查看: 2877|回复: 0
[LV工具模块] LabVIEW 2013 Electrical Power Suite LV2013电力套件EPS2013电力工具包
  • 签到天数: 3816 天
    连续签到: 9 天
    发表于 2020-7-9 11:09:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2013 Electrical Power Suite Win32Eng LV2013电力套件EPS2013电力工具包
    文件大小: 94500128 字节 (90.12 MB)
    修改日期: 2013-06-14 18:16
    MD5: d52287cb2994d15c94fd6244ea544f53(官方正确)
    SHA1: abf87578d7bfe2576f1700dc91eacbef2a00bd69
    SHA256: 4aa36ac7a784cbdf4acef59b1ee541bd63f82062b71ccdd0b803b3fe3517c9fe
    CRC32: f00c68eb
    LabVIEW电力工具包可帮助您开发应用程序来测量、分析、 监控和记录电力数据和现象。
    LabVIEW电力工具包是LabVIEW的一个附加软件,可帮助您自行开发单相或三相电力监控、计量或质量分析应用程序。LabVIEW电力工具包包含了功率测量和电能质量VI,可用于测量电力和质量参数以及在CompactRIO、CompactDAQ和PXI平台上执行谐波分析。该工具包还提供了同步相量测量VI以及保护VI(用于保护CompactRIO平台上的设备)。
    2016版本之前的电力模块叫Electrical Power Suite,简称EPS,2017之后的版本叫Electrical Power Toolkit,简称ETP。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    链接:请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服 提取码: 请注册登录视觉论坛会员,购买附件查看
    下载地址1:
    下载地址2:
    EPS2013.txt (379 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2013 Electrical Power Suite Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW 2013 Electrical Power Suite, including system requirements, installation instructions, and new features.
    The LabVIEW Electrical Power Suite provides VIs that you can use to create applications to measure, analyze, monitor, and record electrical power data and phenomena. You can use the Basic Measurement VIs to perform basic electrical power analysis and use the Power Quality VIs to perform power quality measurement on the NI CompactRIO platform, NI CompactDAQ system, and PXI platform. You can use the Synchrophasor VIs to perform synchrophasor measurement and use the Protection VIs to implement protection devices on the NI CompactRIO platform.
    The Electrical Power Suite complies with the following standards:
    • IEC 61000-4-7:2002, Electromagnetic Compatibility (EMC) - Part 4-7: Testing and Measurement Techniques - General Guide on Harmonics and Interharmonics Measurements and Instrumentation, for Power Supply Systems and Equipment Connected Thereto
    • IEC 61000-4-15:2010, Electromagnetic Compatibility (EMC) - Part 4-15: Testing and Measurement Techniques - Flickermeter - Functional and Design Specifications
    • IEC 61000-4-30:2008, Electromagnetic Compatibility (EMC) - Part 4-30: Testing and Measurement Techniques - Power Quality Measurement Methods
    • IEEE Std C37.111:1999, IEEE Standard Common Format for Transient Data Exchange (COMTRADE) for Power Systems
    • IEEE Std C37.118:2005, Synchrophasors for Power Systems
    • EN 50160:2007, Voltage Characteristics of Electricity Supplied by Public Distribution Networks
    In addition to the system requirements for the LabVIEW Development System, the Electrical Power Suite has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit)
    • LabVIEW 2013 FPGA Module
    • LabVIEW 2013 Real-Time Module
    • NI-RIO 13.0
    • NI-DAQmx 9.7.5 or later (only required if you use National Instruments DAQ devices with the Electrical Power Suite)
    • At least 200 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    Double-click the setup.exe file in the root directory of the Electrical Power Suite installer and follow the instructions on the screen to install the Electrical Power Suite.
    Electrical Power Suite Updates and Notifications
    The LabVIEW 2013 Electrical Power Suite includes the following new features:
    • Protection VIs—Use the Protection VIs to implement protection devices on the NI CompactRIO platform. You can use the Protection VIs to measure input energizing quantities, set thresholds of pick-up signals, and delay for certain time intervals before trip signals assert. You also can use the Protection VIs to control the automatic reclosing and lockout of circuit breakers. If you want to know information about validation tests, visit ni.com/info and enter Info Code ex9nfa to access this information.
    • Power Quality VIs for National Instruments DAQ Devices—Use the Power Quality VIs to perform power quality measurement on the NI CompactDAQ system and PXI platform.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Electrical Power Suite.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Electrical Power Suite.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Electrical Power folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Electrical Power Suite in the labview\examples\Electrical Power directory.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Electrical Power Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Electrical Power Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the Electrical Power Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2013 National Instruments. All rights reserved.
    GMT+8, 2026-3-5 11:00
