查看: 4131|回复: 0
[LV工具模块] LabVIEW 2010SP1 Real-Time Module LV2010SP1实时模块RealTime2010SP1 Win32Eng 32位Windows英文版下载
    前天 16:03
    发表于 2020-7-1 17:18:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    RT2010SP1E.txt (259 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2010 SP1 Real-Time Module Readme
    Version 10.0.1
    December 2010
    This file contains important information about the LabVIEW 2010 SP1 Real-Time Module.
    Supported Platforms
    Installation
    Licensing
    Real-Time Operating System Versions
    Supported Platforms
    The Real-Time Module supports the following operating systems for application development:
    • Windows XP
    Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    Note  The Real-Time Module does not support Windows NT/Me/9x. The Real-Time Module also does not support the Windows Server non-R2 editions.
    Installation
    You can install all of your LabVIEW products—including the LabVIEW Real-Time Module—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the Real-Time Module along with activation instructions in the following locations:
    • LabVIEW Real-Time Module Release and Upgrade Notes, which are available in your LabVIEW Real-Time Module software kit or online at ni.com/manuals.
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Real-Time Module Release and Upgrade Notes for more information about upgrade and compatibility issues, a list of new features, and installation instructions. The LabVIEW Real-Time Module Release and Upgrade Notes is included as a printed booklet with the kit. You also can access the LabVIEW Real-Time Module Release and Upgrade Notes by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the Real-Time Module»Real-Time Module Related Documentation topic on the Contents tab.
    Installing and Configuring Japanese Language Support
    After you install the LabVIEW Real-Time Module 2010 on your development computer, you can complete the following steps to install and configure Japanese language support on an RT target.
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer to install the Language Support for Japanese software component on the RT target. Refer to the NI Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese as the Locale.
    Installing Language Support for Japanese does not enable Japanese language support within the RT target file system. You cannot use Japanese characters in directory names or file names on the RT target.
    Licensing
    The LabVIEW Real-Time Module relies on licensing activation. You must activate a valid LabVIEW Real-Time Module license before you can run the LabVIEW Real-Time Module. To activate the LabVIEW Real-Time Module, use the serial number you received as part of your installation package.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    The Real-Time Module 2010 installs the following RT target operating systems. Refer to the specific RT target hardware documentation for information about which real-time operating system your RT target uses.
    • NI ETS 13.1
    • VxWorks 6.3
    Supported Real-Time Operating System Features
    The Real-Time Module supports only a subset of the features that the ETS and VxWorks operating systems support. Refer to the Real-Time Module book on the Contents tab in the LabVIEW Help for information about features that the Real-Time Module supports.
    Refer to the LabVIEW Real-Time Module Release and Upgrade Notes for information about upgrade and compatibility issues. The LabVIEW Real-Time Module Release and Upgrade Notes is included as a printed booklet with the kit. You also can access the LabVIEW Real-Time Module Release and Upgrade Notes by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the Real-Time Module»Real-Time Module Related Documentation topic on the Contents tab.
    This section includes information about known issues for the LabVIEW 2010 Real-Time Module.
    MathScript Probe Support
    The LabVIEW 2010 MathScript RT Module adds support for the Variables page of the MathScript probe on RT targets. However, the Real-Time Module Help still indicates that MathScript probes are not supported on RT targets.
    You can access the complete software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2010 Real-Time Module.
    The following items are the IDs and titles of a subset of issues fixed in the RT Module 2010 SP1.
    234786Network streams fail to reconnect after some network interruptions
    243651VxWorks crashes with classes in source distribution
    255645Desktop Utility USB Drive formats first enumerated drive regardless of user selection
    238528Phar Lap targets fails to boot after USB system replication restore applied
    The following items are the IDs and titles of a subset of issues fixed in the RT Module 2010.
    128039HDDs not identified as Controller0 fail in RT
    221963Desktop PC Evaluator for RT-Module 2009 SP1 fails: "Unable to create process for format/replication procedure"
    127150Add deployment option in project for RT source distributions
    136654Abnormal Increase of CPU load on a PXI-8186 RT with LV 8.5
    158524Unable to bind a control to function block variables
    160689Memory Leak with To Variant and Variant to String VIs on cFP-2220
    173723RTSet Date and Time.vi for RT doesn't like the context menu for RT Utilities Palette
    173046Code with many reentrant sub-VI's and timed loops crashes PXI RT system
    181653Add a special meesage to the crash log and crash dump for ExitProcess on PharLap (DAbort does)
    192032Error -1: Unknown drive I/0 error when formating a IDE CompactFlash hard drive for 8.6 RTPC
    45336Export raw ping functionlity in PharLap
    199041The Desktop PC Utility USB drive can hang with over 2GB of memory
    201244Stop Timed Structure gives error -804 for reentrant SubVIs
    195089Unable to Use LV 2009 Desktop PC Utility USB Drive with NI 8353
    194232Over 20 probes in debuggable real-time VI causes target to disconnect
    199420RT Create Target Disk Image.vi disregards capitalization in filenames
    196547Memory leak when loading lvuste.dll by way of call library function node
    211484Synchronize with Scan Engine Configuration Gives Invalid Options and Can Cause the cRIO to Crash
    216319Adding Source Distribution that has licensed VIs in it to an Installer will add a folder with the same name as the dependent library and throw an error during install
    192986RT FIFOs do not support waveforms with Y arrays other than DBL & I16 datatype
    104454Cannot Open VI Server Reference on Embedded Controller Running VxWorks 6.3
    217634Zip packaging of RTEXEs increased memory utilization on target by 20%
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in the NI Real-Time Hypervisor, refer to the Copyright topic of the LabVIEW Help.
    For patents covering the National Instruments products, refer to ni.com/patents.
    GMT+8, 2026-2-25 02:24
