查看: 3389|回复: 0
[LV工具模块] LabVIEW 2010SP1f1 Real-Time Module Patch LV2010SP1实时模块RealTime2010SP1f1补丁 Win32Eng 32位Windows英文版下载
    前天 16:03
    发表于 2020-7-1 17:22:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    请先下载实时模块RealTime2010SP1,再安装该补丁。
    LabVIEW 2010SP1 Real-Time Module LV2010SP1实时模块RealTime2010SP1 Win32Eng 32位Windows英文版下载
    http://visionbbs.com/thread-24189-1-1.html
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    RT2010SP1f1E.txt (257 Bytes, 下载次数: 0, 售价: 5 圆)
    The LabVIEW Real-Time 2010 f1 patch resolves the following 3 issues:
    246593        The Power of X and Y-th Root of X functions return incorrect results when using single precision numbers (Phar Lap ETS only)
    244148        The Secant, Cosecant, Cotangent, Inverse Cosine, Inverse Secant, and Sinc functions return incorrect results when using extended precision numbers. (Phar Lap ETS only)
    243004        When you call a Web Service, the boolean control terminals invert on the Web method VIs.
    Note: Corrective Action Request #243004 is fixed by patching a component which can be installed by several software distributions. The following software distributions install the component which must be patched:
    LabVIEW 2010 Real-Time Module
    NI VeriStand 2010
    NI-RIO 3.5.0
    NI-RIO 3.5.1
    NI WSN 1.2
    GMT+8, 2026-2-25 02:25
