查看: 4369|回复: 0
[LV工具模块] LabVIEW 2015 Real-Time Module LV2015实时模块RealTime2015-Eng 32位Windows英文版下载
    前天 16:03
    发表于 2020-7-1 18:55:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    自2011版实时模块起,NI提供了中文、日文、英语等三个语言版。本视觉论坛仅提供中文和英文版,日文版本本论坛不提供下载。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    下载地址1:
    下载地址2:
    RT2015E.txt (362 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2015 Real-Time Module Readme
    June 2015
    This file contains important information about the Real-Time Module, including installation instructions, new features, a partial list of bugs fixed for the LabVIEW 2015 Real-Time Module, and known issues.
    The LabVIEW Real-Time Module is a complete solution for creating reliable, stand-alone embedded systems with a graphical programming approach. As an add-on to the LabVIEW development environment, the LabVIEW Real-Time Module helps you develop and debug graphical, deterministic real-time applications that can be downloaded to and executed on embedded hardware devices such as NI CompactRIO, NI CompactDAQ, NI Single-Board RIO, PXI, vision systems, or even third-party PCs.
    • LabVIEW 2015 Full or Professional Development System (32-bit)
    • At least 200 MB of disk space in addition to the LabVIEW-recommended minimum
    • One of the following operating systems for application development:
      • Windows 8.0/8.1
      • Windows 7
      • Windows Vista
      • Windows XP Service Pack 3 Professional
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    Note:
    • The Real-Time Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    • Support for Windows Server 2003 R2 might require disabling physical address extensions (PAE). Refer to the National Instruments website for information about how this might affect your use of Windows Server 2003 R2 and what actions you might have to take.
    • The Real-Time Module does not support the Windows Server non-R2 editions.
    The Real-Time Module installs the following real-time operating systems (RTOSes). Refer to the specific RT target hardware documentation for information about which RTOS your target uses.
    • NI ETS
    • NI Linux Real-Time
    • VxWorks
    Note:   Each RTOS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Real-Time Operating Systems book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features and special considerations for each RTOS.
    The following table lists the application software versions, including service packs, supported by the LabVIEW 2015 Real-Time Module.
    Application SoftwareVersions Supported by Product
    LabVIEW2015 (32-bit only)
    You can install all of your LabVIEW products—including the Real-Time Module—using the LabVIEW 2015 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target:
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer (NI MAX) to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note:  You cannot use Japanese or Simplified Chinese characters in directory names or filenames on the RT target.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Real-Time Module.
    Maximizing RT FIFO Throughput
    Customers using RT FIFOs with Linux Real-Time targets and the LabVIEW 2015 Real-Time Module may see increased CPU utilization compared to previous versions. If your application requires you to maximize FIFO throughput and minimize CPU impact, you may need to use the same CPU core to read from and write to the same RT FIFO.
    The following items are the IDs and titles of a subset of issues fixed in the Real-Time Module. This is not an exhaustive list of issues fixed in the current version of the Real-Time Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    521631Obtain Queue Function does not preallocate memory to the Max Queue Size when Embedded UI is enabled.
    519937Making changes to a LabVIEW class between interactive deployment sessions can cause the Real-Time target to crash or hang.
    519798Running the Profile Performance and Memory tool on a cRIO with Embedded UI enabled crashes the Real-Time runtime on the target.
    515335Running parallel read and write Timed Loops with RT FIFOs can cause the read to intermittently hang.
    514835The "enable project access" option can be configured in MAX but the property is missing from the system configuration API.
    513004WebDAV Server on VxWorks Real-Time controllers returns incorrect response for "last modification" when accessed with Directory Listing.vi.
    505224NI Linux Real-Time (Intel x64-based) does not natively support third-party USB ethernet dongles but NI Linux Real-Time (ARM-based) does.
    485965Using a custom right click menu in interactive mode with Embedded UI enabled can cause the Real-Time runtime to crash.
    475970RT Wait function does not wait for the correct amount of time on Linux RT Controller.
    428520LabVIEW classes within a CompactRIO Target, configured for hybrid mode, containing Open FPGA Reference by VI will cause UDVs and Scan Engine Variables to load incorrectly in the project.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Real-Time Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Real-Time Module are located in the labview\examples\Real-Time Module directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    LabVIEW Real-Time Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The LabVIEW Real-Time Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Real-Time Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 1999–2015 National Instruments. All rights reserved.
    374714C-01
    GMT+8, 2026-2-25 02:24
