查看: 3384|回复: 0
[NI驱动程序] NI-Motion 8.0f1 Full Win32Eng NI运动驱动程序8.0f1完整版 适用LabVIEW8.2.1~LabVIEW2009
    10 小时前
  • 签到天数: 3668 天
    连续签到: 30 天
    发表于 2020-6-24 10:47:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Motion为NI运动器件的驱动程序,开发软件为NI SoftMotion,及Motion Assistant。
    NI-Motion 8.0f1
    发布日期
    09-10-1
    受支持的操作系统
    Windows 2000
    Windows Vista 64-bit
    Windows Vista
    Windows XP
    语言
    英文
    校验和
    (MD5)
    d00f8c2ed49a02d59209838173ccc4b9
    百度网盘下载(限速,请开会员或使用破解限速工具):
    链接: 请注册视觉论坛用户,登录后购买附件下载查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    Motion8.0.txt (276 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Motion™ 8.0f1 Readme for NI 73xx Controllers
    This document contains installation and programming considerations for using NI-Motion with NI 73xx motion controllers, a list of changes in this version of NI-Motion, and information about NI-Motion known issues.
    Contents
    General Information
    Installation and Configuration Instructions
    NI-Motion 8.0f1 Changes and Enhancements
    NI-Motion 8.0f1 General Considerations
    NI-Motion 8.0f1 Known Issues
    Previous NI-Motion Changes and Enhancements
    General Information
    NI-Motion 8.0f1 is the motion control software you use to communicate with all National Instruments NI 73xx motion controllers using LabVIEW, C, LabWindows™/CVI™, or Microsoft Visual Basic 6.0 development platforms. Refer to KnowledgeBase article 39DA8HMU, Does the NI-Motion Driver Support Visual Studio .NET?, at ni.com/kb for information about Visual Studio .NET 2003 and Visual Studio 2005 support.
    NI-Motion 8.0f1 is compatible with the following National Instruments software:
    • LabVIEW 8.2.1 or later.
    • LabVIEW Real-Time Module 8.2.1 or later.
    • LabVIEW NI SoftMotion Module 2009f1 or later.
    • LabWindows/CVI 7.0 or later.
    • NI Motion Assistant 2.3 or later graphical prototyping software.
    Note  NI-Motion 8.0f1 addresses an issue when using NI-Motion with the LabVIEW NI SoftMotion Module. If you use NI-Motion only with NI 73xx motion controllers, you do not need to update to NI-Motion 8.0f1.
    Compatibility with Earlier Versions of NI-Motion
    If you have developed motion control systems using a previous version of NI-Motion, you must recompile your code before it will work correctly with NI-Motion 8.0f1.
    In addition, any applications you build in NI-Motion 8.0f1 will not work correctly in earlier versions of NI-Motion. Similarly, configuration settings you build and save in Measurement & Automation Explorer (MAX) with NI-Motion 8.0f1 will not work with applications you build in earlier versions of NI-Motion.
    LabVIEW Real-Time Users
    To use NI-Motion 8.0f1 with a real-time target, you must update the NI-Motion driver software on the real-time target system using MAX. Driver versions on the host and target system must be the same for proper operation. Refer to the Measurement & Automation Explorer Remote Systems Help by selecting Help»Help Topics»Remote Systems in MAX for information about installing software on the remote system.
    Back to Top
    The following sections include important information about installing NI-Motion 8.0f1, instructions for downloading and installing NI-Motion 8.0f1 from the Web or from the CD, and information about NI-Motion firmware.
    Note  NI-Motion 8.0f1 is supported on Microsoft Windows Vista/XP/2000. If you are using Windows Me/98/NT, do not update to NI-Motion version 8.0. Continue using NI-Motion version 6.1.x.
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches. This is especially important on Windows 2000 systems. Refer to KnowledgeBase article 45O8JNHR at ni.com/kb for more information.
    Downloading NI-Motion 8.0f1 from the Web
    Complete the following steps to install this update:
    • Download the NIMotion800f1.exe file, and then run it.
      Note  (Windows Vista)  Users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
    • Download the updated firmware to your controller(s):
      Note  You must update the firmware on your NI 73xx controllers before you can use them with NI-Motion 8.0f1.
      • Launch MAX.
      • Select the appropriate motion controller.
      • Click the Firmware tab.
      • Click the Update Firmware button at the top of the window to update all the firmware files on your device.
    Changing Firmware Files to an Earlier Version of NI-Motion
    For optimal performance, ensure that the firmware on your controller matches the driver version you install. Complete the following steps to replace the firmware on your controller if you need to use an earlier version of the NI-Motion software and firmware:
    • Launch MAX.
    • Right-click one of the firmware files in the Firmware Name column and select Download All Files to download the firmware files on the computer onto the controller.
    Back to Top
    NI-Motion 8.0f1 Changes and EnhancementsFixed Issue ID 181673: Incorrect Axis Resources Used With NI SoftMotion Function Blocks
    A memory allocation error has been found which could result in error -70037 (NIMC_irrelevantAttributeError), movement of the wrong axis, or using the wrong move constraints or target position when making a move.
    Back to Top
    NI-Motion 8.0f1 General ConsiderationsInhibit Output Behavior
    The default behavior of the inhibit output changed after NI-Motion 7.0. Previously, the inhibit output would be driven to the active state when the output was disabled. NI-Motion 7.0 and higher drives the inhibit output to the inactive state when the output is disabled. The behavior of the inhibit output when it is enabled did not change.
    Importing Portable Configuration Files
    Importing motion controller settings from older portable configuration files may take a few minutes due to the settings upgrade process. This is expected behavior.
    Creating C Projects with Microsoft Visual Studio .NET 2003 and Visual Studio 2005
    Visual Studio .NET 2003 and 2005 do not allow C++ precompiled header files to be used with C source files. Disable precompiled headers when running NI-Motion C examples.
    National Instruments Software Publisher Certificates
    When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    Firmware Versions in NI-Motion 8.0f1
    The following table lists the expected firmware files that ship with NI-Motion 8.0f1.
    Firmware
    Sector
    Version Number
    NI 7330NI 7340NI 7350NI PCI-7390
    683317.40.30037.40.30037.40.30037.40.3003
    DSP7.31.30027.31.30027.31.30027.31.3002
    FPGA17.00.30017.00.30017.10.30017.00.3014
    FPGA27.00.30017.00.3001
    Upgrading from NI-Motion 5.0.1
    When you upgrade NI-Motion 5.0.1 to NI-Motion 8.0f1, your controller does not use the initialization settings you configured and saved in MAX prior to installing NI-Motion 8.0f1. To use your old initialization settings, you must change back to the old settings using the Change Current Settings feature in the Initialization Settings wizard in MAX. Refer to Measurement & Automation Explorer Help for Motion for information about changing device settings.
    Tip  Click Help»Help Topics»NI-Motion»NI-Motion Configuration Help to launch Measurement & Automation Explorer Help for Motion.
    Back to Top
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI-Motion 8.0f1.
    Back to Top
    Refer to KnowledgeBase article 47CC30FL, NI-Motion Readmes, at ni.com/kb for access to previous NI-Motion readme files, starting with NI-Motion 7.0.
    Back to Top
    Important Information
    CVI, National Instruments, NI, and ni.com are trademarks of National Instruments. The mark LabWindows is used under a license from Microsoft Corporation. Other product and company names listed are trademarks or trade names of their respective companies. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2025-9-30 20:03
