查看: 2817|回复: 0
[LV工具模块] LabVIEW 2011 Electrical Power Suite LV2011电力套件EPS2011电力工具包
    22 分钟前
  • 签到天数: 3792 天
    连续签到: 43 天
    发表于 2020-7-9 11:03:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2011 Electrical Power Suite Win32Eng LV2011电力套件EPS2011电力工具包
    文件大小: 63397984 字节 (60.46 MB)
    修改日期: 2012-02-08 00:00
    MD5: 397f669a344a5f1ae11b24f30ab1a2f0(重复一致)
    SHA1: 23f147441000480c38d63ba72ff6684447e79bc4
    SHA256: 29900619a747d372fe2375dbe0a3063b4a0bd213396dcbae3012d247446faab8
    CRC32: 90a5b72f
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EPS2011.txt (252 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2011 Electrical Power Suite Readme
    December 2011
    This file contains important information about the LabVIEW 2011 Electrical Power Suite. This file also provides you with help resources that you can use while working with the Electrical Power Suite.
    This file contains the following information that you need to understand.
    The LabVIEW Electrical Power Suite provides VIs that you can use to create applications on the NI CompactRIO platform to measure, analyze, monitor, and record electrical power data. You can use the Electrical Power VIs to measure voltage, current, and frequency, measure power and energy values, analyze voltage and current events, and aggregate and log data.
    The Electrical Power Suite complies with the following standards:
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    • IEC 61000-4-7:2002, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111:1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118:2005, Synchrophasors for Power Systems
    The computer you are using must meet the following minimum system requirements to run the Electrical Power Suite:
    • 200 MB free disk space
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    • LabVIEW 2011 FPGA Module
    • LabVIEW 2011 Real-Time Module
    • NI-RIO 4.0
    You can run the Electrical Power Suite on the following operating systems:
    • Windows XP Service Pack 2 or later
    Note: The Electrical Power Suite does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    You can install the Electrical Power Suite by downloading and running the LabVIEW Electrical Power Suite Installer. Double-click the setup.exe file in the root directory of the LabVIEW Electrical Power Suite Installer and follow the instructions on the screen to install the Electrical Power Suite.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Electrical Power Suite. On the Contents tab of the LabVIEW Help, choose Toolkits»Electrical Power Suite.
    LabVIEW examples for the Electrical Power Suite are located in the labview\examples\Electrical Power folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find example VIs using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder. Use the Browse or Search page of the NI Example Finder to find an example VI. In the Browse page, the Electrical Power Suite examples are located in the Toolkits and Modules»Electrical Power folder.
    Important Information
    GMT+8, 2026-2-3 08:40
