查看: 4158|回复: 0
[LV工具模块] LabVIEW 2012 Electrical Power Suite LV2012电力套件EPS2012电力工具包
    18 分钟前
  • 签到天数: 3792 天
    连续签到: 43 天
    发表于 2020-7-9 11:06:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2012 Electrical Power Suite Win32Eng LV2012电力套件EPS2012电力工具包
    文件大小: 67544200 字节 (64.42 MB)
    修改日期: 2014-08-06 17:52
    MD5: a90dc298817a2f73abb97d9459566650(官方正确)
    SHA1: d7955545a1d2639220824040b6e702d9f5799c95
    SHA256: 7aa2f6500c2c364865acfb06bbd9e4cd53326638967137e710bf8d990705ab98
    CRC32: a41acfbc
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    链接:请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服 提取码: 请注册登录视觉论坛会员,购买附件查看
    下载地址1:
    下载地址2:
    EPS2012.txt (383 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 Electrical Power Suite Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW 2012 Electrical Power Suite, including system requirements, installation instructions, and known issues.
    The LabVIEW Electrical Power Suite provides VIs that you can use to create applications on the NI CompactRIO platform to measure, analyze, monitor, and record electrical power data and phenomena. You can use the Electrical Power VIs to measure voltage, current, and frequency, measure power and energy values, analyze voltage and current events, aggregate and log data, and perform synchrophasor measurement.
    The Electrical Power Suite complies with the following standards:
    • IEC 61000-4-7:2002, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111:1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118:2005, Synchrophasors for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    In addition to the system requirements for the LabVIEW Development System, the Electrical Power Suite has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    • LabVIEW 2012 FPGA Module
    • LabVIEW 2012 Real-Time Module
    • NI-RIO 12.0
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    Double-click the setup.exe file in the root directory of the Electrical Power Suite installer and follow the instructions on the screen to install the Electrical Power Suite.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Electrical Power Suite.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Electrical Power Suite.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Electrical Power Suite are located in the labview\examples\Electrical Power directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2012 National Instruments. All rights reserved.
    GMT+8, 2026-2-3 08:37
