查看: 3540|回复: 0
[LV工具模块] LabVIEW 2014f1 NI SoftMotion Module Win32 NI运动控制模块2014f1 适用LV2014
    昨天 16:03
    发表于 2020-6-16 18:59:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2014f1 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    SMM2014f1.txt (300 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW SoftMotion™ Module 2014 f1 Readme
    August 2014
    This document contains information to introduce you to the LabVIEW SoftMotion Module including installation information, a list of changes in this version of SoftMotion, and information about known issues for this version of SoftMotion.
    Contents
    Licensing
    New Features and Changes
       Bug Fix List
    General Information
    The LabVIEW SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SolidWorks.
    Note: Refer to the SoftMotion Selection Guide at zone.ni.com for a description of the different NI SoftMotion Module packages available.
    You can run the LabVIEW SoftMotion Module 2014 f1 installer on the following operating systems:
    • Windows 8.1/8/7/Vista
    The LabVIEW SoftMotion Module runs as a 32-bit application on all operating systems.
    Note:  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    The LabVIEW SoftMotion Module does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run the LabVIEW SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using SoftMotion for SolidWorks
    • 250 MB of free disk space
    The SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2014 Base, Full, or Professional Development System (32-bit)
    • LabVIEW 2014 Real-Time Module
    • LabVIEW 2014 FPGA Module
    • NI-RIO Device Drivers August 2014
    • NI-Industrial Communications for EtherCAT® 2014
    Note  To use SoftMotion for SolidWorks you must have SolidWorks 2009 SP2.1 or later.
    Installation InstructionsDownloading the LabVIEW SoftMotion Module 2014 f1 from the Web
    Complete the following steps to download and install the LabVIEW SoftMotion Module 2014:
    • Download the LabVIEWSoftMotionModule2014f1.exe file from ni.com/updates, and then run it.
      Note  (Windows 8.1/8/7/Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    LabVIEW SoftMotion Module Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Licensing
    The LabVIEW SoftMotion Module relies on licensing activation. After the evaluation period for SoftMotion Module expires, you must activate a valid license before you can run the software. To activate the SoftMotion Module, use the serial number you received as part of your installation package.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    Version 2014 f1 Features and ChangesSupport for NI 9503 Modules
    LabVIEW SoftMotion Module 2014 f1 supports the NI 9503 stepper drive module. Updates include FPGA VIs that can be used to create smoother motion.
    Support for NI Real-Time Linux 64-bit
    LabVIEW 2014 SoftMotion Module is compatible with NI Real-Time Linux 64-bit targets.
    LabVIEW SoftMotion Module 2014 f1 Bug Fix List
    You can access the software and documentation bug fix list online. Refer to the National Instruments Web site for an up-to-date list of bug fixes in the LabVIEW SoftMotion Module 2014.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW SoftMotion Module 2014, you must install the LabVIEW SoftMotion Module 2014 software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about SoftMotion Module concepts, using SoftMotion, step-by-step instructions using the LabVIEW SoftMotion Module, and reference information about SoftMotion VIs and functions.
    LabVIEW examples for the SoftMotion Module are located in the labview\examples\Motion folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    LabVIEW SoftMotion Module 2014 Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW SoftMotion Module 2014.
    Back to Top
    Back to Top
    Important Information
    © 2004–2014 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-2-24 22:19
