查看: 3305|回复: 0
[LV工具模块] LabVIEW 2010f1 NI SoftMotion Module Win32 NI运动控制模块2010f1 适用LV2010
    昨天 16:03
    发表于 2020-6-16 16:10:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2010f1 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    SMM2010f1.txt (291 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW NI SoftMotion™ Module 2010 f1 Readme
    August 2010
    This document contains information to introduce you to the LabVIEW NI SoftMotion Module including installation information, a list of changes in this version of NI SoftMotion, and information about known issues for this version of NI SoftMotion.
    Contents
    Licensing
    General Information
    The LabVIEW NI SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SolidWorks.
    For more information about function block programming and using function blocks with the NI SoftMotion Module refer to Motion Profile Development using the Function Block API at zone.ni.com.
    Note: Refer to the NI SoftMotion Selection Guide at zone.ni.com for a description of the different NI SoftMotion Module packages available.
    You can run the LabVIEW NI SoftMotion Module 2010 f1 installer on the following operating systems:
    • Windows XP (32-bit)
    The LabVIEW NI SoftMotion Module runs as a 32-bit application on all operating systems.
    Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    The LabVIEW NI SoftMotion Module does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run the LabVIEW NI SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using NI SoftMotion for SolidWorks
    • 250 MB of free disk space
    • Pentium 4 processor or equivalent (866 MHz minimum)
    The NI SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2010
    • LabVIEW 2010 Real-Time Module
    • LabVIEW 2010 FPGA Module
    • NI-RIO 3.5.0 or later
    • NI-Industrial Communications for EtherCAT® 2.0 or later
    Note  To use NI SoftMotion for SolidWorks you must have SolidWorks 2009 SP2.1 or later.
    Complete the following steps to download and install the LabVIEW NI SoftMotion Module 2010 f1:
    • Download the LabVIEWNISoftMotionModule2010f1.exe file from ni.com/updates/, and then run it.
      Note  (Windows 7/Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    Changes and New FeaturesFixed Issue ID 243489: NI SoftMotion Commands a Position of Not a Number (NaN)
    When performing a coordinate move, commanding the same position as the current position causes the NI SoftMotion trajectory generator to command a position of not a number (NaN). This results in an effective position of 231 - 1 which results in the motor jumping.
    General InformationUsing the NI 9512 C Series Drive Interface Module in FPGA Interface Mode
    NI-RIO 3.5 adds FPGA Interface mode support for the NI 9512 C Series drive interface module. You must upgrade the firmware on the NI 9512 module to version 1003608 or later to enable support for FPGA Interface mode. Refer to the Motion Modules section in the FPGA Module book of the LabVIEW Help for firmware upgrade instructions.
    Note  Attempting to use the NI 9512 module without updating the firmware causes the module to return a Timing Synchronization Fault.
    LabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW NI SoftMotion Module 2010 f1, you must install the LabVIEW NI SoftMotion Module 2010 f1 software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about NI SoftMotion Module concepts, using NI SoftMotion, step-by-step instructions using the LabVIEW NI SoftMotion Module, and reference information about NI SoftMotion VIs and functions.
    LabVIEW examples for the NI SoftMotion Module are located in the labview\examples\Motion folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW NI SoftMotion 2010 f1 Module Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW NI SoftMotion Module 2010 f1.
    Back to Top
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    In regards to components that use Expat software, the following copyright notice applies. Copyright (c) 1998, 1999, 2000 Thai Open Source Software Center Ltd
    and Clark Cooper
    Copyright (c) 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-2-24 20:50
