查看: 3770|回复: 0
[LV工具模块] LabVIEW 2016 NI SoftMotion Module Win32 NI运动控制模块2016 适用LV2016
    昨天 16:03
    发表于 2020-6-17 14:48:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2016 SoftMotion模块
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    NI官方下载地址(可能失效或无法下载完成):
    下载地址1:
    下载地址2:
    SMM2016.txt (419 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2016 SoftMotion™ Module Readme
    June 2016
    This document contains information to introduce you to the LabVIEW 2016 SoftMotion Module including installation information, a list of changes in this version of SoftMotion, and information about known issues for this version of SoftMotion.
    Contents
    Licensing
    New Features and Changes
    Bug Fix List
    General Information
    The LabVIEW 2016 SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SOLIDWORKS.
    Note  Refer to the SoftMotion Selection Guide for a description of the different SoftMotion Module packages available.
    You can run the LabVIEW 2016 SoftMotion Module installer on the following operating systems:
    • Windows 10/8.1/8.0/7
    The LabVIEW 2016 SoftMotion Module runs as a 32-bit application on all operating systems.
    Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    The LabVIEW 2016 SoftMotion Module does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run the LabVIEW 2016 SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using SoftMotion for SOLIDWORKS
    • 500 MB of free disk space
    The LabVIEW 2016 SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2016 Base, Full, or Professional Development System (32-bit)
    • LabVIEW 2016 Real-Time Module
    • LabVIEW 2016 FPGA Module
    • NI-RIO Device Drivers August 2016
    • NI-Industrial Communications for EtherCAT® 16.0
    Note  To use SoftMotion for SOLIDWORKS you must have SOLIDWORKS 2009 SP2.1 or later.
    Installation InstructionsInstalling from the LabVIEW 2016 Platform DVDs
    You can install all of your LabVIEW products—including the LabVIEW 2016 SoftMotion Module—using the LabVIEW 2016 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW 2016 Platform DVDs, refer to the National Instruments Web site at ni.com.
    Downloading the LabVIEW 2016 SoftMotion Module from the Web
    Complete the following steps to download and install the LabVIEW 2016 SoftMotion Module:
    • Download the LabVIEWSoftMotionModule2016.exe file from ni.com/updates, and then run it.
      Note  (Windows 10/8.1/8.0/7)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    LabVIEW SoftMotion Module Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Licensing
    The LabVIEW SoftMotion Module relies on licensing activation. After the evaluation period for SoftMotion Module expires, you must activate a valid license before you can run the full version of the software. To activate the SoftMotion Module, use the serial number you received as part of your installation package.
    If the LabVIEW SoftMotion Module is not activated and the evaluation period expires, the product will have restricted functionality. Refer to the SoftMotion Selection Guide for a description of the different SoftMotion Module packages available.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    LabVIEW 2016 SoftMotion Module Features and ChangesLabVIEW 2016 Support
    LabVIEW 2016 SoftMotion Module is fully supported on LabVIEW 2016.
    LabVIEW Example Finder
    The LabVIEW 2016 SoftMotion Module examples have been reorganized. The API examples for Express VIs and Properties and Methods have been recategorized based on function, and legacy hardware examples have been removed.
    For more information on SoftMotion examples, see the Finding Examples section below.
    LabVIEW 2016 SoftMotion Module Bug Fix List
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW 2016 SoftMotion Module, you must install the LabVIEW 2016 SoftMotion Module software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX).
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about SoftMotion Module concepts, using SoftMotion, step-by-step instructions using the LabVIEW SoftMotion Module, and reference information about SoftMotion VIs and functions.
    LabVIEW examples for the SoftMotion Module can be found in the Example Finder (at Help > Find Examples) in two different directories: the Hardware Input and Output\Motion Control\SoftMotion folder and the Toolkits and Modules\SoftMotion folder. The examples are grouped into three primary categories:
    Hardware Specific - for use with specific hardware combinationsExpress VIs - API examples for all hardware combinationsProperties and Methods - API examples for all hardware combinationsReinitialization - for resetting the SoftMotion engine on real-time targets
    The Getting Started Guides contain detailed information for setting up and configuring specific SoftMotion hardware. Visit the Resources tab on the product page at ni.com to find a Getting Started Guide for your hardware. In LabVIEW 2014 SP1 SoftMotion Module, the examples for the NI 9502, 9503, and 9503 drive modules were converted to Sample Projects. These can be found in the Create Project menu in LabVIEW.
    LabVIEW 2016 SoftMotion Module Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in this release.
    Back to Top
    LabVIEW SoftMotion Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    LabVIEW SoftMotion Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW SoftMotion Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindowsT/CVITcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to Top
    Important Information
    © 2004–2016 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patent.
    376347A-01
    GMT+8, 2026-2-24 23:50
