查看: 4566|回复: 0
[LV工具模块] LabVIEW 2017 Real-Time Module LV2017实时模块RealTime2017-Eng 32位Windows英文版下载
    前天 16:03
    发表于 2020-7-2 10:47:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    自2011版实时模块起,NI提供了中文、日文、英语等三个语言版。本视觉论坛仅提供中文和英文版,日文版本本论坛不提供下载。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版:
    ZIP版:
    下载地址1:
    下载地址2:
    RT2017E.txt (448 Bytes, 下载次数: 5, 售价: 10 圆)
    LabVIEW 2017 Real-Time Module Readme
    March 2017
    This file contains important information about the LabVIEW 2017 Real-Time Module, including system requirements, installation instructions, a partial list of bugs fixed for the LabVIEW 2017 Real-Time Module, and known issues.
    New and Changed Features
    The LabVIEW Real-Time Module is a complete solution for creating reliable, stand-alone embedded systems with a graphical programming approach. As an add-on to the LabVIEW development environment, the LabVIEW Real-Time Module helps you develop and debug graphical, deterministic real-time applications that can be downloaded to and executed on embedded hardware devices such as CompactRIO Controllers, CompactDAQ Controllers, CompactRIO Single-Board Controllers, PXI Controllers, vision systems, or even third-party PCs.
    The LabVIEW Real-Time Module has the following requirements:
    • LabVIEW 2017 Full or Professional Development System (32-bit)
    • At least 200 MB of disk space in addition to the LabVIEW-recommended minimum
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    • The Real-Time Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The Real-Time Module supports the following operating systems for application development:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 the LabVIEW Real-Time Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 Real-Time Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 Real-Time Module to an unsupported OS. Additionally, after installing the LabVIEW 2017 Real-Time Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The Real-Time Module installs the following real-time operating systems (RTOSes). Refer to the specific RT target hardware documentation for information about which RTOS your target uses.
    • NI Linux Real-Time
    • Phar Lap ETS
    • VxWorks
    Note  Each RTOS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Real-Time Operating Systems book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features and special considerations for each RTOS.
    The LabVIEW 2017 Real-Time Module supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by the LabVIEW Real-Time Module
    LabVIEW2017 (32-bit only)
    You can install all of your LabVIEW products—including the Real-Time Module—using the LabVIEW 2017 Platform media.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target:
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer (NI MAX) to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note  You cannot use Japanese or Simplified Chinese characters in directory names or filenames on the RT target.
    Configuring RT Targets
    Use NI MAX to configure RT targets and to install software and drivers on targets. You can install NI MAX from the LabVIEW Platform media.
    • Networked RT Targets—Refer to the Remote Systems book in the Measurement & Automation Explorer Help, available by selecting Help»MAX Help from MAX, for information about configuring networked RT targets.
    • Desktop PC Targets—Refer to the Using Desktop PCs as RT Targets with the Real-Time Module document for information about configuring a desktop PC as a networked RT target. Navigate to the labview\manuals directory and double-click RT_Using_PC_as_RT_Target.pdf to open the document.
    Note  If you install NI Web-based Configuration & Monitoring on an RT target, you can use a web browser to perform common monitoring and configuration tasks on the target. On the Contents tab in the LabVIEW Help, select Fundamentals»Working with Projects and Targets»How-To»Monitoring and Configuring a Remote Device from a Web Browser for information about NI Web-based Configuration & Monitoring.
    The LabVIEW 2017 Real-Time Module has the following feature changes:
    • The Watchdog Configure VI includes a new parameter, restart LabVIEW Runtime, in the expiration actions input. You can use this parameter to restart only the LabVIEW Real-Time Run-Time Engine without resetting the FPGA application or losing network connection.
    • Starting from the 2017 release, the LabVIEW Real-Time Module no longer includes the OPC UA VIs. The LabVIEW OPC UA Toolkit contains the OPC UA VIs previously included in the LabVIEW Real-Time Module and the LabVIEW Datalogging and Supervisory Control Module.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the Real-Time Module.
    The following items are the IDs and titles of a subset of issues fixed in the Real-Time Module. This is not an exhaustive list of issues fixed in the current version of the Real-Time Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    613222cURL doesn't parse the authority component of a URL correctly when the host name component ends with a # character.
    607423Front panel fonts are sometimes all displayed as the same style and size on Linux RT.
    593319Writing TDMS files to an RT controller using the DAQmx Read VI can result in a memory corruption.
    588116Modbus I/O Server Bound Variables lose the value for varSourceProjectSubPath when they are moved to a different library.
    580006Adding a Prefix to the Dependencies when creating a Source Distribution for Linux RT targets breaks subVIs (i.e. causes broken arrows) that are using certain LabVIEW functions.
    Refer to the previous versions of the LabVIEW Real-Time Module Release and Upgrade Notes, available on ni.com/manuals, for changes in previous versions of the Real-Time Module.
    Note  The LabVIEW Real-Time Module Release and Upgrade Notes document was deprecated from the 2016 release.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Real-Time Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Real-Time Module are located in the labview\examples\Real-Time Module directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 1999–2017 National Instruments. All rights reserved.
    374714G-01
    GMT+8, 2026-2-25 01:40
