.
    The LabVIEW 2009 NI SoftMotion Module supports Microsoft Windows Vista/XP/2000. The NI SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2009
    • LabVIEW Real-Time Module 2009
    • LabVIEW FPGA Module 2009
    • NI-Motion 8.0 or later
    • NI-RIO 3.2.0 or later
    • NI-Industrial Communications for EtherCAT® 1.1 or later
    You can install all of your LabVIEW products—including the LabVIEW 2009 NI SoftMotion Module—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the LabVIEW 2009 NI SoftMotion Module along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site at ni.com.
    The following items are enhancements or additions to the LabVIEW NI SoftMotion Module relative to the NI SoftMotion Development Module for LabVIEW.
    LabVIEW Palette Reorganization
    The VIs previously on the NI SoftMotion palette are now included on the NI SoftMotion»Advanced»Trajectory palette.
    NI Example Finder Reorganization
    The examples previously provided with the NI SoftMotion Development Module for LabVIEW are now included in Toolkits and Modules»Motion Control»NI SoftMotion»Customizing NI SoftMotion»Advanced»Trajectory and Toolkits and Modules»Motion Control»NI SoftMotion»Customizing NI SoftMotion»Without NI Scan Engine.
    Using NI SoftMotion Development Module VIs with NI SoftMotion
    You can use your NI SoftMotion Development Module VIs with the new LabVIEW NI SoftMotion Module using one of the following options:
    • If you do not use the NI Scan Engine, you can continue to use your NI SoftMotion Development Module VIs after recompiling. When you install NI-RIO and the LabVIEW NI SoftMotion Module on the RT target, do not include NI Scan Engine support.
      Note:  If you have developed applications using the NI SoftMotion Development Module 2.0 you may need to run the NI SoftMotion Dev Module Upgrade Utility from the Tools menu in LabVIEW to update your code. Refer to the NI SoftMotion Dev Module Upgrade Utility Readme for more information.
    • If you want to use the NI Scan Engine with your NI SoftMotion Development Module VIs, you need to install the NI Scan Engine on the RT target and update your VIs. Refer to How do I upgrade my NI SoftMotion Development Module 2.x VIs to use with the LabVIEW NI SoftMotion Module? at ni.com\kb for instructions.
    Arc Input Behavior Changes
    The rotation direction of the arc roll, pitch, and yaw inputs has changed in NI SoftMotion relative to the NI SoftMotion Development Module so that a positive angle rotates counterclockwise when looking toward the origin.
    Fixed Issue ID 111553: Incorrect Number of Points Returned
    The NI SoftMotion Development Module trajectory generator was incorrectly dropping the last few points when returning spline points for moves. This calculation issue is resolved in NI SoftMotion.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW 2009 NI SoftMotion Module, you must install the LabVIEW 2009 NI SoftMotion Module software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Using Torque Mode
    When you use an NI SoftMotion axis in torque loop mode, you must set the NI Scan Engine scan period to 2 ms or faster or the axis will not function.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about NI SoftMotion Module concepts, using NI SoftMotion function blocks, step-by-step instructions using the LabVIEW NI SoftMotion Module, and reference information about NI SoftMotion VIs and function blocks.
    LabVIEW examples for the NI SoftMotion Module are located in the labview\examples\motion\SoftMotion folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW 2009 NI SoftMotion Module Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 NI SoftMotion Module.
    Important Information
    GMT+8, 2026-2-24 20:51
