查看: 3366|回复: 0
[LV工具模块] LabVIEW 2013 NI SoftMotion Module Win32 NI运动控制模块2013 适用LV2013
  • 签到天数: 3602 天
    连续签到: 10 天
    发表于 2020-6-16 16:42:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2013 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    下载地址1:
    下载地址2:
    SMM2013.txt (481 Bytes, 下载次数: 1, 售价: 10 元)
    LabVIEW 2013 NI SoftMotion™ Module Readme
    August 2013
    This document contains information to introduce you to the LabVIEW NI SoftMotion Module including installation information, a list of changes in this version of NI SoftMotion, and information about known issues for this version of NI SoftMotion.
    Contents
    Licensing
    New Features and Changes
       Bug Fix List
    General Information
    The LabVIEW NI SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SolidWorks.
    Note: Refer to the NI SoftMotion Selection Guide at zone.ni.com for a description of the different NI SoftMotion Module packages available.
    You can run the LabVIEW 2013 NI SoftMotion Module installer on the following operating systems:
    The LabVIEW NI SoftMotion Module only supports the 32-bit version of LabVIEW on all operating systems.
    Note:  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    The LabVIEW NI SoftMotion Module does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run the LabVIEW NI SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using NI SoftMotion for SolidWorks
    • 250 MB of free disk space
    The LabVIEW 2013 NI SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit)
    • LabVIEW 2013 Real-Time Module
    • LabVIEW 2013 FPGA Module
    • NI-RIO Device Drivers August 2013
    • NI-Industrial Communications for EtherCAT® 2.6 or later
    Note  To use NI SoftMotion for SolidWorks you must have SolidWorks 2009 SP2.1 or later (32-bit or 64-bit).
    Installation InstructionsInstalling from the LabVIEW 2013 Platform DVDs
    You can install all of your LabVIEW products—including the LabVIEW 2013 NI SoftMotion Module—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW 2013 Platform DVDs, refer to the National Instruments Web site at ni.com.
    Downloading the LabVIEW 2013 NI SoftMotion Module from the Web
    Complete the following steps to download and install the LabVIEW 2013 NI SoftMotion Module:
    • Download the LabVIEW2013NISoftMotionModule.exe file from ni.com/updates, and then run it.
      Note  (Windows 8/7/Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    LabVIEW NI SoftMotion Module Updates and Notifications
    Licensing
    The LabVIEW NI SoftMotion Module relies on licensing activation. After the evaluation period for NI SoftMotion Module Premium expires, you must activate a valid NI SoftMotion Module license before you can run NI SoftMotion Module Standard or NI SoftMotion Module Premium. To activate the NI SoftMotion Module, use the serial number you received as part of your installation package.
    If you do not activate the NI SoftMotion Module, you will have access to NI SoftMotion Module Lite, which provides a subset of functionality offered by the LabVIEW NI SoftMotion Module for free. With NI SoftMotion Module Lite, you can perform simple single-axis point-to-point motion, create motion applications for NI C Series drive interface modules, and connect to AKD drives through EtherCAT.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    Go to ni.com/info and enter nismpkg for a description of the different available NI SoftMotion Module packages.
    Version 2013 Features and ChangesNI Linux Real-Time Support
    All major NI SoftMotion functionality is supported on targets running NI Linux Real-Time, with the exception of the following functionality:
    • NI 951x firmware updates
    • the unbound axis type
    • the Axis Interface Read Command, Acknowledge Command, Read Execution Data, and Write Execution Data methods
    • the RT Scan Synchronization VIs.
    LabVIEW 2013 NI SoftMotion Module Bug Fix List
    You can access the software and documentation bug fix list online. Refer to the National Instruments Web site for an up-to-date list of bug fixes in the LabVIEW 2013 NI SoftMotion Module.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW 2013 NI SoftMotion Module, you must install the LabVIEW 2013 NI SoftMotion Module software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about NI SoftMotion Module concepts, using NI SoftMotion, step-by-step instructions using the LabVIEW NI SoftMotion Module, and reference information about NI SoftMotion VIs and functions.
    LabVIEW examples for the NI SoftMotion Module are located in the labview\examples\Motion folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW 2013 NI SoftMotion Module Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2013 NI SoftMotion Module.
    Back to Top
    Back to Top
    Using NI Launcher
    Finding All Programs
    Back to Top
    NI SoftMotion Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The NI SoftMotion Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the NI SoftMotion Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to Top
    Important Information
    © 2004–2013 National Instruments. All rights reserved.
    GMT+8, 2025-7-23 12:13
