查看: 3353|回复: 0
[LV工具模块] LabVIEW 2009SP1 Real-Time Module LV2009SP1实时模块RealTime2009SP1 Win32Eng 32位Windows英文版下载
    前天 16:03
    发表于 2020-7-1 16:52:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    RT2009SP1E.txt (252 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2009 SP1 Real-Time Module Readme
    Version 9.0.1
    December 2009
    This file contains important information about the LabVIEW 2009 Real-Time Module.
    Supported Platforms
    Installation
    Licensing
    Real-Time Operating System Versions
    Supported Platforms
    The Real-Time Module supports the following operating systems for application development:
    • Windows XP
    • Windows 2000
    Note  The Real-Time Module does not support Windows NT/Me/9x. The Real-Time Module also does not support the Windows Server non-R2 editions.
    Installation
    You can install all of your LabVIEW products—including the LabVIEW Real-Time Module—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the Real-Time Module along with activation instructions in the following locations:
    • LabVIEW Real-Time Module Release and Upgrade Notes, which are available in your LabVIEW Real-Time Module software kit or online at ni.com/manuals.
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    You must install LabVIEW 2009 before you install the LabVIEW Real-Time Module 2009.
    Refer to the LabVIEW Real-Time Module Release and Upgrade Notes for more information about upgrade and compatibility issues, a list of new features, and installation instructions. The LabVIEW Real-Time Module Release and Upgrade Notes is included as a printed booklet with the kit. You also can access the LabVIEW Real-Time Module Release and Upgrade Notes by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the Real-Time Module»Real-Time Module Related Documentation topic on the Contents tab.
    Installing and Configuring Japanese Language Support
    After you install the LabVIEW Real-Time Module 2009 on your development computer, you can complete the following steps to install and configure Japanese language support on an RT target.
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer to install the Language Support for Japanese software component on the RT target. Refer to the NI Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese as the Locale.
    Installing Language Support for Japanese does not enable Japanese language support within the RT target file system. You cannot use Japanese characters in directory names or file names on the RT target.
    Licensing
    The LabVIEW Real-Time Module relies on licensing activation. You must activate a valid LabVIEW Real-Time Module license before you can run the LabVIEW Real-Time Module. To activate the LabVIEW Real-Time Module, use the serial number you received as part of your installation package.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    The Real-Time Module 2009 installs the following RT target operating systems. Refer to the specific RT target hardware documentation for information about which real-time operating system your RT target uses.
    • NI ETS 13.1
    • VxWorks 6.3
    Supported Real-Time Operating System Features
    The Real-Time Module supports only a subset of the features that the ETS and VxWorks operating systems support. Refer to the Real-Time Module book on the Contents tab in the LabVIEW Help for information about features that the Real-Time Module supports.
    Refer to the LabVIEW Real-Time Module Release and Upgrade Notes for information about upgrade and compatibility issues. The LabVIEW Real-Time Module Release and Upgrade Notes is included as a printed booklet with the kit. You also can access the LabVIEW Real-Time Module Release and Upgrade Notes by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the Real-Time Module»Real-Time Module Related Documentation topic on the Contents tab.
    This section includes information about known issues for the LabVIEW 2009 SP1 Real-Time Module.
    Windows 7 Issues
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the Info Code windows7.
    MathScript Probe Support
    The LabVIEW 2009 SP1 MathScript RT Module adds support for the Variables page of the MathScript probe on RT targets. However, the Real-Time Module Help still indicates that MathScript probes are not supported on RT targets.
    You can access the complete software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 Real-Time Module.
    The following items are the IDs and titles of a subset of issues fixed in the RT Module 2009 SP1.
    194232Over 20 probes in debuggable RT VI causes target to disconnect
    193917VxWorks semTake sometimes returns OK when semaphore was not obtained
    193434RT Wait Until Next Multiple Timer Cannot be Saved to a Previous Version of LabVIEW
    191558Deployment progress of a RT host VI fails to a cRIO target in LV 2009
    191108Source Distribution Fails to Build - Can't Find File in Vilib
    186326Error downloading RT host code after upgrading to LV 2009
    184584FFT returns inconsistent data on VxWorks when large number of files are being transfered via FTP
    The following items are the IDs and titles of a subset of issues fixed in the RT Module 2009.
    167785Type cast from Fixed Point to U32 does not work properly on VXworks controllers
    162882Need a configurable INI token for UDP large packet fragmentation
    158842TDMS greyed out for Write To Measurement Express VI
    158524Unable to bind a control to function block variables
    153981Flush file cache to disk failure when writing to USB on SMP targets
    152321Possible reason not clear for Error 18
    152049Time-Triggered Shared Variables transfer size limitation is small
    143813Streaming data to USB thumb drive in LV RT 8.6 crashes PXI controller
    142076Fix race conditions involving ni::dsc::osdep::Thread
    141130Comparing I64s in Real-Time on a VXWorks controller gives incorrect result
    138886Front panel binding does not release memory on RT target
    137523IOV Forcing VIs are marked re-entrant but do not execute as such
    135766(ETS) String to IP function error
    135543Run when opened not honored for reentrant remote panel
    135415PXI-8106 with SMP shows clock drift compared to Windows & NIST server
    134264Setting local time on ETS RT target does not return expected time
    132405TDMS Write to Measurement File does not work on RT PXI targets
    130811Set Target Image VI in System Replication fails to FTP PHARBOOT.SYS
    129702PC Eval should print HDD information
    128038Chipset on Vostro 410 tower fails to recognize SATA HDDs
    127463TDMS Open File gives error 6 on VxWorks targets
    125993Quad Core Crash - ThEvent.cpp(211) on LV RT 8.6
    104678Remove "SASASASASASASA" printout from multicore code
    104016PC Eval should not show "No PCI support available." as catch all for PCI BIOS check
    96813Libraries contain illegal characters that cause build to fail
    91776Summer/winter time on FP controllers
    53747RT Project Wizard "generates" bad HTML file
    Important Information
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in the NI Real-Time Hypervisor, refer to the Copyright topic of the LabVIEW Help.
    National Instruments, NI, ni.com, LabVIEW, and LabVIEW Real-Time Module are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    For patents covering the National Instruments products, refer to ni.com/patents.
    GMT+8, 2026-2-25 02:25
