查看: 3372|回复: 0
[LV工具模块] LabVIEW 2013SP1f1 NI SoftMotion Module Win32 NI运动控制模块2013SP1f1 适用LV2013SP1
    9 小时前
    发表于 2020-6-16 17:06:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2013SP1f1 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    SMM2013SP1f1.txt (294 Bytes, 下载次数: 4, 售价: 10 圆)
    LabVIEW NI SoftMotion™ Module 2013 SP1 f1 Readme
    February 2014
    This document contains information to introduce you to the LabVIEW NI SoftMotion Module including installation information, a list of changes in this version of NI SoftMotion, and information about known issues for this version of NI SoftMotion.
    Contents
    Licensing
    New Features and Changes
       Bug Fix List
    General Information
    The LabVIEW NI SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SolidWorks.
    Note: Refer to the NI SoftMotion Selection Guide at zone.ni.com for a description of the different NI SoftMotion Module packages available.
    You can run the LabVIEW NI SoftMotion Module 2013 SP1 f1 Patch installer on the following operating systems:
    The LabVIEW NI SoftMotion Module runs as a 32-bit application on all operating systems.
    Note:  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    The LabVIEW NI SoftMotion Module does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run the LabVIEW NI SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using NI SoftMotion for SolidWorks
    • 250 MB of free disk space
    The NI SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2013 SP1 Base, Full, or Professional Development System (32-bit)
    • LabVIEW 2013 SP1 Real-Time Module
    • LabVIEW 2013 SP1 FPGA Module
    • NI-RIO Device Drivers February 2014
    • NI-Industrial Communications for EtherCAT® 2.7 or later
    Note  To use NI SoftMotion for SolidWorks you must have SolidWorks 2009 SP2.1 or later (32-bit or 64-bit).
    Installation InstructionsInstalling from the LabVIEW 2013 Platform DVDs
    You can install all of your LabVIEW products—including the LabVIEW 2013 SP1 NI SoftMotion Module—using the LabVIEW 2013 SP1 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW 2013 Platform DVDs, refer to the National Instruments Web site at ni.com.
    -->Downloading the LabVIEW NI SoftMotion Module 2013 SP1 f1 Patch from the Web
    Complete the following steps to download and install the LabVIEW NI SoftMotion Module 2013 SP1 f1 Patch:
    • Download the LabVIEWNISoftMotionModule2013SP1f1.exe file from ni.com/updates, and then run it.
      Note  (Windows 8/7/Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    LabVIEW NI SoftMotion Module Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Licensing
    The LabVIEW NI SoftMotion Module relies on licensing activation. After the evaluation period for NI SoftMotion Module Premium expires, you must activate a valid NI SoftMotion Module license before you can run NI SoftMotion Module Standard or NI SoftMotion Module Premium. To activate the NI SoftMotion Module, use the serial number you received as part of your installation package.
    If you do not activate the NI SoftMotion Module, you will have access to NI SoftMotion Module Lite, which provides a subset of functionality offered by the LabVIEW NI SoftMotion Module for free. With NI SoftMotion Module Lite, you can perform simple single-axis point-to-point motion, create motion applications for NI C Series drive interface modules, and connect to AKD drives through EtherCAT.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    Go to ni.com/info and enter nismpkg for a description of the different available NI SoftMotion Module packages.
    Version 2013 SP1 f1 Features and ChangesFixed issue: Limit Switches Fail to Trigger
    The LabVIEW NI SoftMotion Module 2013 SP1 f1 fixes an issue that may prevent SoftMotion from properly interpreting limit switches if the limit switch is not active for longer than the scan rate of the RT controller. For more information, visit ni.com/info and enter the Info Code: nism2013limitswitch.
    Support for C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition
    The LabVIEW NI SoftMotion Module 2013 SP1 f1 allows you to develop applications using the NI SoftMotion Module C API in an Eclipse-based integrated development environment (IDE).
    New AKD Axis Features
    The following new or improved features are added for EtherCAT AKD axes in the LabVIEW NI SoftMotion Module 2013 SP1 f1:
    • Velocity mode
    • Torque mode
    • Write methods for velocity and torque setpoints (EtherCAT AKD drive only)
    • New I/O variables in EtherCAT XML description file for AKD EtherCAT drives, including variables for writing velocity and torque setpoints. The torque feed forward variable has been removed due to the EtherCAT AKD PDO size restrictions.
    Removal of Gain Tuning Panel and Slider Tuner from Axes on EtherCAT AKD Drives
    The gain tuning panel and slider tuner are no longer available to axes on EtherCAT AKD drives in LabVIEW NI SoftMotion Module 2013 SP1 f1. Instead, drives can be tuned using the Kollmorgen AKD WorkBench software.
    EtherCAT AKD Drive Deployment Option Changes
    During deployment, the LabVIEW NI SoftMotion Module 2013 SP1 f1 will not overwrite drive settings by default. The axis configuration dialog features a new option on the General Settings page, preventing NI SoftMotion Module from deploying drive settings over those configured using WorkBench.
    LabVIEW NI SoftMotion Module 2013 SP1 f1 Bug Fix List
    You can access the complete software and documentation bug fix list online. Refer to the National Instruments Web site for an up-to-date list of bug fixes in the LabVIEW NI SoftMotion Module 2013 SP1 f1.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW NI SoftMotion Module 2013 SP1 f1, you must install the LabVIEW NI SoftMotion Module 2013 SP1 f1 software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about NI SoftMotion Module concepts, using NI SoftMotion, step-by-step instructions using the LabVIEW NI SoftMotion Module, and reference information about NI SoftMotion VIs and functions.
    LabVIEW examples for the NI SoftMotion Module are located in the labview\examples\Motion folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW NI SoftMotion Module 2013 SP1 f1 Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW NI SoftMotion Module 2013 SP1 f1.
    Back to Top
    Back to Top
    Important Information
    © 2004–2014 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-12-8 19:07
